Question about Dell All-In-One Inkjet Printer V313
CHANGED THE INK , NOW IT SAYS , PRINTERHEAD NOT SUPPORTED BY THE ALL IN ONE
  • 826 Answers
Here's a video Rich Varsay suggested as a solution to your problem from YouTube:
Replacing Cartridges and the Printhead - HP Officejet Pro L7780 All-in-One Printer
Posted on May 02, 2013
My esp 3 kodak printer now has a printerhead problem after a year of use. When the printer does it's power up check I get a error with the ink cartridges indicator light lit up. When I remove the ink...
Your printer needs a service, in other words the waste ink sponges need to be cleaned and dried. They then need to be replaced and the printer reassembled. Then the Epson counter resetting software needs to be installed.
With this software the printer can be set to zero, it will work perfectly after this bit of attention.
It is a good printer, it's nothing that can't be repaired.
A computer technician will be more than happy to service your printer for you.
All the best!
damnor01
Feb 01, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
When printing no ink on paper. changed ink and cleaned printerheads severl times. still no ink on paper when printed. I toched the ink cartridge and there was ink on my finger from all ports. please help.
My printer did this when I first bought it and Kodak sent a new printhead, which solved the problem. If the printer is out of the warranty period, the charge is $24.99 for a new printhead.
Nov 03, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer isnt printing the color yellow.changed the ink and still the same thing..is it the printerhead?
is the yellow ink seated properly?
have u carried out the maintainence of the print head using the recommended guidance?
Oct 16, 2010 | Kodak ESP 5 Printer
Epson LX 300 printer. every line, starting
Try to check your printerhead it could be damage due to over use or old printerhead. Just replace your printerhead to print it normal.
May 29, 2010 | Epson LX-300 Matrix Printer
Black ink does not print
If your printer have a separate printerhead with the cartridge just try to replace the printerhead of that printer it is because the printerhead have a problem on that.
May 28, 2010 | Brother MFC 240C All-In-One InkJet Printer
Will not print---all I get is a blank paper
Try to check the ink of your printer that they have more ink inside. Or els just check the printerhead of that printer its maybe that was a problem for that. If they could not print at all after this solution just change your printerhead it is because that was the problem. If your printer are using the built-in printerheat from the cartridge just replace the cartridge of what color are did not print but if your using separate printerhead of your cartridge just only replace the printerhead only.
May 27, 2010 | Dell 926 All-In-One InkJet Printer
Howdo you remove printerhead from Kodak 5500
Here is the manual for reference:
Kodak 5500 Manual
If you go to page 88, these instructions are given...with pictures.
1 Make sure the AiO printer is on.
2 Open the printer access door. The carriage moves to a center position.
3 Wait until the printhead is idle and silent, then pinch the pinch latch on the ink cartridge with your thumb and forefinger and lift it out of the print head. Remove both ink cartridges and place them on a flat surface with the ink pads up.
4 Unlatch the printhead by pressing the button in the upper-left corner of the carriage.
5 Remove the old printhead.
Thanks for using Fixya.
Jul 02, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printerhead is not installed.
What you will need to keep in mind is that the ink cartridge contains liquid ink, once opened, can and will evaporate. First, wash you hands with soap and water to remove excess finger/hand oils. Use a clean, moist, paper towel, make sure you ring out the excess water from the paper towel before you begin. Remove cartridge, gently wipe the towel over the contact's pad, and the nozzel tip. Use a dry towel, and patt dry, reinstall. and run an alignment pattern test.
Note: If you do not see an ink trail on the paper towel, The Ink has dried up, and you will need to but a new cartridge.
Note: do not touch the Cartridge GOLD contacts, with your fingers, finger OIL will clog the jet pours, and cause them to corrode.
May 07, 2009 | Canon PIXMA MP610 InkJet Printer
Dell All-In-One Inkjet Printer V313 Logo
50 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
