Question about Maytag CWG3100A Gas Single Oven
Crosley gas oven will not heat up
OUR CROSLEY GAS OVEN TAKES ALONG TIME TO HEAT UP WITH A GAS ODOR. THE GLOW PLUG GETS CHERRY RED BUT THE BURNER WILL NOT LIGHT. WHEN I WATCHED IT IT IGNITED AFTER A FEW MINUTES AND WHEN IT DID THE FLAME ON THE BURNER WAS VERY SMALL AND LAZY LOOKING. THE TOP BURNERS WORK FINE. ANY HELP WOULD BE GREATLY APPRECIATED.
  • 3 more comments
  • sheilaf Jan 09, 2008
    Pilot won't light. Should I call PG&E or do you have a diagram showing me where pilot is and what I should try lighting>
    I have used oven for a year (new when I moved into my apartment) and all the sudden went out. I had preheated it for a 1/2 hour and when I opened oven door there was no heat, when I opened broiler door there was no gas smell. The top burners work semi-fine as they always loose power if I use more than one burner at a time.
    Please help as I have a bad fear of fires, being in one as a teenager and having to get 8 children out of the house before it burned down.
    Thanks,
    Sheila Ferretti (sheilaferretti@yahoo.com or 650-771-6886)
  • Anonymous Feb 19, 2008
  • sorkai Jul 26, 2008
  • Anonymous Nov 25, 2008
    Our Crosley range is not heating up? Sucks!
  • Anonymous Mar 18, 2014
    When we purchased the house, there was a jar of some type of a blackener for the electric burners. You used a small pad and wiped it on and it made them darker and newer looking.
That's my mom!!! Go Sheila!!! Hehe.. -RET-
Posted on Jun 04, 2008
Oven takes too long to start or not at all
is this electric or gas? if it is gas and a newer model it has an ignitor that heats up that will then ignite the gas burner, the ignitor is bad or you may need to inspect and clean the gas ports on the burner as they can get cloged up over time, try the inspection and cleaning first. If it doesnt appear to be cloged then turn on the oven and watch the ignitor, if it doesnt heat up to be white hot then it is bad or going bad and should be replaced. if it is electric check to see if the heating element is working by turning the oven on and watch for it to glow red hot, if it doesnt then it will need to be replaced.
Sep 08, 2014 | Ovens
Glow plug gets red but oven will not ignite. Broiler ignites but has seperate glow plug.
Check to see if you are getting gas to the oven burner. If it will light with a match then look into adjustment of the flow plug, but if it won't light, then look at the gas valve or switch.
Jun 07, 2011 | Ovens
The pre heat is taking a long time over 30 minutes
SOUNDS LIKE THE IGNIGHTER IS GOING BAD, OR GLOW ROD. OPEN THE BOTTOM DRAWER AND WATCH THE AND SEE WHEN YOU TURN THE OVEN ON HOW LONG DOES IT TAKE TO GLOW BRIGHT, THE GAS BURNER WILL NOT START IF IT DOSNT GET A READING FROM THE GLOW PLUG
Dec 24, 2010 | Ovens
I have a 6 yr old Tappan stove, model TGF657BFW5. the burners work fine, but the oven and/or broiler take 5 to 10 minutes to light. when the oven and/or broiler do light, the flame is only about 1/8 to 1/4...
that ignitor should lite the flame within 40 to 60 seconds if not the ignitor is bad.even though it glows red it doesn't mean it's good it works with amps change the ignitor
Nov 06, 2017 | Tappan Ovens
My Magic Chef 21MS Natural Gas Oven will not heat up in oven. The top burners are fine.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 25, 2009 | Magic Chef 9122 Gas Single Oven
VDGO viking gas oven upper won't heat
Aug 16, 2009 | Ovens
Viking professional gas range isn't heating properly
The ignitor must glow brightly, if it is dim it is probably too weak to open the bi-metal safety valve. Take a LOOK
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 17, 2009 | Ovens
Oven burner doesnt light
Doubt that the glow plug is bad. Gas only needs about 1100 degree F. to ignite using the glow plug method. It really seems as if there may be no gas getting to the burner. If there is no flame, you should be able to smell gas. If there is no gas smell, then I would look for the obvious such as: is the gas turned on?, Does the gas valve on the unit have a safety that is tripped? and so on. A new gas valve may be in order but make sure that it is receiving the proper voltage when the glow plug is on. Lastly, there may be a safety that is malfunctioning. If the unit does not light within a given time, the safety will "Lock Out" the unit so the place doesn't fill up with gas.
Hope this helps and good luck.
May 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
I have a gas oven whirlpool sf3020ekq2 buners work but oven won't
Sounding like your hot surface ignitor is getting bad. What I would like for you to do is open the oven and take the bottom panel off. This is so you can see the hot surface ignitor. Turn the oven on and look at the hot surface ignitor it is down on the bottom right next to the burner assembly. Does it start to glow and turn cherry red? This ignitor isn't too hard to replace couple of small screws and two wires. Will have to cut the wires so disconnect the unit from the 120 volt plug. Now if it starts to glow and get cherry red hot then the gas valve is sticking and it is the one going bad. That is a little tougher to replace. Turn the gas off at the source and get your wrenches unscrew the gas valve small space so if you want remove the door by just pulling it off the hinges.
If unit is old and you don't like it anyway maybe santa would be good to you and replace the stove oven. The gas valve is about 60 bucks or so and hot surface is about 20 bucks. let me know how it turns out.. ken
Dec 16, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Maytag CWG3100A Gas Single Oven Logo
1,116 people viewed this question
Top Maytag Ovens Experts
Carmen Mikulic
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
