Question about Konica Minolta bizhub Office Equipment & Supplies
C451 New Drivers Now Won't Let Me Staple Print Jobs
Installed latest BizHub drivers for my C451 and now I can't staple. Does not give options anymore says " This setting can be used with the following settings. "
5 Suggested Answers
waqar697
  • 67 Answers
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Posted on Mar 30, 2009
  • 7 Answers
SOURCE: i have a problem with a bizhub c451
sometimes especially when printing a pdf there is a box on the first print screen that pos up that says print actual size deselect that and then it will default and print on the paper that is available
Posted on Aug 22, 2009
SOURCE: error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
Posted on Aug 23, 2009
SOURCE: Our C451 Bizhub squeeks while idling...the techs
Have the techs replace the fusing unit, and install the update exit guide assembly (A0P0R73711)
This is a on going issue with this model, due to using induction heating, the fusing unit turns constantly, causing the squeak.
Posted on Apr 12, 2011
My machine bizhub c451 display error code p6,p7, p9,p16, p21
Registration errors. Have tech come out clean IDC sensors and replace black i/u
Feb 05, 2017 | Konica Minolta Bizhub C451 Copy-print-scan
I have c451 giving me heavy cyan background at the edges that suppose to be white after printing. What's the cause and what's the solution pls
First check the Laser window cleanliness,
Then check the IU-Cyan and its charging grid cleanliness.
also try in service mode-Image Processing Adjustment-
Background voltage value can be increased.
Dec 30, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
Bizhub c451
C3461 New Fusing Unit resetting failure
• A new installation is not detected when a new Fusing Unit is installed.
May 24, 2014 | Office Equipment & Supplies
Minolta bizhub c451 error code c- 11b0
Stapler in side the finisher is not moving correctly open the finisher a bring the stapler to replace staple cartridge position. If you can if not get a tech to look at it.
Nov 25, 2013 | Minolta Office Equipment & Supplies
121 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
