Question about Genz Benz Shenandoah 150lt Acoustic Amp Awesome!
Amp not comming on until strings played hard.
My Genz benz guitar amp sometime wont turn on or give any sound unless I hit / play the strings hard. The lights come on but the amp wont make any sound until I lightly hit the top of the amp or hit the strings of my instrument hard. I have 2 of these nice amps and both do the same thing. I snt one of the to Genz Benz 8 months ago and thy said they couldn't find any thing wrong. I bought another being afraid of that one amp messing up again / as I really like them. Now I have 2 amps doing the same thing. The 1 st one that I sent off finally made a load buzzing sound when it died. Then I sent it off to Genz Benz. Now they have been bought out by Fender and the c
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Could be a guitar cable, but you said it comes good when you tap the amp?
Some of these are tube amps so id take a peak and see if you have a blown valve.
They will either not light up or will have a blue purle glow about them
Posted on Oct 04, 2017
Check your cables - I've had similar problems with various amps playing various guitars; the guitar electronics and the amp electronics are fine, but the cable is damaged internally and this causes the same problems as you have described. Have you tried using a different cable? Buy a different one, try it out, and see if you have the same problem. If you have a friend who plays, let them plug their cable and guitar in the amp - if it works, your faulty cable is the issue. Hope that helps!
Posted on May 02, 2013
HELLO AND THANK YOU.... I LOVE MY 335...... BUT SOMETIMES ESPECIALLY WHEN PLAYING DOUBLESTOPS......THERE IS A RATTLEY, SPRINGY SOUND THAT ALMOST SOUNDS LIKE DISTORTION.... IRS NOT FRET...
Make sure amp sound is not hitting front of guitar straight on. Get a 2nd pair of hands and while you do a test strum have the other person use hand or hands and apply pressure to various places on the body(such as the bridge, headstock, sides, etc and see if any of those affect the sound. Very light strings are sometimes a problem.
Sep 25, 2017 | Gibson Guitar Gibson ES335 Dot Reissue...
Genz Benz Tranzamp G8 amp my son just bought at a garage sale makes a horrible buzzing sound. I tried cleaning the plugs on both end with 3M sponge. Now, not as much buzzing but still no sound coming...
Sounds like the power amp section of the circuitry has a fault.Not easy to fix unless you are familiar with electronic circuitry.Take it to a repairer and ask for an estimate.It may be cheaper to buy another(new) amp.
Jun 18, 2011 | Genz Benz Tranzamp By Genz Benz G15 20...
If I turn up the volume on my Frontman 10g more than 4-5,the amp starts buzzing every time I play the thick strings. Thank you!
You MAY be overdriving the amp. This is a tiny amp and should NOT be played louder than a typical BoomBox or the speaker may be driven too hard, going non-linear and then buzzing.
Mar 19, 2011 | Fender ® Frontman 10G Electric Guitar...
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
I have a Marshall MG100DFX. I turned my amp on a few days ago and I heard this loud sound (not the standard hum/buzz that you hear when you plug a guitar into an amp; it sounded more like a foghorn). Now,...
I would try hitting the side of the amp before turning it on. There may be a loose piece of solder or other conductive particle stuck somewhere. Bang the cabinet rather hard with your fist. If that doesn't help it might be a loose solder connection at a resistor or capacitor but a tech should check that out.
Dec 04, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
When playing notes on the A string I get a crackeling noise
Just a thought:
If you used the speakers with another amp and they still make noise when you play certain frequencies, then it is obviously a problem with the speakers or the cabinet - it could be a mechanical resonance in some part of a speaker / cabinet, something like a loose screw or a nut, loose protection mesh on the speakers that resonates at certain frequencies, possibly a bad speaker or a speaker membrane...
Also, you might want to check the pickups on your guitar, see if the pickup core slug under the A string is much closer to the string than the other slugs so it is either picking up too much signal and distorting it or the string might be touching the slug when you play it and cause noise, also see if the string is touching something else when it vibrates...
good luck
3rq8 (Triarcuate)
Sep 08, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Gibson Les Paul wont stay in tune
That's the problem; you're using light gauge guitar strings. Chances are that if you are not used to playing strings that light, you're fretting hand will hit the strings with more force than is neccesary to fret them, thereby forcing them out of tune. You can solve this problem by adding more winds around the string post (three or more winds should do it), or you can switch to a heavier gauge of string.
If they're true locking tuners, they should have a notch on the back of the gear housing that you turn with a nickel to engage the locking mechanism once tuning has been established.
Also; check the intonation of the guitar itself on an electronic tuner. If it tunes right but sounds out of tune when played, this is an intonation issue, and can be solved by adjusting a small set screw that moves the individual saddle back and forth in the tune-o-matic style bridge. You can check this by tuning the string to the correct note, then playing the same string at the 12th fret and checking it against your tuner. If it rings in true, you're fine, if it comes up flat or sharp, every note on the fretboard is going to be off by that much, and you'll have to adjust accordingly (turn the screw to the right to add length and lower a sharp note, turn the screw to the left to subtract length and raise a flat note, if I remember right).
Hope that helps.
May 12, 2009 | Gibson Music
Problem with the pickup sound on the 'g' string on my epiphone les paul standard
Hi ! Must be a problem with either the nut or the g-saddle in the bridge of the guitar.
Good luck , Stefan from Sweden
Nov 10, 2008 | Epiphone Music
Genz Benz Shenandoah 150lt Acoustic Amp Awesome! Logo
89 people viewed this question
Top Genz Benz Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Genz Benz Music Expert? Answer questions, earn points and help others
