Question about Doro PhoneEasy Cell Phones
DORO 410GSM can't connect to network
This phone has worked fine on the Tmobile network since I bought it for my mom. Now all of a sudden it wont connect to the network and when it does it disconnects as soon as she tries to make a call. It has no bars and the screen says Emergency, which means she can only make emergency calls. When I go to settings to see if if the network is set to tmobile it tells me AT&T as a network option. Sometimes tmobile shows up and then sometimes it does not. I already turned the phone off and removed the battery and sim. The problem continues. I called tmobile and they said to try the sim in another tmobile store and if it works then it is the phone but they could not give much help beyond that since they do not carry the DORO. Thanks for your help.
SOURCE: LG CU500 cell phone Call Divert Set problem
  • The issue is caused by the phonejack/memory chip assembly, located in the upper right rear of the phone has become unseated/loose and is causing your issues. I had the same problem and after I took the phone apart and put the assembly back in position, I eliminated the problem.
  • If you are not mechanically inclined and/or have access to small tools and an open area to work in, do not attempt!!!! There are numerous small parts including the side buttons and keypad and the above mentioned assembly that are exposed when you seperate the two sections that make up the back of the phone. If you attempt the repair be extremely careful to note the position of parts before you take it apart and make sure they go back in correctly. It is a bit time consuming but doable.
  • If you feel you can't do it yourself I'm sure that there are some online options for repair or perhaps a local repair shop that would do the repair. Good Luck
Posted on Jan 05, 2008
erone47
  • 458 Answers
SOURCE: My Nokia 3250 in "offline" mode.
The problem is with the sim card. try to remove the sim, clean it with a dry cloth and put it back in. if the problem is not solved, take back the sim to your network provider and get a replacement, asuming the sim is damaged
Posted on May 18, 2008
  • 14 Answers
SOURCE: My Blackberry Bold is unable to make or receive calls.
you can go to your call logs icon and click the blackberry key. After that choos options from the menu and go to call barring. Check if you have accidently switched on call baring. You can also try and do a hard reset of the device. You perform this by switching off the phone and getting the battery out and in again.
best regards
Posted on Mar 23, 2009
  • 437 Answers
SOURCE: Usim locked?
Enter this site www.unlock-lg-mobile.blogspot.com and unlock your phone in 5 minutes.
Posted on Aug 26, 2009
greenspan
  • 1734 Answers
SOURCE: How do i set up my sciphone i68+ with tmobile, i
Ask at chinamanuals.com - send them your provider and country and they will come back with the settings. They also have a i68 manual for download (which includes some settings).
I searched and found that for you, pls leave a good rating.
Posted on Oct 02, 2009
Can you give me PUK for SN: CKC23003V02839
Check online, at the carriers website log in and check you my accounts page. Or call the carrier, I have never been denied a puk code.
Sep 05, 2015 | Doro PhoneEasy 410gsm Easy Mobile Phone...
Fitted new sim card into new doro phone and tried to charge battery but no joy? keep checking sim is in correctly which i am sure it is! help!
Having the SIM in the phone doesn't affect whether the phone charges or not. I'm guessing either the charger you have is bad or the battery in the phone won't hold the charge.
Mar 02, 2015 | Doro Phoneeasy 410Gsm Easy Gsm Sim Free...
Dmy doro says insert sim when sim is in how can i fix that
Your device doesn't recognize the sim. First try to clean the connectors, than try different sim (eliminate the possibility your sim is bad) and if that will not work it means your device is broken and 95% is NOT software issue.
Good luck,
Konrad
Sep 23, 2014 | Doro Phoneeasy 410Gsm Easy Gsm Sim Free...
Doro phone 410gsm will not charge
For this problem contact the mobile service provider......
Sep 24, 2011 | Cell Phones
Operator code
Hello
Please indicate your exact problem with details, including the brand and model of your GPS device.
Sep 07, 2011 | GPS
My daughter bought a Phone Easy 410gsm over the internet for my Christmas gif. For some reason the phone does not retain outgoing msgs. Is this normal or have I got a faulty one?
Hi Victorem, I work for Consumer Cellular and thought I would pass along some helpful resources to you. In order to retain outgoing messages, there is a great "how to" video on our YouTube channel: http://www.youtube.com/watch?v=hq7YaFp2Lm4 that explains all of the features and settings on your Doro PhoneEasy410. You can also refer to your phone's manual: http://www.consumercellular.com/Support/Manuals for additional support. If neither of these resources help, feel free to give us a call at 1.888.345.5509. Thanks!
Feb 16, 2011 | Doro 410 Unlocked Phone with Speakerphone...
I want to unlock my doro phone easy 410gsm it is on orange now
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Jan 06, 2011 | Doro 410 Unlocked Phone with Speakerphone...
Cell Phones Logo
56 people viewed this question
Top Doro Cell Phones Experts
Computer Repairing
Computer Repairing
 Mikey
Mikey
ray gallant
Are you a Doro Cell Phone Expert? Answer questions, earn points and help others
