Question about Health & Beauty
JQ-5 Mini iSmart Massager
How do I turn my stimulator on
How to replace mini pro 2 massager faceplate?
Not clear what you mean by faceplate. Please elaborate.
Nov 09, 2014 | Thumper Mini Pro 2 Massager
Where can i get a thumper mini pro repaired?
Actually, you can remove the switch without opening the case, by simply carefully prying off the switch (which is actually a switch cover)
and then pushing the retaining clips of the "real" switch itself until it comes out. Then inspect & clean, and see if that solves your problem.
Another possible cause might be blown circuitry in the over-heat limiter.
May 20, 2014 | Thumper Mini Pro 2 Massager
Reclining is hard and the foot massager is not functioning, don't have the owners manual.
Sounds like the cable to foot massager is trapped in the levers. Turn it on its side and check. Unplug it first.
Sep 26, 2013 | Sunpentown Takasima A-619b 5-in-1 Air...
Where can I get the purple plastic pivoting assembly for my mini pro2 thumper massager
best to call the company & see if they have it available as a repalcement part.
Sep 06, 2012 | Thumper Mini Pro 2 Massager
How do I access the battery compartment on a Dr. Scholl's arctic heat mini massager
What a shame, I can't change the battery, so More plastic trash to pollute our environment. Why do manufacturer's do this? My arctic heat has run out of battery power and I can't open it and so I have to throw it away.
Jul 21, 2011 | DR Scholl's Dr Scholls Arctic Heat Hot And...
It wont turn on
throw it at the wall
May 23, 2011 | Thumper Mini Pro 2 Massager
Holding question
First, select a wide massage area, and use the roller surface. Slowly movethe head of the massager over the massage area in big, wide circles. Then,for areas of soreness or stiffness, change the massager to the proper mode (Some massagers have two levels) . Push down on these massage areas for about 5 to 7 seconds for eachsore spot. Finish with the roller surface again, moving the head around theextended massage area in large, uniform circles.
Aug 27, 2008 | Jobri Dolphin Handheld Massager
Health & Beauty Logo
44 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
