Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi tv repair
After about 15 minutes, the colors reverse
    Top Expert:
  • Mitsubishi Master
  • 74,251 Answers
If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2400 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. Your problem post haven't enough details to provide a solution.http://electronicshelponline.blogspot.com/
Posted on May 02, 2013
Our Mitsubishi rear projection TV model VS-60707 keeps turning itself off. it is like it overheated cuz it comes back on after about 15 to 30 minutes being off, it comes back on by itself.
Called a repair man, he adjusted the convergence, with a remote for Mitsubishi. (I lost mine years ago). He thinks that is what was causing the TV to turn off. Time will tell if that cured it.
Dec 07, 2009 | Mitsubishi Televison & Video
DLP TV - After warm up - colors smear
Did you ever figure the problem out? My TV is doing the same thing.
May 11, 2009 | Mitsubishi WD-73927 73" HDTV
After a few minutes the color goes to intense red and green
My tv didn't turn green, but the red separated significantly. It started off happening after a few minutes of being on (I suppose the defective part was "warming up"), then it got to where it was like that immediately upon turning the tv on. In my case, I had to pay a tv repair man $350 for a new part. There are 2 microcircuits that control the color alignment--one that controls the red only, and the other controlls the other 2 colors, blue and green I believe. Maybe your part is the blue/green controller, mine was red. The repair man said these parts fail so rarely they don't stock the part. The cost of repair may be different for a different part, but either way you have to choose if it's worth that cost to you. If you get rid of it, I'll buy your tv stand ;-), I bought mine from a friend and didn't get the stand in the deal.
Dec 14, 2008 | Mitsubishi WT-42315 42" TV
Mitsubishi 1080p 73'' DLP HDTV - Color distortion
This would be the little sensor on the light wheel. Its cheap, you can get them online for around $2. You will need to take the light engine out and remove the color wheel cover and remove the color wheel and then remove the sensor. You will have to desolder the sensor and remove it to replace with the new one.
What is happening is the sensor is overheating and not tracking the color wheel properly there for the colors get messed up. Once you replace the sensor the tv should work like normal. The part is
(Sharp GP2S40 Photointerrupter). It is very difficult to find because they are not made anymore. Most major online part stores do not carry them but I found a lot of them at Wright Hobbies. Good luck.
Nov 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS 50805/60805 blue/yellow shadows on screen
Ok try turning the tv of for 40 minutes by the power point and back on. that way it will reset picture - and should go back to normal please let me now how this goes ((By a rating
Make sure you un plugged it by the power point for the 40 minutes
also make sure there is no speakers or anything magnetic within 60cm's of the tv this can also cause the picture to have strange colors in the screen - if that happens simple do the above
Aug 17, 2008 | Mitsubishi WS-55807 TV
32F531T color tv loses color after about 15 minutes.
the crt socket of your tvhas a problem,coldsolder the board of your crt socket,if not working replace the crt socket.
Apr 21, 2008 | RCA 32F531T 32" TV
IS THIS TV PLAYING OUT
Color separation is called convergence mis-alignment......that
problem can be repaired...............Blurry,darker when cold may
be a bit of difficulty..............Have a skilled tech give it a look.....T.
Nov 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Tv shuts off
When you let it sit for approx. 15 minutes it will come back on and usually stay on. I've also noticed that the color will fade in and out at times. during 15 mts of your sitting do you get sound & less brightness then problem in video or luminance section. if picture is dim & color will fade in and out at times then possibility of crt is getting less voltage on g2. if set is old then there is a possibility of crt getting weak. but if the above things are not there then problem in power supply. good luck
Sep 22, 2007 | Mitsubishi VS-55707 TV
Problem with color
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
Jun 05, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
