Question about KitchenAid KESC307HBS Electric Kitchen Range
Kitchenaid superba oven
Display/control panel was starting to dim when oven was on. Then it began to dim when oven was off. Now the control panel won't display anything at all, but when I press the buttons it still beeps and the oven turns on also.
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
You will need to replace the control board. Here is that part to order.
Posted on May 03, 2013
SOURCE: Kitchenaid Superba Gas Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Posted on Aug 31, 2008
SOURCE: My kitchenaid superba has the control lock stuck
the control lock shows up on my stove how do i get it off.
Posted on Aug 17, 2009
SOURCE: Kitchenaid Superba Gas Range - Oven temperature problem
The problem is: the temp seems to be 'stuck' at 260 and will not allow any higher settings.
Calling KitchenAid proved to be unuseful. The manual did not have this item in the troubleshooting pages. Resetting the power does not help.
The SOLUTION:
There is really no problem besides that the temp display setting has been somehow set to be celsius (metric system) rather than farhenheit (english system). Changing this setting somehow can be easily touched off without knowing, thus the "I didn't do anything and yesterday it was working fine..." comment from family members.
The FIX:
Reset the temp display back to farhenheit (F). This is done by opening the oven door, then hold down the 'Broil' button until you hear a beep from the control panel. The same method may be used to change from Farhenheit back to Celsius.
Prevention:
I speculate the inavertent change of the temp setting is done while cleaning the flat control panel. So the best thing to do is to always 'LOCK' the control panel when cleaning the controls. This is done by holding down the keypad "3/lock" for a few seconds until the display shows LOCK.
(The solution was already posted when I arrived at this page. I just organized it a bit by adding some details and a preventative comment. Many thanks to those who posted earlier, solving my issue as well. I hope my writing presents a clearer and quicker read to the next person)
Posted on Aug 28, 2009
  • 291 Answers
SOURCE: Kitchenaid Superba - oven stopped and code F2E1 is
F2 E1 is an error code that says the membrane (touch pad assembly) is not connecting to the ERC(Electronic Range Control). Call the warrantee company and give them the model number and serial number of your range and ask them if it still has a parts warrantee on the electronics. If it does, they will have to send their technician out to replace the part or parts and charge you for the labor. Your model may have the membrane and Erc all in one part, so an easy diagnosis, if it is seperate you need to make sure the membrane ribbon connector is plugged tightly into the Erc, plug your range back in, press cancel, and then retest. If it still fails then replace the membrane, test and if it fails again, replace the Erc. Before you tear into this make sure you unplug the unit for 30 minutes, plug it back in and test. Sometimes this will reset the Erc and solve your problem. If it doesn't the make sure you unplug the range before doing any repair work. Good Luck, Appliance Specialists
Posted on Jan 06, 2010
SOURCE: KitchenAid Superba gas range/convection oven. Oven won't turn on.
From what I've read, the igniter is most often the problem and was with my KitchenAid Supra oven, Here are some details to help you do the actual repair by knowing where everything is located.
1. The oven has 2 igniters: one for the broiler (located at top inside of oven) and one the "overall" oven igniter (located underneath the heat shield on bottom of oven; remove 4 screws to get to it).
2. Do visual test to see if your broiler igniter works versus your oven igniter. It will glow orange if working. This is a good way to focus on the source of the problem (i.e., if no glow, then it may very well be the igniter).
3. Order new igniter. The site repairclinic.com shipped mine very fast.
4. To install: pull oven away from wall, unplug, and remove inside panel on back (not entire back panel but, rather, panel that is in the middle of the back). Here, you can access one of the two igniter wires. You can access the other wire by removing the storage shelf on the bottom of the oven. Snap the old ones off. Unscrew the igniter from inside the oven, Snake new wires through back.Screw new igniter in place. Put everything back in place and you are done!
Posted on Feb 16, 2010
How to unlock a kitchenaid superba stove
How-To Unlock A Kitchenaid Superba Oven - YouTube
? 1:24
www.youtube.com/watch?v=yKNGTVCEiuM
Sep 22, 2014 - Uploaded by Public Relations & Promotions
How-To Unlock A Kitchenaid Superba Oven ... Repair - Deadoven after self clean mode, blank display, locked door Kitchen
Sep 09, 2015 | KitchenAid Kitchen Ranges
Kitchenaid Superba 27 built-in Microwave/Oven
Disconnect it from power outlet for 30 minutes to hard reset the owen. It may be a faulty control panel or the fan thermistore switch.
Apr 02, 2008 | KitchenAid 27 in. Built-in...
Kitchenaid Superba KEMS307D Microwave buzzes, looks like it works, but doesn't heat. Full normal display, tray rotates, but fan doesn't sound normal.
Most likely causes - shorted high voltage rectifier, or failed high voltage transformer, or shorted high voltage capacitor, or shorted magnetron. If an odor accompanied the failure, high voltage rectifier or transformer most likely. All of these components operate on 4000 v, or more - with enough current to kill you. Make sure the unit is unplugged, and the high voltage capacitor is fully discharged before testing.
Apr 10, 2014 | KitchenAid Microwave Ovens
KitchenAid Superba Fridge beeping and clicking on and off
next to the compressor is a relay called a klickson
You can get engineer to replace for about $120 or buy one for about $20
Apr 08, 2014 | KitchenAid Refrigerators
Superba KGT607HBS oven stopped working
The flame went out.  Move the oven control back to where it sounds like it is lighting.  After it clicks a few times and sounds like you have a flame set your temperature again.
Nov 27, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
Kitchenaid superbra 24 oven
select clean on the control panel and set stop time then push start
Jan 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
Kitchenaid superba stove
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven. The Control Lock is preset off;
however, it can be enabled.
When the control is locked, only the TIMER SET/START and
TIMER CANCEL pads will function.
The Control Lock is preset unlocked, but can be locked.
Before locking, make sure the oven, the Timer and Timed Cooking
are off.
To Lock:
1.
Open the oven door.
2. Press and hold the number pad 3 CONTROL LOCK for 5
seconds.
A single tone will sound and “START?” will appear on the
display.
3. Press START. “CONTROL LOCK” and a picture of a lock will
appear on the display.
To Unlock:
1.
Open the oven door.
seconds.
A single tone will sound and “CONTROL LOCK” and a picture
of a lock will disappear from the display.
Sep 29, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
KitchenAid KESC307HBS Electric Kitchen Range Logo
257 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
