Question about Whirlpool Lasco 7460621R Dossi-32 , White
Lasco bathware stoppers
How do I remove the drain plug
My jets are humming In the lasco luxury bathware how do I fix
The humming suggests that the pump is running but something is clogging it. You will have get access to the pump and probably do some disassembly to isolate the cause and correct it.
Jan 26, 2015 | Home
How to remove bath tub pop-up stoppers
Put the lever in the open position so that you can grab the stopper. After you get a grip on it, put the lever in the closed position and the drain plug and rocker assembly will pull out in a horizontal direction.
Sep 25, 2014 | American Standard 1583.470.020 Universal...
Clogged drain on moen bathroom sink
There should be a stopper valve on the sink's downspout (the first section of drain pipe). You SHOULD be able to loosen the nut holding the stopper valve's lever inside the pipe. Once you remove that nut, you can pull the lever out - that releases the stopper inside the sink, so you should start with the stopper OPEN, and hold it open with a chopstick or pencil or other tool when you remove that lever.
The lever and the bottom of the stopper itself will be wrapped with masses of hair. That's normal. Clean it up and reinsert it, put the nut back on & snug it down, then readjust the stopper.
If that's not enough, you may need to open the trap (the gooseneck-shaped piece of drain pipe under the sink) to clean it out.
Apr 05, 2014 | Moen Tub Drain Assembly, Lift-N-Drain -...
Grohe drain stopper installation
Try cleaning drain with a length of wire. Strip insulation back about an inch. Turn exposed wire back to form a hook and put down drain and spin, then remove from drain, repeat until hook comes out fairly
clean. Then put drain cleaner down drain, follow instructions with drain cleaner. This should remove gunk that is preventing stopper from working correctly.
Jan 20, 2014 | Plumbing
Where do I buy Moen 14627 drain plug
LASCO part number 03-4647L will replace Moen 14627. You can get it from Amazon. I just verified 8/6/13 with the manufacturer that the diameter of the chrome cap is 1 1/4 inches, same as the original Moen stopper and the 4 7/8 inch length is correct also. Looks like it may also replace Moen part 12314.
Mar 18, 2013 | Moen Home
After one year of usage my portable A/C drains on the floor approximately 3pint / hr. Unit was raised so that the water can drain into a container without weting the carpet . This situation needs to be...
This is what the manual says:
When the internal water container is full, the back light on the LCD display flashes. The unit will shut off automatically, beep 15 times, and must be drained before it will restart.
To Drain the Unit: switch off the unit and remove the plug from the wall socket.
• DO NOT MOVE THE UNIT. Doing this can result in water
leakage, damaging your floor or carpet.
• Place the drain pan on the floor under the drain cap.
• Remove the drain cap and the rubber stopper from the
drain, and let the water run out. Partially fill the drain pan,
replace the rubber stopper, and empty the drain pan.
This procedure must be repeated until the unit is empty.
• Replace the rubber stopper and drain cap.
Put plug into the wall socket, and switch the unit on.
The warning signal should be off.
For Continuous Drainage: • Switch off the unit and remove the plug from the electrical outlet.
• Remove the Drain Cap and Rubber Stopper. Drain if necessary.
• Connect a Drain Tube (not included) (20mm / 3/4" inner dimension) on to the water outlet.
• Place the other end in a drain. Make sure the tube is free from twists and bends.
The tube must decline over its entire length.
Jun 06, 2011 | Amcor PLM12000E Portable Air Conditioner
How does the lift and turn stopper come out so we can clean plugged drain?
  • Push the stopper down to fully seal the stopper against the tub drain.
  • 2
    Turn the knob on top of the stopper counterclockwise with your fingers. Do not lift the stopper while turning the knob. Remove the knob from the stopper.
  • 3
    Insert a large flathead screwdriver into the slot on the center shaft of the stopper. You will see the center shaft when you remove the knob. Turn the shaft counterclockwise to unthread it from the retaining hole in the bathtub drain basket.
  • 4
    Use a pair of vise-grip pliers to turn the shaft if the center hole has corrosion and will not accept a screwdriver. Lock the jaws of the pliers securely around the shaft, and turn the shaft counterclockwise.
  • 5
    Pull the stopper out of the tub by lifting it by the shaft.
  • Mar 12, 2011 | Maax Soprano II: One-Piece Shower Module...
    I am trying to use a plunger in a slow drain. bathroom lav. The pop-up valve stopper is in the way of my plunger. the Pop-up valve is a Price- Pfister. My past experience with other older pop-up valves has...
    Some of the drain plugs have holes or slots in them so that the stopper can not be removed without taking the actulating lever out from under the sink. This rod is part of the linkage that is hooked to lift rod on top, Unscrew retaining nut to remove rod so you can take stopper out. Remember that any water that is in sink is going to run out of this hole once you remove rod. Good luck and thank you.
    Feb 21, 2011 | Price Pfister 47 Series, Lavatory Drain...
    I have akohler bath drain that seals/drains simply by pushing down on the gasketed spring-loaded chrome stopper. The drain is clogged with hair but I can not figure out how to remove it and snake the...
    Toe tap stoppers remove by just gripping the stopper and unscrewing it. Once the stopper has been removed the hair will be usually caught on the crossbar underneath the stopper where it can be removed with needlenose pliers.
    Spring type stoppers for drains are just about as notorious for being hair catchers. Once again there is nothing to stop the hair from leaving the tub.
    May 21, 2010 | Plumbing
    Whirlpool Lasco 7460621R Dossi-32 , White Logo
    122 people viewed this question
    Top Whirlpool Home Experts
    Donni Steen
    john h
    Mike
    Are you a Whirlpool Home Expert? Answer questions, earn points and help others
