Question about Tools & Hardware - Others
Engine brake - Tools & Hardware - Others
    Top Expert:
  • Tools & Hard... Master
  • 42,120 Answers
Come back with what engine and make of engine brake and fault description.
Posted on May 18, 2013
How does my engine brake work?
Engine brakes or Jacobs brake on diesel engines work by using engine oil pressure controlled by a electric solenoid in three stages, the oil pressure is directed to a piston which holds down an exhaust valve slightly approx 2.85-3.5mm.
The three stages of exhaust brake on a six cilinder engine activates two cylinders at a time, cylinders 1-2 stage one, cylinders 1-2-3-4 stage two, and 1-2-3-4-5-6 stage three.
A Volvo engine brass or VEB works kind of the same only it uses a separate lobe on the camshaft to open the valve for engine braking...
Hope this helps..
Feb 05, 2016 | 2013 Suzuki Grand Vitara
Engine shuts off when brake is released
That's better with spaces.
The engine is not connected to the brakes. The only electrical item on the brakes is the brake light. The brake light is not connected to the engine. When the brake light turns off, why would it stop the engine?
So in my mind, the two are not connected. For weird things like this, you have to visit a dealer who is an expert with your make and model of car.
Oct 16, 2015 | Cars & Trucks
What would cause engine yo die at a stop light and not start again. The engine almost turns over but doesnt.
engines stopping at lights can sometimes be attributed to a vacuum leak in the brake booster
test by idling the engine with the hand brake on and no foot brake then apply the foot brake and if the engine dies then it is the brake booster
hard to restart may be the vacuum leak if you still have your foot on the brake.
May 12, 2015 | Cars & Trucks
Step by step instructions for replacing brake booster on a 1999 Toyota Camry
its my pleasure to answer your question how to replace the brake booster :
1 With the engine off, step on the brake pedal several times to relieve the brake booster of vacuum.
2 Press the brake pedal down and start the engine. Verify that the brake pedal sinks slightly. Turn off engine.
3 Remove the vacuum hose from the brake booster.
4 Remove the brake lines from the master cylinder. Remove the master cylinder from the brake booster. Plug the fittings to prevent brake fluid seepage.
5 Disconnect the brake pedal from the push rod.
6 Have an assistant hold the brake booster from inside the engine compartment. Remove the nuts that hold the brake booster to the firewall. These nuts are usually located under the dash on the interior of the firewall.
7 Remove the brake booster.
8 Install the new brake booster to the firewall. Tighten the mounting nuts.
9 Connect the push rod to the brake pedal.
10 Connect the vacuum hose to the brake booster.
11 Attach the master cylinder to the new brake booster and reconnect the brake lines.
.12 Bleed the brakes at the master cylinder.
Oct 04, 2013 | Cars & Trucks
How to remove brake booster on 1999 Toyota Camry
The following steps will help you to replace a Toyota Camry brake booster :
How do i replace the brake booster on a 98 Mercury villager
12 specific steps will help you :
10 Connect the vacuum hose to the vacuum brake booster.
Sep 24, 2013 | Cars & Trucks
NO BRAKES WHEN ENGINE IS RUNNING
Brakes and engine are totaly diferent systems. Do you have brakes when engine is off? If so the only conection between engine and brakes could be vacume which is created by the engine stored in the chamber at the master cylinder to assist with brakes but does not overide personal brake presure only help increase braking. If trully you have less breaking preasure with the engine running then check the vacume line at the master cylinder to see if there is a vacume or maybe preasure?
Sep 18, 2012 | 1993 Plymouth Acclaim
Engine Brake does not work properly
master cylinder run out of oil, foul up and bleed 2 front wheels first and the rear after top up oil every time.
Aug 19, 2012 | Nissan Vehicle Parts & Accessories
Engine brake not working
Engine brake light.// Can be low oil on master cylinder or brake pad low/ LOW pressure in the system it has to be check by mechanic for your safety.
Engine increases rpm when brake pedal is depressed
Inspect brake booster vacuum line from engine intake to brake booster for leaks also inspect brake booster check valve, more than likely your brake booster is causing a vacuum leak to your Intake thus leaning mixture wich increases idle rpm
Apr 03, 2010 | 1990 Toyota Pickup
Tools & Hardware - Others Logo
19 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
