Question about Home Security
We have a home alarm system (xL4612sm. one of the keypads is continually giving off a warning sound but all of the other keypads are fine and can sense the house correctly. how do i make the faulty keypad be quiet?
SOURCE: Wireless keypad cannot be reprogrammed....not able to get to "smart button".
http://www.chamberlain-diy.com/diy04/pdf/programming_instructions/940CB.pdf
Posted on Dec 13, 2007
SOURCE: Reprogram garage door keypad?
I have a Liftmaster 377LM wireless Keypad no maual
How do I reset it?
Posted on Feb 07, 2009
  • 43 Answers
SOURCE: Need to change keypad code, but lost instruction manual
The key code transmitter for your unit should be 53776 multi key panel:
you must have access to the operator to reset. The programming keys are as noted below:
1. Open the Touch C.ode Transmitter cover to access the keypad.
Decide on a 4-digit code number using numbers from
0 to 9. You can use a number more than once. (For
example, 4, 0, 4, 1).
2o Press the 'SR' code button on the opener panel. The
indicator light atongside the push button will turn ON.
3_ STAND AWAY FROM THE DOOR. Press the selected code
numbers on the keypad and then press the ENTER key.
The indicator light on the opener panel wiil turn OFF and
the door witl begin to move, The opener receiver has been ._
programmed with your code selection. (_
NOTE 1" If the indicator light turns OFF before the code _ . "_ _'
digits and ENTER key are pressed, repeat Steps 2 and 3. _._t,_-_ J t_
NOTE 2' During programming, be sure the,k/_ca_i_n push :---'-"_"
button (if your opener has that feature) is OFF and the
Infrared Sensor (if you have installed that accessory) is
free of obstruction. THE DOOR WILL NOT MOVE AND THE
INDICATOR LIGHT WILL NOT TURN OFF in either case.
To change your code at any time, repeat Steps 1, 2 and 3.
Hope this helps
Posted on Apr 12, 2009
SOURCE: turned power off in house alarm went off.
pull transformer out of outlet---disconnect battery---let it stay down for five or ten minutes--make sure you have a known-good battery --ready--re plug transformer,then battery,if it comes up armed,put your code in
Posted on Apr 23, 2009
  • 3197 Answers
SOURCE: Liftmaster Keypad problem
First thing to do is make sure it has a good battery installed. If this doesn't take care of the problem then the keypad is going bad and needs to be replaced. It is important that you get the same keypad as there are others out there that look the same but will not work.
Posted on Jul 23, 2009
What kind of alarm equipment does the company provide?
Depending on what ur using it for .check out swann or logitech website
Oct 15, 2014 | Home Security
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
I don't remember how to set my alarm
This is the manual in .jpg/image form. Hope this helps for anyone still looking for the manual .
Mar 23, 2014 | Bell & Howell Secure Pro Keypad Alarm...
LINTECK LS400 WONT DISARM
You have most likely "bought a duffer" I have 30 years experience with alarms.
!. Remove the internal battery, power down the panel.
2. leave "dead" for 10 minutes.
3. reinstate the power, Mains first then refit battery (Make sure terminals are correct for each wire)
4. Retest.
If the above does not work give Lynteck a call on
  • 01282 717 490
  • email sales@lynteck.co.uk
Mar 05, 2017 | Home Security
I bought a home with this system and need to be able to use it. Who can help me set it up?
i bought a home with a gemini system in it / i dont have the old codes can i reset this key pad
Oct 07, 2011 | Gemini Sound Products Gemini Napco...
MY ALARM SYSTEM KEEP BEEPING UNCONTROLABLY..ADEMCO ALARM
Resetting Your Installer Code
1. The installer code (IC) is the code that allows you to access the system programming. If you forget your IC, your alarm company probably won't give it to you. This is because they use the same IC for many installed units and keep it a heavy guarded secret. If your forget your IC code, you're going to have to reset it.
First locate and disconnect the transformer. This is a cube-shaped wall outlet, usually placed around the alarm control panel. Next, shut down the alarm system's power supply. You may have to unplug a battery if you have a secondary power source connected to the alarm system. Once the alarm is powered down, you will reconnect the transformer and the battery in that order.
The rest of resetting comes on the keypad. Within 30 seconds of powering up the alarm, go to your alarm key pad press down the * and # keys simultaneously until you see "20" displayed. At the same time, you should see "Installer Code." Enter your new installer code while the "20" is still on the screen. Your installer code will be four digits. The keypad will beep to acknowledge the new installer code. After the keypad beeps, press *99 to exit the program. To check if you have reset the code successfully, enter your new installer code and press 1 (off). The keypad will beep once if you have successfully changed your installer code. If it doesn't beep, repeat the process.
Resetting Your Master Code
2. The master code is usually only used by the home owner. Other users codes can also be set up, including manager, babysitter, gardener and housekeeper codes. The home owner will use the master code to set up these other codes. The master code is also the code you will use when you come home and need to deactivate the alarm before it goes off.
To reset your master code, type in your installer code, press 8, press 02 and then punch in your new master code. Press 1 to turn off the programming. Your keypad will beep when you successfully reset your master code. You can now activate and deactivate your alarm system as you please.
Read more: Ademco Alarm Resetting Instructions ' eHow.com http://www.ehow.com/way_5752912_ademco-alarm-resetting-instructions.html#ixzz3pC2j96jl
Feb 04, 2011 | Audio Players & Recorders
Bought a foreclosed home with an ademco 6510pl3 keypad. No manuals left and no code. Is it possible to reset? I don't want to have it monitored, waste of money with all the false alarm fines.
This thing can't be reset,must have the original codes to used the system.Cancel the monitored service,when u all set to move in or sale it.Have to put in a new alarm system.
Jan 14, 2011 | Ademco 1 Ademco 6150 6150pl3 6150pl2...
Home Security Logo
61 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
