Question about Refrigerators
Ge tbx18ja refrigerator
The freezer was working the the fridge was not. I cleaned the coils, which were very dirty. There was ice in the back of the freezer, so I thought the defrost might not be working. I let it completely defrost. Now when I plug it back in, nothing works. Is there anything that might have 'tripped' a safety type switch, or any other ideas?
peyton32034
  • 410 Answers
SOURCE: GE TFX27PF refrigerator and freezer still not getting cold enough
the partial frost pattern is an indication of low refrigerant, restriction or bad compressor. if the unit is under 5 years old this repair will probably be under warranty thru GE. if out of warranty then you are looking in most cases between 200-500 dollars for repair. good luck Thanx peyton
Posted on Jan 30, 2009
Maytag317
  • 1136 Answers
SOURCE: refrigerator not cooling enough and freezer has ice on back wall
HI, You will need to remove the rear inside panel of the freezer and check the defrost heater located on the bottom of the evaporator coils, for continuity. If the heater shows a break in it, replace the heater. If the heater checks out ok, check the bimetal switch that is located on the top of the evaporator coil. It has to be tested while it is cold. Check coninuity and if is shows the switch is open, replace the bi-metal switch.
If the heater and bi-metal check out ok, you will need to replace the mother board.
The heater is the nost common issue with this model.
I hope this helps you and if I can assist you further, please let me know.
Vic
Posted on Jun 28, 2009
SOURCE: GE GSL22JFPH BS refrigerator, coils icing up
I'm in the process of fixing the same problem on a GSS22JEPDWW right now. There are several parts in the defrost circuit that I can tell:
1) Defrost Heater
2) DefrostThermostat
3) Temp Sensor (Thermistor)
4) Main Control Board
I've replaced the Defrost Heater (remove back panel of freezer section - it's a stainless steel bracket that has a glass bulb in it) and it still doesn't work. The main control card provides power to the heater 4 times every 24 hrs for 25 minutes or so to defrost the evaporator coils. If all items are working, you'll see water in the drip catch at the bottom inside of the freezer compartment. Better yet, pull the refer away from the wall for 24 hrs and check if water is gathering below the plastic drain on the right rear of the refer in the pan. The water drips into a pan and the fan for the condensor coil evaporates it. Go to the www.ge.com website and look in the service section to find the parts diagram for your refer. You can then get a part number to buy the parts you need from a local parts store or the Internet.
I just bought the thermostat a few minutes ago and will try that next. Heater was $37, thermostat was $15. Sensor is about $20 and the control card is $140 (you can find on line for $95). I'm going down that path. If none of this works, it'll be in the dump in a week.
I've learned on-line GE refers are bad news. The control cards can fail repeartedly, althoough mine has worked for over 4 years. But, I won't ever buy another one since refers should last at least 15 years in my book. After $200, it doesn't pay to throw more good money after bad. I'll keep you posted on my results.
TM
Posted on Jun 25, 2008
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
  • 56 Answers
SOURCE: GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
Posted on May 30, 2009
Freezer side and fridge side not working, temps are freezer 30 fridge 50
Most likely the condenser coil is dirty. It is under the fridge, clean it with a vacuum, or air pressure, blow it out outside it will ne dusty . There are two to three fans. One by the compressor, called a condenser fan. If it is a side by side, usually there is a fan in the freezer section, and one in the refrigerator section. All need to work. If all this is and the compressor is running then chances are the compressor has bad valves. Make sure there is no ice on the coils in the refrigerator and freezer coils. If there is ice you have a defrost problem, which can be fixed. If the compressor has bad valves, get a new refrigerator.
May 08, 2014 | Maytag MSD2454G Side by Side Refrigerator
Frig stopped cooling. Light works, freezer works, can hear freezer fan. Doesnt seem like air flow is getting to fresh food area. Freezer back wall has thin line of frost on it. Model tbx18ja. I want to...
Easiest way is to push against the vertical portion of the ice tray holder until it slides
off the buttons which are inserted into the top of the freezer compartment.
These models sometimes had issues with defrost timers (which I just replaced one today) and Defrost termination thermostats (which is clipped on to a tube behind freezer panel).
Make sure the freezer coils are not frozen up solid, if so use a hair dryer to defrost them
and make sure the vent is not iced over.
Model and serial are in the lower compartment on the left wall. In case you need to go to
the appliance parts store.
Hope this helps.
Aug 02, 2011 | GE J Series 18.2 cu. ft. Top Freezer...
Side by side ge fridge model number gss22kgpabb. not cooling on either side freezer is cooler than fridge side but not cold enough to make ice. What do I do to troubleshoot. Also has a slight layer of...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 02, 2011 | Refrigerators
My GE Profile fridge has ice built up in the fan ....i have used a hair dryer to melt the ice. Is there a faulty part in the fridge?
heatman101
Jan 27, 2011 | GE Refrigerators
GE Profile Performance: Fridge rose in temp to the point where milk is spoiling. Now Freezer is going up in temp as well. Ice is melting and food is no longer frozen. Ice forming on the back wall of...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 30, 2010 | GE Profile Performance 25.2 cu. ft....
Fridge is clicking and getting louder it is a GE freezer on the botton and fridge on top with an ice maker in the freezer. Have unpluged and pluged back in but still doing it.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 16, 2010 | GE Refrigerators
My freezer is working but not like it was and my fridge isnt working...also ice maker is not making ice
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
heatman101
Jul 11, 2010 | GE Profile PDS22MHR Bottom Freezer...
GE refrigerator is not working. the lights are on in the inside of fride and freezer but the fridge isn't running. My external digital temperature controls, water dispenser, ice cube dispenser, is not...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
qrtgfs
Jun 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Not cooling freezer or fridge, not making ice. fan is running
heatman101
tryr67
May 27, 2009 | GE PSS25NGM Side by Side Refrigerator
Can't find refrigerator coils/ cooling issues
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Apr 21, 2009 | Refrigerators
Refrigerators Logo
237 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
