Question about Sony KV-35S42 35" TV
TV won't power up after surge
I have a 2000 sony trinitron KV-35S42 that hasn't worked since a power surge. The continuous blinking lights indicate something about Jungle IC 301, and was told on a previous post here that it needed a new board. I have some soldering experience with circuit boards, but not actual TV repair experience. I would love to try to tackle this repair, because the TV is so darn big, and to have someone come to the house could invest that money in a new set. Please help.
  • Thomas Rehm Aug 14, 2007
    I don't have an OHM meter, and am really not sure how to use it. I have some soldering experience 20 years ago, but that is really the extent of it. I consider myself handy, willing to learn. I am also cheap, and this set is sooo big and heavy I want to try and fix it.
  • 398 Answers
Try this: unplug the set and wait about 10 or 20 minutes. This is to make sure that the main power supply filter caps completely discharge. Look on the power supply board, close to where the AC cord attaches to the board. Look for a white resistor labeled "0.1 OHM" (the symbol for OHM, like an upside-down U) and measure it with your ohm meter. If it is open then your switching transistors in the main power supply are most certainly shorted. Older sets had 2 separate transistors on little heat sinks labeled "C4834", then they switched to 2 transistors in one package labeled "MX0841" or "MX0842", and then some sets went to two separate MOSFET transistors. Measure those parts and post your results and we will guide you from there.
Posted on Aug 09, 2007
SOURCE:
My tv kv-xr29m50 won'to on.stand-byl light blinks 8 time
Count the number of blinks occur at one time switch ON. These blinks are fault indications. After counting it, check this link for more details. There are details about Sony blinking codes. Search the site by brand name and model number to your TV in its search box.
Jan 29, 2013 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Tv Won't come on
I suspect a power board failure but to be sure i would have to know how many times your light is blinking as there is a code to it. please repost with number of blinks. This is a common problem with this brand of sony televisions as far as I can tell from what i have been reading online. If you are still under warranty you should contact Sony. If you need further help from an expert please let us know the number of blinks.
Aug 03, 2007 | Sony KV-35S42 35" TV
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Hi, my sony trinitron Wega KV-32Hs500 will not come on. The stadby light blinks 6 times. I was able to get it on yesterday after repeated turn on, but now won't come on at all. It was working great and had...
common problem. sony makes a power suplly service kit that will repair it. cheap. the power supply is very efficient but ver sinsitive to power surges. easy ans cheap. good picture is worth fixing.
Nov 15, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony kv-35s42 35" tv picture blinks off and on
my best advice would be to check power supply for faults, bad capcitors etc to r/o the possiabilies of a power failure.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 26, 2009 | Sony KV-35S42 35" TV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Tv won't power up
your regulator might be blown, & the red led is an indication your standby supply is still up. I can't recall the part #, its MX ### something, but there will most likely be a .22 ohm resistor feeding it, it'll be blown to
Aug 02, 2007 | Sony KV-35S42 35" TV
Sony KV-35S42 35" TV Logo
198 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
