Question about Garden
Cubcadet ss418 first time using it won't stay running after using for awhile
  • 7,482 Answers
Hi robert
Here are a few suggestions you can try
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on May 03, 2013
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
I have a husqvarna 4623 zero turn and when I would pull up the pto the mower would die. I replaced the fuel filter and now it won't even stay running
Most likely the battery isn't holding enough charge which is why the PTO won't engage.
Likely you have air in the fuel line/fuel filter which lets it run for awhile then it fuel starves.
Oct 30, 2012 | Husqvarna Garden
98 Expedition..5.4L 4WD..coded bank 1 bank 2....O2 sensors..LEAN....replaced both..no change..still same codes..now it won't stay running. Tried to code again..won't run long enough to get a c
all code readers will retrieve information stored while in the on position --doesnt need to be running ---when you rehook up scanner either resubmit or edit request with codes
Aug 15, 2017 | 1998 Ford Expedition
Our cub cadet will run and mow for a short time then it shuts down and won't start if we let it set for awhile then it starts it done this about 4 times now it acts as if it needs the battery char
Take your battery to Oreilly's or autozone,, ask them to check the CCA (Cold Cranking Amps).. this is the true measure of battery quality... if its low, they will tell you and get a new one... see if it runs better,,, it not... you may need the assistance of a qualified professional.. ( may be a coil)..
Aug 10, 2017 | Cub Cadet Garden
1987 300 zx starts the quits after 2 minutes and won't start again
probally crank sensor. starts then stalls after driving a few min. then won't start for awhile. u can actually check it on the ecu. 4 green lights then 4 red lights. if you can't run the comp check on ecu let me know i'll look it up its been awhile had same prob years ago all my sensors are new
Oct 28, 2011 | 1987 Nissan 300ZX
My hp elite won't turn on. it was running fine, and I left home for an hour, came back and it was off and wouldn't start. it's only 3 years old. The little green light on the back stays lit for...
The green power light will stay on after it is unplugged, as there is still residual power in the unit. The symptoms you describe point to blown main capacitors in the PSU, the only way to check is by fitting a new PSU (recommend one of 700 watts minimum). Not very expensive and as long as you are careful, easy to fit
Jul 02, 2011 | Computers & Internet
Garden Logo
165 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
