Http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01465973&lang=en&cc=us&contentType=SupportFAQ&prodSeriesId=3733093&p
witch card to wan't to remove.remove the scruws holding the card in the chassi and watch up for hook or lock in the cards front.BE CAREFUL.ALLWAYS REMOVE THE ELECTRIC CORD SHUTDOWN PSU.NO LIGHTS ON THE MOTHERBOARD.
Http://www.fixya.com/support/t17978814-remove_wireless_card
Regards,
joecoolvette
What about Static? What about the English language?
yes what about the english.from a man who needs use ugly words to express himself.let's keep us to users problem bad english or not.
A) What 'ugly' words? B) So you're stating it's okay to Static shock out the hardware components, of this person's computer? No reason to caution them? (Edwin Rulds or brother, hmmm?)
Turn the laptop over and remove the battery.
Remove the screws that are used to secure the memory/wireless LAN minicard cover with a Phillips-head screwdriver. Lift the edge of the cover to remove it.
Disconnect the antenna cables from the wireless LAN minicard with the needle-nosed pliers.
Locate the screws that are used to secure the wireless LAN minicard to the motherboard and remove them with the Phillips-head screwdriver.
Pull the wireless LAN minicard out by grabbing the card by the edges.
Reinsert the wireless LAN minicard and push down on the card to set it in place.
Tighten the screws to secure the card to the motherboard.
Replace the antenna cables with the needle-nosed pliers.
Replace the memory/wireless LAN minicard cover and secure it with the screws.
Replace the battery and then turn on the laptop. Windows Vista will load and reinstall the drivers for the ISATAP adapter.
hope this helps
Get online
and got to www.google.com In the google search box type: "Toshiba
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Download and install the Network drivers.
Make sure the wireless switch is turned on.
Maybe you don't have your wireless turned on. Look on
both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle
the wireless on or off. Normally you would Press and Hold the FN function
key located at the lower left of the keyboard, then hit the correct F1 thru F12
key that toggles the wireless. The correct F1 thru F12 key to hit will
have the wireless signal icon )))) on it. Or it might have the icon of a tower
with the wireless signal icon )))). Normally the screen will display
Wireless On or Wireless Off when you toggle the wireless.
Still not working?
If you still have problems then turn the laptop off, remove the power
cord, remove the battery, then remove the cover that houses the wireless
card on the bottom of the laptop. Remove the antennas (2 cables) from
the wireless card (remember how they go so you can put them back later),
then remove the wireless card from the slot ( it might be secured by
one or two screws you have to remove). After about 30 seconds put it
all back together and reboot. Sometimes reseating the wireless card
will make it work.
