Question about Seagull Scientific Systems Barcode Software Bartender Basic Edition (BT32-BSC) for PC
Bartender error 1402 - Seagull Scientific Systems Barcode Software Bartender Basic Edition (BT32-BSC) for PC
Code activation
only the manufacturer can help you with any codes associated with their program
Oct 21, 2013 | Seagull Scientific Systems BarTender...
IPod touch error 1402
Well first of the battery is most likely defective, replace that and try again.
Jun 24, 2017 | Apple Audio Players & Recorders
Error 1402.Setup cannot open the registry kaey. HKEY_LOCAL_MACHINE\Software\Classes\CLSID\{7EA9A8FA-F5D2-49E1-99E8-C26EE07FCEEB}\LocalServer32.
The first thing you should do to fix this error is - if you're using Windows 98 or 2000 - to use the 'registry checker' facility. This is done by loading up the "Run Console" with CTRL + R and then typing "registry checker". If the registry is intact then this will not be a problem. On later versions of Windows, you should use a 'registry cleaner' program to perform this task.
If you have XP, Vista or Windows 7, you should first download a registry cleaner from the Internet and let that scan your system. It will look for any registry errors on your PC and then fix them, which should fix the 1402 error in the process. To use one of these, you need to download a registry scanner program and then let it scan your PC. It will identify all the damaged parts of Windows and should fix them. And if one of these registry errors is causing the 1402 error then a quick restart after the registry scan should enable you to install Office or the program you wanted.
If that method did not work, you should try using a different user account, or creating a new user account, to install the program onto. It's often the case that user accounts will become corrupted for whatever reason, blocking access to the registry. This causes the 1402 error because it means that the program cannot access the files and settings it needs to create when it's being installed. You should try creating a new administrator account and then installing the program on that.
Jun 08, 2011 | Microsoft Windows XP Professional With...
Error 1402
Hi Glenn,
As you have not mentioned the operating system that your are using. I suggest that you visit the below support website. The site has different steps to resolve issues occuring in ME/XP/98 and Vista.
If you find the information useful, please grade my answer
Apr 05, 2010 | Computers & Internet
Can't install adobe reader 9.1 - Error 1402
Hai,
Error 1402 Could not open key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run.
Verify that you have sufficient access to that key, or
contact you support personnel.
They are using Windows XP Home edition. I fear that they
have one to many viruses/ spyware apps on the machine
already and it may just be time to re-install the OS, but
wanted to make sure this was not something that someone had
ran into before...
Thanks
Jaggu
Sep 19, 2009 | Adobe Computers & Internet
Hi there! I work with Zebra TLP2844 through
If you are using Bartender, Make sure to use the Seagull Scientific Zebra Driver. The zebra driver works (but not properly) with bartender. Download the driver from Seagull Scientific site. You can also email bartender tech support, their contact details are available from the help screen on the main bartender design screen. I have always found them to be extremely knowledgeable and helpful.
Jul 01, 2009 | Zebra LP 2844 Thermal Printer
Zebra Z4m+ won't print from Bartender 9.01
BarTender uses its own drivers for each model of printer you must install the correct driver, because there are differences in some commands a printer to another.
Mar 09, 2009 | Zebra Z4MPlus Printer
Bartender 5.40 software returns "cannot find Hard Lock Driver"
This may be du to problem from your alladin driver. the key is not recognised. Dwnload a new driver from alladin and try again
Jan 19, 2009 | Seagull Scientific Systems BarTender...
HP PSC 1402 All-in-One Printer
I HAVE (HP PSC 1402 ALL IN ONE PRINTER
THERE R ONE AED IS BLINKING THIS LED IS MESSAGES IS "CHECK PRINT CARTRIDGE ERROR , BUT I N CHANGE MY PRINT CARTRIDGE PLEASE HELP ME WHATS MY PRINTER PROBLEM
Nov 28, 2008 | Office Equipment & Supplies
Hp psc 1210 all in one problem
Hey Neddy I found you on the HP site thius link, it explains how to fix your problem follow this instructions, they are pretty simple and Good luck http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=bpy21098&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Sep 02, 2007 | HP PSC 1210 All-In-One InkJet Printer
Seagull Scientific Systems Barcode Software Bartender Basic Edition (BT32-BSC) for PC Logo
78 people viewed this question
Top Seagull Scientific Systems Computers & Internet Experts
pkwc
ray gallant
Dan Shibata
Dan Shibata
Are you a Seagull Scientific Systems Computer and Internet Expert? Answer questions, earn points and help others
