Question about Refrigerators
Where is the defrost timer in frigidaire frs20zrg
3 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
  • 2696 Answers
SOURCE: Frigidaire FRS20ZRG Ice is collecting in the
sounds like the drain is blocked,melt out the ice with a hair dryer until you can remove the bottom bin or draw,and remove the second drawer or bin,look at the inside back wall of the freezer and follow it down to the bottom,if you can't see the drain hole you'll have to remove the wall to get at the drain,slime and food gets stuck in the drain and when the machine defrosts the ice that melts off of the evap coil turns to water and it goes down the drain and down into the pan where it evaporates from the heat of the compressor and condenser but when the drain gets blocked the water has nowhere to go but onto the floor of the freezer and eventually onto the kitchen floor,i use a steemer to blow out the drain hose if you don't have one melt out as much ice that you can and pour hot water into the hole,with something like a turkey baster or anything that will push through the drain will work,when you think it's clear pour more hot water into the drain,if it goes down you're done if not keep at it until the water drains through.hope this helps
Posted on Oct 21, 2011
How to fix a bad defrost control timer frigidaire ffu14fk1cw
Good Afternoon Friend,
I understand you want to know how to fix a bad defrost control timer on your Frigidaire freezer, model# FFU14FK1CW. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to fix the defrost control timer with ease. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire Freezers
Location of defrost timer on frigidaire model lfus2613f3
Hello Friend, thank you for allowing me to assist you!
It appears that the defrost timer of your Frigidaire refrigerator (LFUS2613F3) uses the main control board to energize defrost. The defrost timer is located at the front of the control console in the fresh food compartment (display that controls all functions). I do hope this information proves to be helpful! - Z
Jun 04, 2014 | Frigidaire FRS26KR4A Side by Side...
Where is the defrost relay button?
Frigidaire equips most of its refrigerator models with automatic defrosting capabilities. This means that owners don't have to set a calendar reminder to manually defrost. The internal automatic defrost control and timing mechanism is placed at the bottom of most Frigidaire refrigerators, next to the stationary panicon1.png that captures water - even the defrosted meltwater is automatically evaporated. You might be confused about how the defrost timer works, thinking it is broken. Frigidaire understood this might be an issue for some owners and suggests double-checking the defroster for normal operation because it may not be malfunctioning at all.
Read more: http://www.ehow.com/how_12165725_troubleshooting-frigidaire-defrost-timer.html#ixzz32x8RyDGe
May 27, 2014 | Frigidaire Ffhs2622mh 26 Cu. Ft....
FRIGIDAIRE FRS20ZRG STOPPED WORKING AFTER MOVING IT, LIGHTS STOPPED THE NEXT DAY
It may have been defrosting on a timed cycle when the compressor stopped. If any water was present at the time, it may have seeped into the electrics. Check the fuse and you have power to the on/off switch and thermostat.. If fuse blown, check all is dried out before plugging back in.
Apr 21, 2012 | Frigidaire Refrigerators
Location of defrost timer for frigidaire side by side
REMOVE BOTTOM FRONT TRIM UNDER FRONT DOORS
THE TIMER I BELIEVE IS ON THE LEFT SIDE YOU WILL SEE TWO PHILIP SCREWS REMOVE AND UNPLUG THE WIRE HARNESS FROM TIMER AND VOILA!
Jan 19, 2010 | Frigidaire Defrost Timer 215846602 ...
Where is the defrost timer located on a Frigidaire model # FRS24WNF?
its a defrost trermostat located near the evaporator coil and defrost heater coil
Oct 24, 2009 | Frigidaire Defrost Timer 215846602 ...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Mar 30, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
313 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
