Question about Sylvania LC195SLX LCD TV
Remote does not power on, rest of remote works
Remote works except for power on and off which works if you hit manually, ideas? all other functions of remote works.
    Top Expert:
  • Sylvania Master
  • 74,136 Answers
It sounds that your remote control need cleaning. If you wish to get more details, check the site linked below. Pull up older posts there. Check the site with patience, as it has over 2400 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. One among the posts have details about how to clean and check a remote control.
Posted on May 02, 2013
Remote will no longer power on Onkyo HT-S3500. Once I turn it on manually, the rest of the functions work properly.
I just had this same issue. I tried to change the batteries for the factory remote that came with the Onkyo HT-S3500 (remote: RC-799M). Still no luck. It would not power on with the remote, despite the light flashing and the and all other remote function working. If I powered on the receiver manually, everything worked (except power on/off).
I just pushed a button on the remote labeled "REMOTE MODE RECEIVER" and viola, the remote now powers the device on and off and works just like usual. Not sure what the heck happened, but I would suggest pushing that button on your remote.
Dec 19, 2012 | Onkyo HT-S3500
I am trying to find a remote code for the Cox 7820 remote, that will fully operate my Hannspree tv. The codes provided by Cox will operate most of the TV functions, on the correct buttons, all except for...
I have a Hannspree 42" LCD and I have the exact same problem, the code worked to control all functions except "Power On". I checked the Hannspree web site's support section, it says that their TVs will not work with a universal remote unless you have DirecTV. So why does everything work except to turn it on if they claim their TVs do not work with other remotes?
Oct 25, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Pentair Easy Touch remote lost sync with the outside unit. Have tried resyncing a dozen times, per the manual, tried hitting the reset button and then resyncing...nothing worked. I removed the cover on...
Try turning the whole system power off at the main house panel, wait a minute, turn power back on, then go to the pool panel and reset communication as per manual instructions. This worked for me.
Sep 25, 2010 | Pentair Easy Touch Indoor Control Panel...
Only the power on works . The rest of the remote controls and manual controls including volume no longer work
First, unplug the TV from the outlet, wait a few seconds and reconnect the power, try the power and the rest of the TV functions, it could be that you need a new remote, if the TV keys(located on the TV itself) do not operate still , then you will need the TV checked out by a qualified tech, in this cases the key,microprocessor or the power supply boards could be at fault, not all of them, but one of the three.
Mar 10, 2010 | Televison & Video
New remote won't program to switch to cable input.
That's a problem with universal remote controls. Often they don't control every function of the TV. They just don't have the buttons needed to control everything the original remote did. You'll have the most basic controls - power, channel and volume up and down - and maybe a menu button. But you'll frequently find other things don't work, like switching inputs. There isn't anything you can do except try all the codes for your TV brand and see what each button does. You might find that the buttons have different functions depending on which code you've entered. You might also look for another brand of universal remote that has more functions available.
May 23, 2009 | Daewoo Televison & Video
26 ilo tv comes on but stuck in composite no functions on side works except for power switch
I would contact them on this
http://www.funai-corp.com/support/contact.aspx
in the manual see page 34 for testing the remote
http://www.funai-corp.com/6pdf/om/CIWL3206.pdf
Jan 26, 2008 | iLO 2600 Television
Remote Control-reset to factory settings
hi,,., i saw your concern... i worked for a big company whose supporting tv remote and universal remote... we reset remote by removing the batteries and by pressing all of the buttons twice (take not each and every button) by doing this it will discharged the power consume in the battery. and also check if there is a jammed or stucked button, or check if there will be a Function button... hope this may help
Jan 23, 2008 | Insignia IS-LCDTV32 32 in. Television
Remote won't turn set on anymore!
Hi Smittie, I had a similar problem with another type of TV set. All functions work well except power. The solution was to replace the batteries, perhaps they are running low. It will also reset the remote which might help as well. Hope this will work for you too. Cheers.
Feb 09, 2007 | Samsung TXN3271HF 32" TV
Sylvania LC195SLX LCD TV Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
