Question about Garden
String trimmer my 4-cycle string trimmer won't stay running after using for a few minutes it is brand new
  • 7,482 Answers
Hi robert
Posted on May 03, 2013
5 Suggested Answers
  • 16 Answers
SOURCE: troy bilt 4 cycle string trimmer wont stay running
If this is an old unit, then the diaphragm is probably hardened.
Tests before hand would be:
1. Is the gas fresh and water free?
2. Is the spark-plug clean and snugly fastened?
3. Are you using the correct gas to oil mix ratio in your fuel?
4. yes...yes...yes...= bad diaphragm. Probably less than $5 for the part and a 1/2 hour to replace the part.
Posted on Jul 07, 2009
  • 133 Answers
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Posted on Apr 21, 2010
  • 103 Answers
SOURCE: I have a Toro 4
check to make sure the air filter and the fuel screen are clean, the screen is the little white plastic piece on the end of the hose in the tank. if it is still sputtering try cleaning the bell out on the carb. it is the little metal cylinder on the bottom of the carb where it holds the fuel until it evaporates into the engine if it gets clogged the engine will not run properly.
Posted on Jun 30, 2011
Hobbit_who
  • 2044 Answers
SOURCE: My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Posted on Apr 08, 2013
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Sears & Craftsman 25cc Weedeater brand new starts but will not stay running?
Try leaving the chokey partially engaged. Operate it this way for a few minutes until the engine is thoroughly heated then move to the run position. If this does not work return it.
Aug 13, 2014 | Sears Craftsman Convertible 25cc 2 Cycle...
Apr 08, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
Won't start. String pull will not go more than a few inches. Engine seized?
Try the clutch. I just fixed this problem.One of the clutch springs ate it's way though the red housing where the spring for the pull start is at. When the housing came apart the engine seized and I couldn't move the pull start. For the schematic on the engine here is the web address http://www.searspartsdirect.com. Hope this helps.
Aug 20, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
Husgvarna string trimmer stahls.
Try getting some carb and choke cleaner and spraying down the carb. You might have some varnish in the carb and it won't let the fuel flow properly. My ryobi 4 cycle trimmer does that every year. I clean the carb and it usually runs decently.
Good luck
roundo4
Aug 09, 2009 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
