Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
34788 calibrate is there a procedure/method to verify the unit is pulling the set amount into the vehicle in a manufacturing environment?
  • Robinair Master
  • 16,210 Answers
What is the reasoning behind this?
Posted on May 06, 2013
Robinair 34788 keeps overcharging the isv how do i fix this issue or how do i find out whats wrong
Robinair 34788 Set Up Operation Part #1 - YouTube
? 6:05
www.youtube.com/watch?v=XW8o5tahLpE
Aug 30, 2013 - Uploaded by OTC TOOLS This video takes the viewer through the entire Set Up and Operation of the 34788. The Cool-Tech 34788 ...
Aug 26, 2015 | Robinair Measuring Tools & Sensors
How to remove dash panel to replace climate control panel
  1. Remove the instrument panel accessory trim plate around the control panel by prying gently and then pulling it straight out.
  2. Remove the control panel mounting screws.
  3. Pull the control panel straight out from the instrument panel.
  4. Disconnect the electrical connectors.
  5. Installation is the reverse order of removal.
  6. After installation, the actuators must be calibrated. For additional information, refer to the following section, -Actuator Calibration.-
  8. Fig. Remove the screw and pull the control panel straight out of the instrument panel.
To calibrate the system:
  1. Place the ignition switch to the OFF position.
  2. Install the HVAC control module.
  3. Connect all previously disconnected components.
  4. Start the vehicle.
  5. Wait 40 seconds for the HVAC control module to self-calibrate.
  6. Verify that no DTCs have set as current DTCs.
  7. Place the ignition switch to the OFF position.
  8. With the Mode knob in the PANEL position, press and hold the AC button for 5 seconds.
  9. Rotate the Mode knob fully counterclockwise.
  10. Rotate the Mode knob fully clockwise.
  11. Rotate the Mode knob fully counterclockwise.
  12. Release the AC button.
  13. Wait 40 seconds for the HVAC control module to self-calibrate.
  14. Start the vehicle.
Sep 14, 2011 | 2001 Oldsmobile Silhouette
Power steering
Hello Mohamede.
Not sure what your question is here.
I will post a couple of common issues with the Elantra steering problems.
Hopefully one of these following problems will assist you.
1. SERVICE TIP - POWER STEERING OIL PUMP WHINE NOISE DESCRIPTION:
Before replacing a power steering oil pump for a "whine" noise condition, check the oil pump reservoir filter screen for contamination. If the filter screen at the bottom of the oil pump reservoir is clogged, it may cause the pump to aerate and cause a "whine" noise.
If the filter screen is clogged, replace the reservoir and reconfirm the condition.
2.Subject
ABSOLUTE STEERING POSITION (ASP) CALIBRATION FOR ELECTRIC POWER STEERING (EPS) DESCRIPTION:
This bulletin provides the Absolute Steering Position (ASP) calibration method for 2007-2009 ELANTRA (HD) and 2009 ELANTRA TOURING (FD) Electric Power Steering (EPS or Motor-Driven Power Steering). This procedure is required when the battery is discharged or after the battery or EPS-related parts are replaced.
NOTE:
If the EPS ASP calibration is not conducted when the battery is discharged or after the battery or EPS-related parts are replaced, the EPS and or Electronic Stability Control (ESC) warning lamp will be turned on and the automatic EPS return-to-center control will not be performed. VEHICLES AFFECTED:
Model: 2007-2010 ELANTRA (HD), 2009-2010 ELANTRA TOURING (FD)
3. Subject:
DIAGNOSIS AND CORRECTION OF VEHICLE PULL This bulletin supersedes TSB 05-50-012 to include 2009 models
DESCRIPTION:
Several factors may cause vehicle pull, both vehicle related and external conditions. The purpose of this bulletin is to assist in identifying the vehicle related conditions that cause pull and how to correct those conditions.
CAUSES OF VEHICLE PULL:
Vehicle pull is the tendency of the vehicle to drift right or left while driving in a straight ahead direction on a straight road at a constant speed with no pressure on the steering wheel. This pull or drift may be gradual and can always be compensated for by inputs through the steering wheel. One or more of the following conditions may cause the vehicle to pull:
Non-vehicle conditions that may cause the vehicle to pull:
^ Cambered road surfaces - Most highways are built with cambered or "crowned" surfaces to drain rain water. Sometimes the road camber is visually noticeable. Other times, it is not. The vehicle may tend to pull to the left or right, depending on the camber of the road surface. ^ Cross-winds - A sometimes overlooked, yet possible cause of steering drift is cross-winds. Side winds at higher vehicle speeds may cause vehicle pull. Please do not rule out cross-winds when diagnosing a vehicle pull. Vehicle pull caused by these two conditions is not related to vehicle adjustments and no repair should be made.
Vehicle conditions that may cause the vehicle to pull:
^ Tire inflation pressure - As small as a 2 pounds/square inch tire inflation pressure difference between the right and left tires may cause a vehicle to pull. Be sure to check the tire pressure before the tires are warmed up prior to attempting more extensive diagnosis. ^ Wheel alignment - Slightly out of specification wheel alignment causes very few vehicles to pull. Therefore, if the vehicle wheel alignment has been adjusted as close as possible to specification, DO NOT attempt to correct the vehicle pull by changing the wheel alignment angles by bending suspension components or other non-approved methods. ^ Uneven brake adjustment - If one of the four brakes is dragging, the vehicle may pull to the side of the dragging brake. Verify that none of the brakes are dragging and that they are adjusted correctly prior to attempting more extensive diagnosis. ^ Incorrect vehicle trim height - If the trim height of the vehicle is not equal on all sides, the vehicle may pull to the side of the lower trim height. Check and adjust the trim height of the vehicle as necessary. Please note that a slight variation in the vehicle trim height seldom causes a noticeable vehicle pull.
^ Tire construction - The way in which the tire is built can produce vehicle pull. An example of this is the placement of the under tread belt. An off-center radial tire belt can cause the tire to develop a side force while rolling straight down the road and the tire will tend to roll like a cone. To correct this condition, please use the flow chart. This chart provides the sequence of procedures designed to be performed for all conditions of vehicle pull. ^ Tire size - Different size tires or different make of tires, on either axles, may cause a vehicle pull.
Nov 14, 2010 | 2007 Hyundai Elantra Limited Sedan
Had the battery changed, but now the (heat) vents in the top of the van and the floor vent (heat) does not work - only cold air comes out. Also, the heating/cooling dial lets it get hot midway on cold...
Try this calibration procedure and let us know if you have more questions:
  1. Start the vehicle.
  2. Wait 40 seconds for the HVAC control module to self-calibrate.
  3. Verify that no DTCs have set as current DTCs.
  4. Clear all DTCs.
  5. Place the ignition switch to the OFF position.
  6. With the Mode knob in the PANEL position, press and hold the AC button for 5 seconds.
  7. Rotate the Mode knob fully counterclockwise.
  8. Rotate the Mode knob fully clockwise.
  10. Release the AC button.
  11. Wait 40 seconds for the HVAC control module to self-calibrate.
  12. Start the vehicle.
  13. Verify that no DTCs have set as current DTCs.
Nov 14, 2010 | 2005 Pontiac Montana SV6
Compass direction wrong
Compass Calibration
Before calibrating the compass, drive the vehicle to an area that is magnetically clean or free of large metallic objects. Verify there are no magnetized objects on the inside or outside of the vehicle close to the mirror.
Start the engine.
Press and hold the switch for the compass, which may be depicted as COMP, COMPASS, or On/Off (w/UE1) depending on the type of mirror on the vehicle, until the letter "C" or "CAL" is displayed.
Drive the vehicle in circles at a speed of less than 8 km/h (5 mph) until the "C" or "CAL" is replaced by a proper vehicle heading. The calibration procedure is now complete.
Compass Magnetic Variation Adjustment
Magnetic variation adjustments are required when the compass displays a constant error in heading. Variation is the difference between magnetic north and true north due to geographical location.
Nov 09, 2010 | 2004 GMC Envoy
Robinair 34788 not pulling a vacuum
It's seems to be problem with your unit relay board,vacuum pump or pressure transducer.Most of Robin air 34788 machine having same problem.You can try as follows 1# Open vacuum pump oil filling cap to release extra pressure from pump.2# Replace new relay board & follow the on screen message(do not skip any option).3# Check pressure transducer is working properly.I hope this will help you.
Jun 06, 2009 | Robinair Cool Tech 34700Z Recovery,...
1996 Ford Crown Victoria Shifting
when was the last time you had the fluid and filter changed? This trans should be done every 30,000. Is it shuddering as the torque converter locks up?
TSB 97-10-6 has a repair procedure for this ysmptom:
Vehicles equipped with an AODE or 4R70W transmission may experience a torque converter clutch shudder or vibration. This occurs under light to moderate acceleration above 56 km/h (35 mph) while in 3rd or 4th gear. This may be due to either transmission fluid breakdown and/or the Powertrain Control Module (PCM) calibration.
Verify that bulk fluid does not have moisture contamination. If suspected, use quart containers of MERCON®. Refill transmission with the proper amount of Motorcraft MERCON® Multi-Purpose Automatic Transmission Fluid (ATF) (XT-2-QDX).
NOTE: DO NOT USE MERCON® V.
Check emissions decal to verify vehicle has the latest calibration. If it does not, reprogram the PCM to new calibration level using Service Bay Diagnostic System (SBDS) or New Generation Star (NGS) Tester with May 1997 CD-ROM or later. Refer to the PCM Calibration Chart found at the end of this article for proper application.
NOTE: VEHICLES SHOULD BE DRIVEN A MINIMUM OF 480 km (300 MILES) TO WORK THE NEW FLUID INTO FRICTION MATERIAL.
PCM CALIBRATION CHART Application Old Calibration Old Part Number (-12A650-) New Calibration New Part Number (-12A650-) 1996 Crown Victoria/Grand Marquis 49S/Canada/High Altitude 6-18F-R05/R11 F6AF-AE 6-18F-R11 F6PZ-DJA 49S/Canada/High Altitude 6-18H-R05/R11 F6AF-BE 6-18H-R11 F6PZ-DKA Mexico 6-18H-R05/R11 F6AF-KE 6-18H-R11 F6PZ-DMA Police 6-18I-R05/R12 F6AF-CF 6-18I-R12 F6PZ-DLA California 6-18M-R05/R11 F6AF-DE 6-18M-R11 F6PZ-DNA California 6-18N-R05/R11 F6AF-EE 6-18N-R11 F6PZ-DPA
Mar 02, 2009 | 1996 Ford Crown Victoria
I have a 2003 jimmy that blows very little heat at level 4
It sounds like it could be the control panel or the A/C And Heater Control Calibration you can give this info to your mechanic... but if i were you i would go to gm dealer.replacing the wrong part will get expensive fast..... hopes this helps you..........................................A/C And Heater Control Calibration
Re-Calibrating Actuators (Primary)
When replacing the HVAC control module it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC control module be sure to perform the following:Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result.
  2. Disconnect the scan tool.
  3. Install the HVAC control module.
  4. Connect all previously disconnected components.
  5. Start the vehicle.
  6. Wait 40 seconds for the HVAC control module to self-calibrate.
  7. Verify that no DTCs have set as current DTCs.
When replacing the HVAC actuator it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC actuator be sure to perform one of the following:Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted improper HVAC performance will result.
Alternate Method (W/O Scan Tool)
  1. Clear all DTCs.
  2. Place the ignition switch to the OFF position.
  3. Install the HVAC actuator.
  5. Remove the HVAC B fuse for a minimum of 10 seconds.
  6. Install the HVAC B fuse.
  7. Start the vehicle.
  8. Wait 40 seconds for the HVAC control module to self-calibrate.
  9. Verify that no DTCs have set as current DTCs.
Preferred Method (W/ Scan Tool)
  1. Clear all DTCs.
  2. Place the ignition switch in the OFF position.
  6. With the scan tool, initiate the Motor Re-calibration feature of the Heating and Air Conditioning Special Functions menu.
Dec 29, 2008 | 2001 GMC Jimmy
Compass out of whack
You need to recalibrate the compass. The procedure is in your owners manual. Here are the basic steps.
First, you will need to verify that your compass zone is set to your current geographic location. Since I do not know where you are located, I cannot tell you the code. They are listed in the manual. (For example, So Cal is zone 5.)
Second, here is the compass calibration adjustment procedure:
Perform this adjustment in an open area free from steel structures and high voltage lines. For optimum calibration, turn off all electrical accessories (heater/air conditioning, wipers, etc.) and make sure all vehicle doors are shut.
2. To enter the compass calibration mode, press and hold the button for greater than eight seconds. The display will then show CAL in the display window.
3. Drive the vehicle slowly (less than 3 mph) in circles until CAL indicator turns off. As many as 5 complete circles may be required.
4. The compass is now calibrated.
Dec 19, 2008 | 2005 Ford F-150
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
133 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
