Question about Kitchen Ranges
I have a Ge profile range model # JCB968BK3BB. I turn it on and it warm up and then turns off after turning off you set any temp and it say it that temp. The broil isn't working. How can I fix this? What parts do I need?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
You have a bad "ERC" and it will need to be replaced. Here is that part to order.
Posted on May 03, 2013
jumptrout51
  • 3361 Answers
SOURCE: GE Profile Oven does not work although stove does
Check and or replace the glow bar ignitor.
Posted on Feb 21, 2009
beachin
  • 6 Answers
SOURCE: GE Profile Electric Stove - Buttons for oven don't work
We had a bunch of storms roll through the area and we figured a surge must have fried our control panel. We decided to buy a new oven rather than spend $200 fixing this one. Luckily, our local Sears rep wasn't in it just for the commission and suggested we flip the circuit breaker off for 10 minutes to allow the range to reset itself. Works good as new! So, try this first before you make a decision. Good luck!
Posted on Apr 03, 2009
  • 715 Answers
SOURCE: I have a GE XL True Temp gas range/oven. None of
your stove must be plugged in for the auto-pilot to work .do you hear a ticking noise when you turn on a burner?
Posted on Oct 07, 2009
  • 382 Answers
SOURCE: GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Posted on Dec 27, 2009
SOURCE: GE Range Model GRCR3825ZWW-1 DOOR error code on range display
The door latched Micro-switch is not working or is dirty.
Remove the back panel, in the middle of the back there will be a metal arm that moves in and out when self cleaning latch is closed and opened. This arm pushes two or more Micro-Switches in the back, they are dirty or not working and need replacing.
Posted on Jan 12, 2010
Ge profile oven model jgs968 won t stay hot
If it has a thermocouple, replace that. They are cheap and easily available. They wear out after a few years.
Dec 27, 2013 | Kitchen Ranges
I have a GE Hotpoint stove/range model num 317B6641P001 that the oven will not ignite nor will the igniter turn on.
It sounds like the ignitor is bad...you will not or should not smell gas if ignitor is bad...gas valve is not supposed to open until the sensor by the ignitor has reached a certain temp. It's a safety feature. If you replace the ignitor, it should work like normal.
Jan 31, 2013 | GE Profile JGSP44 Dual Fuel (Electric and...
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven tempature is 10 to 15 degrees lower than set temp.Can this be adjusted? This is a electric oven. GE Profile Model VZ295971J.
all ovens very sometimes 10-25 degrees +/- depending on the brand..nothing you can, do set the temp a little higher if you know its off.
Jan 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Dec 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Gas Range Model:JGBP79AEV4AA When i turn on the oven the flow of gas is interupted and continues (sort of like stops and starts) oven does warm up to temp however takes a long time. Any ideas?
Possibly an ignitor or valve problem. We also see this sort of thing due to a control board failure. If this turns out to be your case we can help. We repair oven controllers at www.fixyourboard.com
Oct 13, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Microwave Profile Spacemaker Runs on its own
Your microwave turning on by itself is a "self preservation feature" of the GE Profile Advantium and maybe some other models. Read the manual, When your over the range oven gets warm enough, for whatever reason the venting fan comes on until a satisfactory oven temperature is reached. You are not permitted to shut the vent fan off. Also it seems a temperature near room temp must be achieved before it shuts the fan motor off, it is very annoying. We had to return our Advantium because of fan noise. I configured the ovens vent fan to the recirculate direction because we do not have a vent duct that exits the house over our range. When the vent fan acting as the ovens cooling fan automatically turned on we would have to leave the house to hear each other talk. Too bad we really liked the oven other than that major problem. G-Man
Apr 19, 2009 | GE Profile Spacemaker Over-the-Range...
GE True Temp Profile Oven, Locked Door Light stuck on
there should be some type of button that the door hits to turn it on and off
Mar 24, 2009 | GE Profile JTP18 Electric Single Oven
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
177 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
