Question about Veo Wireless Observer Network Camera
No Wireless Camera Not Found
I have purchased VEO Wireless Observer (network camera). Installed the Observer setup utility and Observer Studio, when i click on the wireless setup it give me the camera not found. i have connected the camer to Serial Port, and How to configure it.
  • nagendra Aug 09, 2007
    After installing the Observer software, when i open the observer setup utility in that their is a option called wireless setup when i click on it it gives me no wireless camera found please check the camera is powered on and connected to your serial port.
  • Anonymous May 01, 2008
    no wireless camera found. comm port is working in device manager
    Scholar:
  • 125 Answers
While you had it plugged in the serial port you should have set the SSID name for the camera? You may have to enter this manually to find the camera. If it is not set to broadcast this SSID, it will work but you must put it in the wireless connection settings.
Posted on Aug 08, 2007
  • Anonymous Aug 09, 2007
    Have a look in Device Manager for problems with your serial ports first.
  • Anonymous Aug 13, 2007
    So you can't connect to the camera at all?
    Is the serial port enabled in the BIOS?
    Check in Device Manager for problems with the ports and post back what you find.
SOURCE:
Serial cable
I have the same problem but I dont found this configuration serial cable, if u found this please sendme, thanks.
[email protected]
Apr 25, 2010 | Veo Observer Network Camera
VEO observer hard wired version
Did you configure the webcam to be accessible over the internet? The IP address that you are using in your home network for the cam is only valid there (I assume you are running on a workgroup).
Jan 25, 2008 | Veo Wireless Observer Network Camera
Did you solve your problem with the VEO Wireless observer?
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Aug 04, 2008 | Veo Wireless Observer Network Camera
VeoNetwork Web cam
You can view your Veo Observer web cam at home by either of two methods. The first is to use the Observer Studio software that came with the camera. When you configured the camera, you selected a local (private) IP address for each Veo Observer, and set the address specific to each camera. You then put the same IP address into your Observer Studio Software.
Depending on the brand of router you use on your home network, your Veo Observer camera probably has a local (private) IP address in the format 192.168.0.xxx or 192.168.1.xxx where "xxx" is the actual address assigned to your Veo Observer (by you) and configured to display on the LCD window on the side of the Veo Observer.
You may need to log into your router to see which of the two local (private) IP address formats is used. Your router's user manual will show you how.
To view your Veo Observer, just type the exact local (private) IP address in your IE browser. for example, if you assigned address 100 to your cam, you would enter http://192.168.0.100 or 192.168.1.100 into your browser. Veo Observer will display the Language selection screen. Choose the language, then you log in and view your camera.
To view your camera from outside your home using another computer, you use the same method, but you have to substitute your WAN (public) IP address.
You can log into your router and select its STATUS tab to view your WAN (public) IP address. See you router's set up guide if you do not know how to do this.
An easier way to determine your WAN (public) IP address is to visit Gibson Research Shields Up! web page:
https://www.grc.com/x/ne.dll?bh0bkyd2
and scroll down to the last paragraph where you will find your WAN (public) IP address.
For example, if this address is 123.456.789.100, then you would enter http://123.456.789.100 on your IE browser. You should see the Language select screen, choose your language, then log in and you are now viewing your Veo Observer from outside your home.
Note: when you view your Veo Observer at home, you probably have a fast frame rate and smooth video motion. When you view your Veo Observer from outside the home, the frame rate is certain to be less, and your moving image quality will be choppy. This is normal, as viewing from outside the home is less efficient and the image suffers. There is nothing you can do to boost the frame rate.
Jun 15, 2008 | Veo Observer Network Camera
Veo observer
Connect your pc to your webcam directly with a cable,and close the firewall software on your pc,then try the set up utility.
May 20, 2008 | Veo Observer Network Camera
Veo Observer software
I have the original disk. I can make an image of it and post it on my website. Email is "[email protected]"
Jan 16, 2008 | Veo Observer Network Camera
Wep key for veo network camera
Your wireless access point or router is using WPA encryption. The VEO can only handle WEP encryption and its likely to be a hardware limitation - I doubt a firmware upgrade would appear for this. One solution is to change your network to WEP or open. Another is if you are running OpenWRT on you access point or router, you could possibly set up a virtual wireless LAN for your camera(s) using WEP while maintaining  your WPA set up for other wireless clients.
Sep 04, 2007 | Veo Wireless Observer Network Camera
VEO Wireless Observer RS232 serial cable help please
PC Serial port - Stereo jack
Pin 2 - Ring
Pin 3 - Tip
Pin 5 - Sleeve
Aug 20, 2007 | Veo Wireless Observer Network Camera
Voe observer down
Can you help me? I have an Observer camera too. And I have the problem "no response from camera" (Veo Observer Studio) and I can't reach the camera via Explorer too (the page dosen't exist).
Earlier it is working well except the remote access. I try it resolve and came the problem: "no response from camera".
What was the solution at your camera?
thanks
May 29, 2007 | Veo Observer Network Camera
Veo Wireless Observer Network Camera Logo
313 people viewed this question
Top Veo Computers & Internet Experts
Thomas F. Schneider
meli novacole
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
