Question about Philips FW-M56937 CD Shelf System
Speakers Looking for replacement speakers for this stereo system
Can I replace the speakers on this system? Speakers are too large for space & want to replace with another brand.
make sure impedance is the same so 6 ohms and the power rating of speakers is no less than 200 watts peak rms.And bare wire ports on back of speaker.
The power rating is so the speakers can handle the maximum power delivered by stereo amplifier without burning out speakers coils.
Jan 23, 2016 | RCA Audio Players & Recorders
Where can I find a free owners manual for a sharp stereo system model SC-9700C?
Can you upload the pics showing the back panel of the stereo system and the speakers and its connectors... No need of the manual..
May 10, 2014 | Sharp R-7A85 Microwave Oven
Need a new stereo to work with the old speakers
Any 5.1 surround system will work with this. It is better to be high in impedence than too low.
Feb 13, 2014 | Sony MHC-M300AV CD Shelf System
I am replacing a stereo system in my 2007 Chevy Suburban. I am looking for what each Harness ( Black, Purple and Grey ) are for and what wires go into each one. Can anyone help?
2007 Chevrolet Suburban Stereo Wiring Information
Radio Battery Constant 12v+ Wire: Red/White
Radio Ground Wire: Brown
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Not sure if this helps or not, ypur question is kind ofconfusing.
Oct 01, 2013 | Chevrolet Silverado 1500 Cars & Trucks
Looking for a diagram/schematic for the stereo wiring, so i can reinstall my new cd/stereo player
I hope this would help you: 1999 Chevrolet Silverado C1500 Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Feb 12, 2010 | 1999 Chevrolet Silverado 1500
Wiring diagram for audio system replacement? First time replacing a car audio system. I'm OK with wires connections but color codes does'nt match at all.... No diagram found in manual nether on actual...
2003 Mitsubishi Galant Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Black
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
pls rate
Mar 15, 2009 | 2003 Mitsubishi Galant
RS525 5 1/4
The infinity system is unique in that the amplifier for each speaker is built right onto the speaker. You will need to bypass it by looking at the wire colors as they go into the JVC stereo, then finding them at the speaker. My suggestion is to just put 2 new speaker wires in and wire the speakers directly to the radio. You will have to routhe them through the dashboard but it's pretty simple to do. BTW, i know that vehicle well as I used to own one and customized the whole van.
Jan 01, 2008 | Car Audio & Video
Philips FW-M56937 CD Shelf System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
