Fixya com Won't switch on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Televison & ... Master
  • 102,366 Answers
Could you provide some details, such as the make and model of the device that won't turn on?
Posted on May 01, 2013
Ice and water switch won't turn off
I went back into the files here and found a good bit of info, hope there's something to help! http://www.fixya.com/search/p45578-maytag_msd2756ges_side_by_side/button
Feb 16, 2013 | Maytag MSD2756GES Side by Side...
1994 toyota corolla brake lights won't turn off
Thanks for choosing FixYa and welcome. You need to check the brake switch. Your brake pedal contacts the brake switch when it is pressed down. There is a small button on the brake switch that activates the lights. It may be stuck or broke. Try to loosen the button first. If it won't, buy another one. They only cost a few dollars.
Sep 07, 2011 | 1994 Toyota Corolla
On/Off Switch is not working sometimes. Will start for a few cuts then won't start at all.
I dont have a steel clad answer for you ... consider this please: Depending on the cuts you are performing, your motor may ge 'going out' on over load (heat). The solution is to wait until the motor cools.
Thanks for your interest in FixYa.com
Sep 04, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
If the basket won't spin when you turn it on what
Their are two leading causes that will make the Whirlpool washer not spin, either the lid switch is defective or the motor coupling is broken. these 2 tips i wrote will explan how to check them and see which on it is.
MOTOR COUPLING http://www.fixya.com/support/r10293994-whirlpool_made_washer_not_agatating
LID SWITCH http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
Aug 31, 2011 | Whirlpool Washing Machines
Washer model#11092282100 won't drain or spin
The leading cause of the water not draining and the washer not spinning is going to a broken lid switch. This tip i wrote about the lid switch will explain how to check if its broken and also how to replace it. http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
The part number for the lid switch on your model# is 285671 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
repairclinic.com
apwagner.com
GENE
Aug 31, 2011 | Kenmore Washing Machines
I have a top loading Kenmore series 80 washer. The cycle starts, agitates, but won't drain and go into a spin mode. It just stops after the agitate is done and remain full of water. It won't...
This is usually a door closed switch that is either a bad Lid switch It is number 11 on the diagram on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024032301/0582/0153200/K0403014/00001?blt=06&prst=&shdMod=
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 12, 2011 | Kenmore 24032\24036 Top Load Washer
Key stuck in ignition but it will turn, and steering column won't lock and car won't start.
you most likely have a bad key switch cylinder assembly. you can try to spray wd40 solvent into the switch before you have the switch replaced,but sometimes it's a switch replacement that repairs the problem. have you inspected your ignition key to look for damage to the key itself? try a spare key to make sure it's the key,and not the key switch. you can also try turning the key while turning the steering wheel at the same time to get the key to work.sometimes the switch locks when parked in a bind,such as on a hill,or against a curb and so on. try this 1st before you have the ignition switch replaced. AAA auto club,if you're a member covers part of the replacement costs for a replacement switch also. you may have coverage through a cell phone also.one more thing to try, if you have a tilt steering column,try to reposition the steering wheel to see if you can get the key to turn. remember never force it enough to break your key off into the switch! thank you for choosing fixya.com!
May 13, 2011 | 2002 Chevrolet TrailBlazer
1993 gmc 1500 350cid - engine turns over but will not start. Fuel is good
Hello and welcome to FixYa!
If it's not turning over then the problem will be on the firing. If there's no current to the plugs, the engine won't fire up. Few things to look at to resolve the issue... First, the ignition coil can be faulty. Second, The ignition switch can be faulty. Third will be the starter. If it's faulty, it won't kick the flywheel. One good reason why it won't turn over.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 28, 2011 | 1991 GMC C1500
My vitamixer's variable speed switch is stuck on about 2/3 speed. the on/off switch works fine. the high/variable switch changes from high to about 2/3 speed. the variable speed dial has no effect of the...
This problem sounds like failure of the Variable Speed Potentiometer component. Here is the most helpful Fixya article so far: http://www.fixya.com/support/t6032529-need_replace_speed_control
I have the same problem right now and don't want to pay ridiculously high prices for a small electronic component.
So far, this is as far as I've gotten in researching replacement parts:Vitamix Part #015955
Partstown sells #15955 for $23.39 on their website but I found out they charge $15 for shipping -- for a one-ounce piece of electronics. I won't pay to be ripped off on shipping so I won't buy one from Partstown until I've exhausted less-expensive suppliers. Here is the product at Partstown: http://www.partstown.com/vita_mix/vm15955
Another Fixya contributor, Robert Sadler, said he was going to try a generic potentiometer from Mouser.com. His descriptions are kind of vague for me. I'm not an electronics expert so I'm not very confident I can interperet his description:
"If you are comfortable with soldering, you can get a replacement part at Mouser.com. The pot is a 5k "slimline" made by Bourns, however looking inside the cover it looks like most pots would fit. I ordered one for a bit over $5 and will update when I get it with how it worked. You would just have to solder the existing wires to it." -Robert Sadler
I have no problem soldering the existing wires onto a new component but I don't really know what would be an appropriate potentiometer to buy as a replacement from an electronics supplier. In addition, Mouser's website seems to sell potentiometers only in bulk quantities of 5, 6, 12, or 45 items at a time. I just want one.
If anyone knows how to interpret Robert Sadler's comments, or has actually done this repair, please post below. I'm sure quite a few people would benefit from a high-quality repair at a low component cost.
Apr 08, 2010 | Vitamix 5000 Work Top Blender
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
