Sharp mx 4501n error code f2- 67 - Office Equipment & Supplies
tehnik_bdg
  • 91 Answers
SOURCE: Sharp printer copier MX 4501N, how to remove the
Pull the paper tray to the front, after it is stuck pull it up ward and front
Posted on Apr 16, 2009
  • 117 Answers
SOURCE: add user codes to a sharp mx-4501n mpf
Try exploring the device's web management interface.
Use your wenb browser to connect to the device's IP address.
the default credentials for the unit are user: admin pasword: admin
if that does not work, try password: Sharp (note that the S is capital and the rest are lower case)
Posted on May 07, 2009
  • 120 Answers
SOURCE: CE00 Error code
CE-00 means the copier cannot find the computer or server it's directed to scan to.
The usual cause is that the IP address for the scan destination has been changed by DHCP and the connection info has not been updated in the copier.
To resolve, reboot the destination workstation or server. Or, right-click on the Network Scanner Tool icon in the tray, select Automatic Profile Update, and click on Update Now.
If the scan profiles were created in the webpage and not through Sharpdesk/NST, make sure that destination names and/or IPs have not changed in the profile.
If you are using DNS name resolution instead of direct IP addressing, you must be sure that the DNS server IPs are correctly entered into the web page.
Hope this helps!!
Posted on Jul 09, 2009
  • 143 Answers
SOURCE: Sharp MX-4501N Error L4-11
L4-11 is a Shift motor trouble in the finisher. First you must repair the problem then Use SIM6-1 to check the operation of the shift motor. Then use SIM30-1 to check the shifter home position
sensor. Check the harness and the connector
between the PCU PWB and the shift motor.
You can clear the code by using SIM 14.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key ON → CLEAR key ON → Asterisk (*) key ON → Ready for
input of a main code of simulation
2) Entering a main code with the 10-key → START key ON
3) Entering a sub code with the 10-key → START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected
item.
Press START key or EXECUTE key to start the simulation
operation.
To cancel the current simulation mode or to change the main
code and the sub code, press the user setup key.
* Canceling the simulation mode to return to the normal mode
1) Press CA key.
Posted on Sep 01, 2009
  • 33 Answers
SOURCE: can you bypass or delete the admin on the sharp mx
this is easy to do but it comes down to a security problem....cant be sure you are the owner of the copier best to contact local sharp repair
Posted on Jul 20, 2010
Sharp MX-4501n firmware
The firmware is only available from Sharp's service site. Call a local Sharp dealer to upgrade the firmware for you.
If you're in Houston we would be glad to help you out. We have the best copier service in Houston.
Skelton Business Equipment Houston Copiers
Sep 05, 2013 | Sharp Mx-4501n Color Laser - Printer /...
Selected servers not found
this is a common error with Sharpdesk and the Network Scanner Tool. Your IP address has probably changed. Here are some instructions on how to resolve this issue and prevent it from happening in the future.
Sharp Scanner CE 02 Cannot Connect to Server Consult your Network...
Apr 30, 2013 | Sharp Mx-4501n Color Laser - Printer /...
Error H2-00
check your connection in fusing unit..try to reset in techrep mode using #p * c *..or replce fusing unit..
Apr 17, 2013 | Sharp Mx-4501n Color Laser - Printer /...
Add user codes to a sharp mx-4501n mpf
Apr 24, 2009 | Office Equipment & Supplies
Sharp MX-4501N Mac drivers 1.1 will not hold black and white colour setting in printing profile (save as)
You are using Bonjour to print to the MX-4501N which uses a generic post script driver. To fix this, you must install the printer using the proper driver from Sharp. For a first time install, download the drivers, install the drivers, restart, and install the printer as an IP printer, specify the IP address, it should be using the LDP (Line Direct Printing) protocol, and specify any additional optonal accessories you have on your MX-4501N. Hope this helps :)
Oct 09, 2008 | Sharp Office Equipment & Supplies
88 people viewed this question
jasbo
jasbo
