Question about Kenmore 75085 Air Conditioner
580 75101500 Doesn't put out cold air anymore. Only thing wrong with it. Can it be recharged?
Hi there We have a kelvinater fridge, it is quite old but not that old that you don't get parts for it anymore. But anyway the thing is broken, first the gas but thats fixed, we even got a new...
if the compressor runs but the fridge never gets cold, toss it, if the compressoris not running replace the start mechanizm, also check to make sure the thermostate is putting power to the compressor when you turn it colder, if not... then replace the therm
Feb 05, 2013 | Refrigerators
1999 VW passat air conditioning gets cool but not cold. It gets colder after driving then put in park than it does while driving. The condensor and fan both come on but it doesn't blow cold air. H
take to a shop and have it done if you dont have proper equipment to do it is easy to over or under charge if was shop not friend then take back . when too much is put in at higher speed it will not cool and the specs are in metric and only holds 1.15 lbs of 134-a no more
Aug 04, 2012 | 1999 Volkswagen Passat
I have a Frigidaire FRC150FF fridge, the fridge light comes on but the fridge is warm. The frezzer compartment is working fine
How old is the fridge? Can you hear it running?
It could me many things. Could be anything from a dead compressor to a coolant leak.
Did someone change thermostat setting, maybe during a cleaning? There's a knob in the refrigerator section somewhere; see if it's turned to "Off" or to a less-than-cold setting.
If you hear the motor running, but it doesn't get cold, it probably doesn't have any refrigerant to compress. That could be recharged, but modern refrigerators are pretty tight, so that would also indicate a leak. With a leak, it will need recharging again sometime later.
Jul 22, 2011 | Refrigerators
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
My 1994 Camry idling problem.? It's a 1994 Camry V4, 2.2 L. After i changed the head gasket, my car idle became too slow. It seems like it doesn't have the cold engine starting idling anymore, i...
If it runs fine and the idle is the only problem you could try idling it up some with the idle set screw on the throttle body it sounds like it may be a little bit out of time those toyotas have a fine lins on the timing.
Jul 03, 2011 | 1994 Toyota Camry
I have a Electrolux Intuition plus freezer/refrigerator, and freezer is working properly but refrigerator isn't working anymore (but light inside still works) but it is not cold inside anymore, what...
A clog on the refrigerator side will cause that. Check if there's a lot of things loaded into it. Usually cold air from freezer will going down up to the bottom of the refrigerator if there's no hindrances or blockage like food stuff, fruits, vegetables, etc. load, it should therefore be cold.
Arrange correctly the things you loaded so it will not blocked the cold air dropping and it will reach the bottom side of the fridge.
Good luck.
Jun 24, 2011 | Refrigerators
CARRIER WINDOW A/C HAS A COOLING PROBLEM, IT RUNS FOR 30 MIN STARTS FORMING ICE ON IT'S EVAPERATOR AND DOESN'T COOL ANYMORE. CAN SOMEBODY ADVISE ???
This is due to low gas pressurre in the system, check the leak repair it and recharge the gas pressurre.
Jun 24, 2011 | Heating & Cooling
Air doesn't get cold like it use to. I spray cleaned the unit and it didn't help. Can the unit be recharged? Goldstar model: GWHD6507R Thanks.
Hello, yes the unit can be recharged but you need to install a piercing valve on tje low side of the system to charge in the refrigerant here is a link to where you can buy piercing valves. http://www.globalindustrial.com/g/hvac/parts/ac_accessories/Supco-Acces-Valves
Jun 07, 2011 | Goldstar KG6000R Window Air Conditioner
Kenmore 75085 Air Conditioner Logo
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
