Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Pulleys Diagram part number for pulley
2 Suggested Answers
BAMOUT
  • 2478 Answers
SOURCE: Belts and Pulleys diagram for Craftsman 24727022
Your owner's manual has a diagram in it.
Posted on Feb 06, 2014
2007 dodge sprinter belt and pulley diagram
There is a belt routing diagram under the hood.
May 18, 2016 | Dodge Cars & Trucks
Can you show me the correct diagram for the drive belt on a 44in Dixon zero turn mower
Hope this helps. Serpentine Blade Drive Belt
1 Lower the mower deck to its lowest position.
2 Route the serpentine blade drive belt (part number 6109) onto the V-pulleys located on the mower deck. One double pulley is located at the front of the deck near the center. The other two pulleys are located near each side of the deck. Route the belt around the outside -- the side toward the outer edge of the mower deck -- of each pulley. For the double pulley near the front of the deck, route the belt around the lower pulley (part number 6058) only. If pulleys are fitted with belt guards, work the belt in between the pulley and shield.
3 Push the idler pulley toward the center of the deck with your hand. The idler pulley (part number 6059) is the fourth pulley on the deck and is located near the rear of the deck. It is the only movable pulley on the deck. Wrap the belt around the side of the pulley nearest the edge of the deck. Release the idler pulley to place tension on the belt. No adjustment is necessary because the serpentine idler spring (part number 6065), located on the idler pulley, adjusts the belt to the correct tension.
May 10, 2016 | Garden
I have a vintage Murray Riding Mower, model number is missing has three blades each blade is 15.5 inches Need belt diagram to install both belts to deck
If you have info numbers off the engine, usually found stamped on the top front area, it should at least give you an approx. year.
Sometimes there is a belt diagram under the foot rest area.
Worst case : The belts always fit/sit with the flat part to the flat pulleys and the v part of the belt to the v pulleys.
Oct 24, 2015 | Murray Garden
Serpentine belt diagram for a 2003 Chevy unpalatable 4.3
Pop the hood of the car and locate the serpentine belt routing diagram. The diagram on the 2003 Chevrolet Impala is on top of the fan shroud. The diagram will be a picture of all of the accessory pulleys and how the serpentine belt is routed among the pulleys. This diagram will give you the exact direction for routing the new belt onto the pulleys. If you cannot find a serpentine belt routing diagram, take a notepad and pen and draw out the exact routing diagram of the old belt across the pulleys.
  • 2 Locate the serpentine belt tensioner. It is located below the alternator on the left front side of the engine. The tensioner on the 3.4 liter, 3.5 liter and the 3.9 liter engines will require a 3/8 ratchet to release the belt tensioner. The 3.8 liter engine will require a ratchet and a 15 mm socket for the belt tensioner. Rotate the belt tensioner clockwise to loosen and remove the belt from the belt tensioner pulley.
  • 3 Slide the old belt from the belt tensioner pulley. Remove the belt from the remaining pulleys and pull the belt from the engine compartment.
  • 4 Route the new belt across the crankshaft pulley first. The crankshaft pulley is the big pulley on the bottom of the engine in the center. Then route the serpentine belt across the remaining pulleys as directed by the serpentine belt routing diagram. Leave the belt tensioner pulley for last.
  • 5 Rotate the belt tensioner clockwise again to relieve the tension and slide the new belt across the top of the belt tensioner pulley. Release the belt tensioner and the belt will tighten up as the tensioner applies pressure to the belt. Make sure the new belt is properly seated in all the pulleys.
  • 6 Crank the engine and inspect the belt again to make sure that it stays seated in the pulleys.
  • Read more: How to Replace a Serpentine Belt on a 2003 Chevrolet Impala ' eHow.co.uk http://www.ehow.co.uk/how_6120665_replace-belt-2003-chevrolet-impala.html#ixzz1Yi6QLAjb
    Sep 21, 2011 | 2003 Chevrolet Impala
    Need a belt routing diagram for a 15.5hp craftsman kohler command model #917259542
    With the model number you have you can search for craftsman parts and go to sears and enter the model number and select the deck and find the replacement belt routing sticker for your deck. It goes on the top, left, front.
    The belt comes from the motor pulley in between the pulleys in the middle and around the back of them, then out to the front side of blade pulleys, around the outside and straight across the back from blade pulley to blade pulley. Not a hard routing. If looking down on the deck from the seat it will look like an inverted T. Watch out for the belt keepers that help keep the belt aligned in the pulleys, may need to gently retract them to get belt in the pulley.
    Jul 07, 2011 | Craftsman Garden
    Need a diagram for a 99 toyota corolla serpentine belt
    • Here is the serpentine diagram for a 1999 Toyota Corolla with and without AC.
    • Thank you for using FixYa
    Regards, Tony
    Jun 19, 2011 | Toyota Corolla Cars & Trucks
    Dryer belt diagram how it goes on pulleys
    usually 2 small pulleys one on tension-er spring push it in or you can not get belt on
    belt makes an S on small pulleys one of the pulleys is the motor most belts are grooved flat side to dryer drum grooved to motor pulley flat to tensioner pulley do not flip belt
    Jun 09, 2011 | Kenmore 98702 Stacked Washer/Dryer
    Need to know the routing for the pulleys on a 2001 chevy cavalier 2.2 liter engine serpentine belt. I already have the belt and I'm working on putting it on now, but I really need instructions or a diagram...
    Helllo there:
    Simply click on the links that i have provided and the routing diagram will be there ok
    2001 - 2001 CHEVROLET CAVALIER - L4 2.2L 134ci CNG FI N 5
    Belts / Tensioners / Pulleys Part Number Description 5050630
    Belt Routing Diagram Multiple Accessory, w/o A.C. 5050888
    Belt Routing Diagram Multiple Accessory, w/A.C.
    Dec 27, 2009 | 2001 Chevrolet Cavalier
    Pulleys are shredding belts on my van... just want a diagram with the names of the pulleys... Thanks!
    they are not align well that is why the tension is ripping your belt try aligning before spending money buying new ones thank you
    May 26, 2009 | 1996 Dodge Caravan
    Do you have a diagram on routing the drive belt?
    The diagram on the right in this link provides the exact diagram/pic. for your car. The link is to a site that explains how to convert earlier NG models (which had an extra center idler pulley) to a shorter belt, ala the newer models such as yours which had eliminated this idler. See also, this site for additional information. Another diagram is here with part numbers for the pulleys and the belt. This is about a one hour job to replace the belt and one or two pulleys. Ensure the pulleys are lined up correctly to avoid throwing the new belt when you start it up.
    Mar 28, 2009 | 2000 Saab 9-3 Viggen
    Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
    42 people viewed this question
    Top Craftsman Garden Experts
    Wade Mobley
    Wade Mobley
    Dean Gruber
    Roland W VanLue
    Roland W VanLue
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
