Question about Pool & Spa
Pool motor problem
Leaking water..
  • 783 Answers
If your pump is not moving water you first want to check the skimmer and pump baskets and make sure they are empty as not to restrict water flow. Next make sure your pool filter is clean. Once you have checked these, you may want to check the pump impeller. This is the part in the pump that is connected to the motor that moves the water. Impellers will clog from time to time, especially during the springtime. To inspect the impeller, you will need to open the pump, to see inside of the impeller housing or volute.
Posted on May 01, 2013
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: i just installed a us pool pump motor eb841 1hp 3450rpm 208volt 56y and it is leaking water behind the square bell housing actually leaking bottom side of motor
There is a leaky water seal on the pump shaft housing between the pump and the motor.
The drain hole prevents water from going into the motor and this seal needs to be replaced before the motor is damaged.
Posted on Aug 20, 2012
How to fix a hayward pool pump leaking from under neath
Shaft seal has failed. Replace it immediately or water will get into the motor and the motor will have to be replaced. The leaking is there by design to let you know when its time to replace the seal.
Aug 17, 2014 | Hayward Super Pump 1 1/2 - Hp for In...
Hayward pool pump leaking from underneath motor
The leak is an indicator the shaft seal has failed. It leaks by design to let you know to replace the seal before water gets into the motor and ruins it. Replace the seal right away.
Aug 17, 2014 | Hayward 3/4hp Super Pump Inground Pool...
Emerson pool spa pump leaking water-how to change gaskets
Emerson is not the name of the pump, that's the brand of the motor attached to the wet end, and the two together make a pump.
1081/1563 only means that it meets the standards for a pool motor.
provide make and model, for your pump.
Jan 23, 2014 | Emerson Pool & Spa
I just installed a us pool pump motor eb841 1hp 3450rpm 208volt 56y and it is leaking water behind the square bell housing actually leaking bottom side of motor
Aug 19, 2012 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Jacuzzi pool pump leaking
Where is it leaking? if it is still leaking between the wet end which is the black plastic water housing and the motor then the seal is not properly set.
Rod
US Parts Center
Aug 04, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
Century laser pool/ spa motor drips water is there a seal ? Or what causes this?
seal that joins wet housing and motor if leaking probably ruining bearings in motor replace whole pump
Jul 03, 2012 | AO Smith A O Smith Motors Century 1hp 115v...
Hayward Self-Priming Pump with AO Smith 1 HP 56J frame motor. Stopped moving inground pool water. Added water to pump basket (low). Turned on pump, return jets sent "bubbles" into pool, stopped, then...
the pump must not have any air leaks in the suction side of it,, or it will just **** air and not water,,, water is very heavy you see, however i think its the impeller in the pump thats the problem,,,you should try to put water in the out let of the pump so you fill the pump with water first if its dryed out it may just wear out the impeller before it starts to **** water up, if this still dont work turn off the stop **** and strip out the pump to look at the impeller any wear on it and it will need a new one fitted
i hope this has help you, good luck
Nov 20, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
Proline pool pump SD-1--1N11XB
This sounds like you have a bad seal in your pump and the loose piece is probally a piece on the shaft of the motor called a water slinger. This is just there in case your seal goes bad and leaks water it will spin with the motor and sling the leaking water out and away from the motor so a small leak does not ruin your motor. But you will still need to replace your seal and "O" ring.
Sep 12, 2009 | Hayward 1.5 Hp Northstar High Performance...
Pool & Spa Logo
800 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
