Fuel&watergaugeclock possible purchase? or repair
  • 7,627 Answers
Ebay
Posted on May 02, 2013
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
White smoke out the tailpipe,does not small like coolant
Could be raw fuel, if only on start up,not ATF
Check fuel trim with a professional scanner
& fuel pressure,& look at oxygen sensor data
I wouldn't use it, if it is fuel,you could hydraulic
the motor & bend a rod, as a liquid doesn't compress
Leaky injectors possibly
If so, I would mail them all away to be tested & cleaned off
the vehicle ( Ultra Sonic Cleaning) nothing else works
If some are bad, they will clean up some old ones & flow them
to match yours
A repair shop won't know what I'm even saying
Mar 25, 2014 | 2004 Lincoln Aviator
Location of fuel over load reset button?
Fuel Safety Shut Off Switch --- is only on Ford Products
& only opens in a serious accident,so diagnose the circuit
that blows the fuse
Don't keep replacing it,that's silly
Diagnose the fuel system if you know how ,have the proper
knowledge & test equipment & possibly wiring diagrams,
otherwise take to a repair shop & explain
Jul 11, 2013 | Cars & Trucks
Hi My Kelvinator Beverage Cooler fridge has packed up due to power surge. If possible please could you email me a quotation as i need to purchase another one. Description: 1 door which is glass and its...
Hi.
The price depends on the model and on the internal volume. Here a UK seller: Commercial Beverage Coolers & Commercial Bottle Coolers. Here a SA distributor of beverage coolers. The choice includes Kelvinator.
About the fault. If the problem happened after a power surge it is often possible to repair the cooler replacing the starter relay mounted on top of the compressor. The part is not expensive. Call the Kelvinator number listed on the owner manual to know more about the possible repair or to purchase the part.
Regards.
Ginko
Sep 13, 2011 | Kelvinator Refrigerators
Just purchased a 1994 Firebird, took it in for a smog test, and it failed at 15MPH, measuring 522 while the max allowed is 483. Car had been in storage for two years with the battery disconnected. Also low...
522 what? Get it registered. Yes it needs to be driven, Yes do an oil change. Add some injector cleaner, I recommend Chevron TECHRON fuel system cleaner. The shop that is checking it most likely knows what it needs to be repaired. If you dont trust them to properly repair it, find a different shop.
Aug 03, 2011 | Pontiac Firebird Cars & Trucks
Ive got a 2001 vw jetta 2.0 that died while driving and will not start. The starter engages but engine is not firing at all. Ive tested the starter which is good. I removed a spark plug & while still...
do you have compression on every cylinder? that may be your problem, that's the suggestion i'll make. pull each spark plug one at a time and do a compression check to make sure you have compression. if you don't have the tool, they are not that expensive to purchase. hope this helps you out!! although, if you do this test and it's good compression, i would lean more towards it could be out of time. meaning it could possibly have jumped time but you said the belt was good, it could have jumped a tooth or two which would mean a no start also.
Aug 23, 2010 | 2001 Volkswagen Jetta TDI
95 S10 blazer 4.3 vortec skipping code po172 and po300 possible solutions
P0172 system too rich bank 1. P0300 random multiple misfire. All are a common symptom of either bad fuel pressure regulator or leaking injector. Need to pull off intake plenum (upper) You should visibly see a clean side or part of intake manifold (lack of carbon buildup) Reconnect fuel lines. Energize fuel pump (turn on key to run) Most likely you will see fuel dripping out of rear (fuel pressure regulator) or nylon lines to each cylinder (fuel injectors). Once you see which is leaking will need to replace. Once they are repaired will need to clean or replace spark plugs & change oil & filter.
Jun 26, 2010 | 1995 Chevrolet Blazer
89 ford taurus, had to have the fuel pump replaced, now the gas gauge doesn't work. The garage says they didn't cause this. Is that true? (It worked before the repair)
In order to replace the fuel pump the gas tank has to be removed from the car. Both the pump and the gas gage are located in the tank. They probable didn't reconnect the wires going to the gas gage. I guess it is possible that they didn't have anything to do with it and it just happened to go bad while they were working on your car. Not likely but possible.
Jan 27, 2010 | 1989 Ford Taurus
Code 25 for Toyota 3.0 3VZE
code 25 air fuel ratio lean condition indicated.POSSIBLE CAUSES- AIR LEAKS IN THE INTAKE MANIFOLD -EXHAUST MANIFOLD -EXHAUST PIPES- FUEL CONTROL SENSORS IS OUT OF CALIBRATION LIKE THE-ECT IAT MAF -LOW FUEL PRESSURE LIKE- FUEL FILTER CLOGGED PRESSURE REGULATOR FAILURE- ONE OR MORE FUEL INJECTORS RESTRICTED -HO2S ELEMENT IS CONTAMINATED DETERIORATED OR HAS FAILED -VACUUM HOSE IS DISCONNECTED BROKEN LEAKING OR LOOSE.
Jul 20, 2009 | 1994 Toyota Xtracab
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
