Just two speakers working when i connect it to tv
    Top Expert:
  • Televison & ... Master
  • 74,377 Answers
How many speakers are there in your TV? What is the brand name and model number? Provide more details please.
Posted on May 02, 2013
Internal speakers won't turn off when external audio is connected
Normally , you would expect the TV sound to stop when headphones are plugged in. Obviously not in this case. If you have a set of headphones, try them and see if the TV still has speakers on. If it does, then there may be a setting on the setup of the TV to get headphones to work. If the TV speakers stop, then I would think that the Logitech are not compatible with the TV. The only other thing would be is to get into the TV and disconnect the TV,s own speakers. If the wires are soldered on and not terminal connected, carefully cut 1 of the wires off near the speaker. If 1 wire is cut, the speaker wont work. Make sure both the TV and the additional speakers (If they have their own power supply) you are using are unplugged from the power before you go doing this...!
May 26, 2015 | Haier L32F1120 32-Inch LCD TV 720p 32"
I have a 29" Philips TV model 29PT4824/94R. The
To make sure that the external speaker is good or deffective try to use others speaker.If the other speaker work it means that your speaker is deffective and if the other speaker not work it means that the problem is the sound output amplifier or driver of the TV.You need to check the inner part othe TV.The board of the TV inside at the sound section, just fallow the speaker wire to the board,that is the sound section.Check if theres a loose connection.
Jul 16, 2011 | Philips Televison & Video
Can these speakers be connected to a TV?
Hi there bud , Yes they can be , Just make sure you have a RCA converter , So you can connect it too your T.V then it should work perfect
Have a good one
Happy new year
Jan 07, 2010 | Creative Labs Inspire P7800 Computer...
Can the Boston BA 7900 be converter to use with TV or DVD Player?
Yes, but so far I can only get the 2 front speakers and subwoofer to work.
You need a wire that converts a headphone-style jack (like the green one with the Boston speakers) into a red and white AV connection (typical CD/DVD, etc. connection). I've had this connector for a long time and I'm guessing it's under $15. You connect the green Boston speaker connection to the converter end (mine connects to the back end of the headphone-jack (which has a hole for the connection) and the red/white AV connectors to your TV.
I'd been trying to solve the problem too for a long time. Only problem is that I can't get all 5 speakers to work because I think the red/white connector doesn't work with all 5 speakers. I have yet to figure out how to make all 5 work, but the system gives great sound anyway. You will have something like a 5.1 system with your computer speakers, the Boston speakers and subwoofers.
One more issue is that if you connect it directly to the TV, you have to manually turn the Boston speakers on and off.
Nov 06, 2009 | Boston Acoustics BA7900 Computer Speakers
I have a panosonic plasma tv when i switch it on it tell me there is a speaker short and then switches it self of model number pdp507xda help
It's the internal circuitry problem. Try muting it and put audio connection to other speakers if it repeats, your TV audio system is internally dying.the audio connections has to be checked and faulty components should be replaced.
1. Speaker short.
Open it up and check the speaker connections. ONLY if you have basic skills working on electronics and don't have a warranty.
2. Sound Volume "Leveler"
Look in your sound option menu for a sound "balancer" option and turn it off.
If this doesn't work disable the sound and invest in that surround sound system (external speakers solution of your choice)
try this.for first unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out.if still the same problem then its quite possible that the capacitors and ic on the audio circuit board are getting short in between so the circuit is not getting completed and cutting in between so the tv starts and turns off. if the tv is connected to externalk speakers then check out without connecting the external speakers and see whether it works.if it works that means tv is perfect.but if tv is having inbuilt speakers that its confirm problem with inter audio circuit of tv.so try connecting external speakers at the back of tv and check out.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 20, 2009 | Panasonic PDP-428XDA 42 in. Plasma TV
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
One speaker has stopped working
It could be the cable connecting to the speaker, or the speaker itself. Try taking the cable that's connected to the left speaker and connecting it to the right speaker. If it works, the cable connected to your right speaker is defective, if it doesn't work - your speaker is.
Jan 10, 2008 | Toshiba 36A43 36" TV
Connecting a logicK TV LCX2 to a Yamaha Surround sound system YSP 1
Not entirely sure what the problem is. You should have Two RCA outputs (left and right) from the TV. These plug into the surround decoder, it decodes the dolby and provides 4 or more outputs for speakers. If I have misunderstood you then please comment before rating badly
Oct 07, 2007 | Televison & Video
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
