Question about DeLonghi A120E Air Conditioner
What would be the reason it leaks water
  • 499 Answers
Just as a cold can of soda condenses the moisture in the air as it contacts the cold surface, so does an Air conditioner, it is part of the "conditioning" not simply temperature reduction. As you may know in New York city for example 95F is a heat stroke warning temperature if the humidity is very high, Miami beach is also very humid, humidity affects the comfort level at a given temperature tremendously.
Posted on Jun 07, 2014
How can I fix a leaking valve in the water heater. For some reason, a genius decided to put a plastic valve and now it has a slow leak.
sorry but many genius people put in Plastic valves because they work much better than the old types but when we do they need to be made so they can be quickly replaced with unions also .
Nov 10, 2015 | Water Water Heaters
How to fix a kenmore ice maker leaking water
Refrigerator Leaking From Icemaker
If it's leaking from inside the freezer then it's coming from the icemaker or the drain. Lets start with the icemaker. If it's the icemaker there will likely be an ice hanging from the icemaker or just a big block of ice in the ice bin. In any case, it will be obvious.
There are a few reasons this will happen: one is the icemaker will stop turning when it gets to the fill cycle. This will happen when the gears in the icemaker break. On GE icemakers that were made before the year 2000, you can see the gears by taking off the cover on the front of the icemaker. However, if the small gear is broke you can't buy it as far as I know. I have been taking them off of junk icemakers for years. So this part may be hard to find. But if the big gear is broke replace it. Another reason icemakers leak is the fill tube is stopped up and I already discussed this earlier (replace water valve and clean out tube).
Another reason icemakers leak is that the water comes in too fast so it over fills the first cube mold. When this happens you will get a few drops of water when it fills. To fix this you have to take the icemaker out and remove the piece on the side of the icemaker. I don't know the name of it so for this we'll call it cube separator because that's what it does (most of them just snap off others have a screws). Now take silicone (RTV) and put a small amount around the first cube mold only under the cube separator. Now reinstall the cube separator and wipe off excess silicone and it shouldn't leak anymore.
Another reason that icemakers leak is that the refrigerator water valve sticks after the icemaker goes out of the fill cycle. When this happens the valve stays on and the icemaker keeps on turning, in which case, replace the refrigerator water valve.
Feb 20, 2015 | Kenmore Refrigerators
How do i do when the indoor unit start water leaking non stop??
Water leaking depends on 18 reasons. Plz let me be cleared that voltage, amphs, gas pressurer, indoor motor condition, cleanliness of the indoor evaporator coil., etc.
Sep 20, 2014 | Heating & Cooling
Ice maker leaking water
Jul 14, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
My water outlet cap popped off and its leaking water and the water that stays boils. Should i replace my water pump 2003 dodge intrepid se 2.7
replace the cap--is the radiator damaged? No reason to replace the water pump. Boiling is caused by leak, faulty thermostat, clogged radiator, or head gasket.
Aug 22, 2010 | 2003 Dodge Intrepid
My whirlpool wtw5500sq0 leaks water when washing
There can be many causes for this leak, and where it leaks helps diagnose what to fix. Most commonly the water pump leaks from its seal and bushing over time since it spins whenever the motor is engaged. The reason it never spins water out until the spin cycle engages is because it is turning in the opposite direction as flow to prevent water running out as you wash, You way also have a separation of the washtubs water ring, or a crack near the top, since the leak only happens during wash time.
Mar 18, 2010 | Washing Machines
The water dispenser leaks
The most likely reason for the leaking at the water dispenser is the dual water control valve on the back and near floor is leaking water while shut off. The only option is to replace the water control valve. Sea Breeze
Aug 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking from bottom of washer
Tub Seal is leaking and needs to be replaced
Jun 11, 2009 | Washing Machines
Water leaking during drain and spin
Hi!
You Need to check the following--
The fill hoses : These are located behind the washer and are connected to the water mixing valve and faucets. Pin holes and cracks on the hoses may cause them to leak.
The water valve: The water mixing valve is located behind the washer. The fill hoses connect to the water mixing valve. Inside of the valve is that the water gets directed to the filling spout. Water leaks happens when the valve develop pin holes or cracks. Bad fill hoses or water valve could be the reason why the washer is leaking water.
The Filling spout: Is just a directing part, this part directs the water from the water valve to the tank. Pin holes and cracks is what make this part to leak.
The tank : The major cause for the tank to leak is through holes or cracks that the tank develops because of vibration or metal items hitting the tank during the spin cycle.
The tub seal : The tub seal is made of rubber, it is connected between the transmission post and the center of the tank. Leaks developed when the seal gets worn out and it looses the ability to make a good seal between the transmission and the tank. A crack tank or worn out tub seal could be the reason why the washer is leaking water.
The overflow tube : This tube is use to direct the water away from any electrical parts like the motor in case of an overflow cause by a bad water mixing valve or bad water level switch.
The pump : The pump job is to remove the water from the tank to the drain pipe. This pump has an electric motor and an impeller. When the pump motor is turning, any water that falls in to the impeller, is push out to the drain pipe.
Most leaks are cause by a worn out seal between the front pump housing and the rear one.
The drain hose : The drain hose is made of hard plastic and some times it develops pin holes and cracks leaks. Bad pump or drain hose could be the reason why the washer is leaking water.
Thanks for using FixYa and do rate the solution as Fixya if found helpful.
Rylee
Apr 03, 2009 | GE Washing Machines
DeLonghi A120E Air Conditioner Logo
136 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
