Question about Ovens
Frigidaire slef cleaning model RE-34BA REG-36A REG-36CA RSE-37BAL instructions
Frigidaire models RE34BA REG36A REG36CA RSE37BA instructions for self cleaning oven. Taken from owners manual: Setting the controls: 1. Close the oven door 2. Make sure the clock shows the correct time of day. 3. Be sure the Start Time knob is set for the same time as the clock. If not, turn the knob to the time on the cock. The knob will thin poop out. 4. Set the Stop Time for 2 to 3 hours past the Start Time. EXAMPLE: If the Start Time and Clock read 1:00, set the Stop Time for 3:00 or 4:00. 5. Set the Temperature Control to CLEAN. 6. Set the Selector to CLEAN. The door will lock and the oven signal light will come on. The oven signal light will stay on until the oven reaches its cleaning temperature. The clean light will come on when the oven temperature reaches approximately 550 degrees. The oven signal light will then cycle on and off to show the temperature is being maintained. It will then go off at the end of the cycle indicating that the high temperature phase is completed.. The oven must now COOL FOR ABOUT 1 HOUR or until the interior temperature has dropped below 550 degrees. Only then can the door be unlocked. The clean light will remain on until the oven cools below 550 degrees.
How to use Frigidaire self cleaning instructions lost manual
Good Afternoon friend, thanks for your inquiry!
To locate instructions regarding self-clean on your Frigidaire range I would need to have your model number. I have provided a link for you to use once you have your model number to locate any Use and Care Guides available on your current appliance. I hope this helps to some degree and if you need assistance please reach back out. -Matt
Sep 27, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Self clean instructions
Hello jeffreyandje - Do you have the exact model number so I can provide you instructions on how to use the self-clean mode? Meanwhile, the manual and operating instructions can be found on the manufacturer link. I will recommend taking off the last letter of the model number so you can pull up the information.
http://b2b.frigidaire.com/support/manuals.asp?NewSearch=New+Search
Dec 10, 2012 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Model CGLEF379GSA self-cleaning stove with ES340 Control: Won't self-clean after following instructions in manual.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Jan 04, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
We have a frigidaire fef354cjsa oven that has a self cleaning option. We started the self clean and it locked the door. 2 days later we cannot open the door still. The lock light is blinking. We have tried...
The best way to do is to pull the oven out if is built in and go through the top. If its free standing use a clothes hanger and make a hook and pull the latch to where youcan open the door. Your going to have to replace the lock motor assembly. Bit of advice though, slef clean is the worst invention ever and if you use it you will have more problems.
Nov 02, 2010 | Frigidaire Ovens
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
Self cleaning instructions
Hi. i have created a link for you to access the actual manual you are needing. please feel free to print it out or, save it to your CPU for safe keeping.
Click here for your Frigidaire manual.
please rate and god bless.
Mar 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door locked i tried the self clean got scared by the smell
The door will remain locked until the unit cools, this is a safety feature.
Feb 19, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire electri clean selfcleaning feature
It locks automatically. You can download the manual from Frigidaire here (as I just discovered while trying to figure out how to use the self-cleaning feature :) ): http://www.frigidaire.com/support/manuals.asp?NewSearch=New+Search
You don't need to type in the whole model number. For example, if the model number (found in the upper left when you open the oven door) is RSE37BAW*4, you only need to enter RSE37BA.
Apr 27, 2008 | Frigidaire Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
