Question about Music
Manuals mixer I need the manual for sound effects
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Music Master
  • 102,366 Answers
For what make and model mixer?
Posted on May 01, 2013
I cannot hook my Behringer mixer to the Pioneer EFX 500 it's not working
I presume you are using the send and return inputs on the EFX500.
Make sure the effect selector, CH Selector and EF On/off are set right. then use these in the insert chain of the mixer for the channel/bus/sub you want to use the effects on. Remember on the mixer it will be tip send and ring return. It would be useful if you said which behringer mixer (they make an awful lot of them from complex digital to simple DJ) and what you are trying to do with it.
It is clearly explained in the Pioneer manual under basic connections. If you are a DJ you may not be familiar with the Insert concept so get yourself down to a professional sound/PA outlet or Radioshack / Maplin and ask for a pair of insert leads.
May 23, 2016 | Behringer Music
Have a mackie profx8 and the effects don't work
Sounds as if you're not sending a signal to the effects unit or it is not sending it's signal to the bus you want. The manual should sort you out.
Jun 07, 2014 | Mackie ProFX8 Professional Compact Mixer
Why do i have echo when i play music on my phonic powerpod 820 mixer
Visit this link to download the manual if you don't have it already. https://phonic.box.net/shared/crqxhlhmmz
This mixer has a multi-effects processor onboard, but the key is understanding the audio signal chain. There is a chance that you have your input audio going through an undesired effect, but without knowing your setup (input source, connections, mixer settings), it would be difficult to pinpoint the problem.
Apr 04, 2011 | Phonic Powerpod 820 Mixer
Can't route effects to two channels of my mixer. If I plug into input 1 of my power amp, I have effects. If i plug into input 2 of my power amp, I get no effects. I tried both Crown and QSC power amps. ...
The power amp is the final stage - the last output from the mixer goes to the power amps.
Its a routing problem - some mixers only allow certain routing and this could be affecting your FX routes.
All the FX - internal or outboard come before power.
Check the manual Check the aux send and returns Check if you need need stereo plugs for the send and return of FX.
Get back if still stuck.
Feb 26, 2011 | Lexicon MX400XL Dual Stereo/Surround...
HELLO, I HAVE A BEHRINGER PMP 3000 MIXER, AND I CANT SEEM TO GET THE FX TO WORK EVEN THOUGH I FOLLOWED THE INSTRUCTIONS IN MANUAL, IME JUST WONDERING IF THERE IS SOMETHING IME OVERLOOKING? SCINCE I KNOW...
Do the following:
Set each of the FX mix knobs to 12 o'clock (halfway up to start)... I believe they are orange tops for each channel effects are desired for.
Next select the number of effect by rotating the selection knob. The display will flash.
Push DOWN on the selection knob to activate the selected effect number... the display will cease to flash. Note that you can mute the effects with a small button in the effect area and decimal point will come on showing effect, even though selected, is disabled. That small button can toggle the effects on and off.
Next, adjust the "FX to main knob" above the MAIN fader... set it to 12 o'clock to start with.
Note that there are two others that send the resultant same effect to stage monitors if used...
Now ADVANCE the FX (orange) fader to increase the input to the FX. You should start to hear the effects... SOME of the effects are subtle, so maybe choose a long delay one to get the hang of it... choose #3 for example...
The manual is NOT too clear how to use the effects and is confusing... they assume you have knowledge common to mixers... and new users don't.
I would recommend watching several YouTube videos about mixer setup... there are some good ones there !!! Most mixers have a lot in common and once you learn what is there, you can work most any of them... some of the new digital ones are a bit more confusing.
Feb 14, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Im thinking about buying a djx750 and have rokit 5 monitors. would this work? what is the best way to connect them, to have good sound? it is just for a home dj setup, all on one desk, two cd decks,...
Here is alink to the manual:http://www.behringer.com/EN/downloads/pdf/DJX750_P0956_M_EN.pdf You should have no problems hooking them up (RCA to RCA). I've been using a Behringer XenyX1222FX board in my recording system for about 4 years now and have been quite satisfied with it's reliability. Try to find a dealer who will demo the mixer for you.
Aug 24, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How to get the effects to work on the mixer
This is in general for Behringer mixers since you did NOT tell us a model number...
To use the effects you adjust the FX knob for EACH channel for the amount of the mic or input you want to send to effects from that channel. This is the "send" mix.
You dial in one of the effects based on the list near the effects selection window with the selector knob and the number will change and start flashing. You press down on the selection knob which will enter the new effects number and the number will be solid and not flashing.
Then there is a knob to select how much of the OUTPUT of the effects you want to go to the main and sometimes one for the amount to the monitors.
That is all there is to it. The effects can be gated by a foot switch input if you desire.
It is a good idea to include a model number as your thing is posted as if it is a PMP3000 mixer.
May 11, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I have an operational problem.
Here is Behringers website:http://www.behringer.com/EN/Support/ If you look at whatever model you want under products, the download link for the manual is usually on that page. For any other manufacturer, try typing the manufacture,model number and support or manual into Google or your search engine.
May 05, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
What do i need in a mixer? i want to connect my kaoss pad mini, and kaossilator, and obviously a couple of cdjs, and where do i connect them straight in the mixer or amp, im awaiting my purchase and just...
For dj use, industry standard would be something like a Pioneer DJM600 mixer. 4 channels w/ effects and a mic input. To use kaoss it's best to go into Send/Return input through the effects. By tapping on Send, all sound is sent out to the kaoss pad, and comes back into the mixer into the Return inputs. By doing this you can have the kaoss pad on sitting next to the mixer ready to apply effects all the time. Then connect the master outputs from mixer into your amp, or straight to powered speakers. Kaossilator is more of an instrument than effects unit, so plug in to channel 3 after your 2 cdjs in channel 1 and 2. You still have a spare channel left. I use 2 x 1200s and 2 x cdjs with kaoss pad through effects channel in this way. A 4 channel mixer is plenty.
Mar 25, 2009 | Korg Mini Kp Kaoss Pad
Music Logo
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
