Question about Home
Aqua whirl lr-47939 info
The timer works but the jets dont turn the water / push the air thru the jets
3 Suggested Answers
  • 4336 Answers
SOURCE: My jetted tub motor will run, but it will not push
It kind of sounds like you have not purged air from near the pump impeller. Try adding water through the filter, often times this forces prime.
Posted on Jan 16, 2011
  • 96 Answers
SOURCE: I have a Royal Whirlpool
You have a bad neumatic switch. Or a small hole in the air line. Try pushing the button fast and hard to see if it will stay on. if so , it is a hole in the tube. if not it is your neumatic switch
Posted on Mar 24, 2011
Testimonial: "perfect! Thanks for your help"
I have an aqua glass pump model #F42E92A03 I'm trying to remove the timer circuit to use the pump for a pond application. The motor is 110v has 3 wires red, back. White.
I couldn't find any info in that pump model, looks like some kind of jet pump but most likely the time was controlled by an outside timer that controlled the power to the pump. Wherever the power button was that's where the time is. Well anyway that things probably too powerful for a pond lol
Jun 07, 2015 | Pool & Spa
Aqua Glass whirlpool, Indulgence collection, pump turns on and works briefly, then jets stop.
First of all, what you have is a WOW pump that has an E-switch for a control.
There is a knob on the top lip of your tub that you turn a 1/4 turn to turn this pump on/off.
There is a small circuit board inside the box on top of the motor. This is likely the source of your problem.
Here is your biggest problem. That little circuit board is not made anymore. We have the e-switch but you will be better off changing out the pump (which you have to do anyway) with a new WOW pump with an air switch and change the switch on the top lip of the tub to an air button which will turn the pump on/off.
Rod
US Parts Center
Apr 13, 2014 | Whirlpool Safety Bath Walk In Bathtub -...
Melnor 4 zone aqua timer dosent follow program
Water timers and Melnor timers last a year or two. They come with 1 year warranty for defects in workmanship.
Change batteries, reset timer if there is a reset protocol, buy another timer. Melnor, Orbit, are major brands. Gardena is not supported. Yardworks repackages other brands.
Copy following link for all watering and irrigation timers on market, with links to manuals for each brand:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Add a comment and say what you find.
Jun 20, 2013 | Aqua Hardware & Accessories
Our jets turned on by themself and we don't know how to turn them off? What seems to be the problem?
Hi i will need more info to tell you why they turned on. The most simple way to turn off is with the breaker. That would be in a elctrical subpanel located by the pump and equipment or sometimes all the way from the house main breaker panel. So what i need to know is this:
1. What do you have ? a above ground spa, a in ground pool and spa or a in ground spa only.
2. How do you turn all your equpment on and off like your booste(jet)pump? meaning is it a manual system with a timeclock or does it have a control system where you turn on and off from a button in the house or lastly is there like a single button located in the spa above the water line that pushes in about a half inch.
If you dont reach me back than heaR are some of the answers and solutions:
1. If you have a fancy control system where you turn your stuff on and off from the house than the majority of those have built in freeeze protection so if it sees or thinks the air temperature reches about 38 to 45 degrees than it will turn on the pumps so they move water and it doesnt freeze in pipes. Likewise actually there is a little add on to a simple timeclock operation as well that would do the same thing. IF THATS IT THAN AS SOON AS THE TEMP WENT ABOVE THAT EVERYTHING WOULD GO BACK TO NORMAL. OR IF THE AIR SENSOR IS BROKEN OR MISREADING THE ACTUAL TEMPERTAURE OF THE AIR THAN THAT WOULD GET REPLACED AND EVERTHING BACK TO NORMAL.
2. If you have a fancy control system than where the pump connects to which is called a relay could be stuck. THAN YOU WOULD JUST NEED TO REPLACE THE RELAY.
3. If you have a fancy control sytem and as part of it there is whats called a spa switch located typically by or in the spa and there either round wsith 4 push buttons or rectangle with like 8-10 buttons. WHEN PART OF THAT GOES BAD AND WATER GETS IN IT THAN IT CAN SHORT CIRCUIT AND OR MAKE FALSE3 CONTACT AND THE DEVICES IT CONTROLS WILL END UP HAVING RANDOM PHANTOM LIKE OPERATIONS THINGS TURNING ON OR OFF BY THEMSELVES. THE FIX IS EITHER DISABLE IT IF YOU DONT USE IT MUCH OR NOW ISNT A GOOD TIME FINANCIALLY OR REPLACE IT.
4. Lastly if its one of those single usually white push buttons that pushes in about half to 3/4 in. Than that is whats called a air switch and it blows a little puff of air thru a small tube behind it to a box near the pump and activates a relay there to turn it on and off. SO WHEN WATER OR CONDENSATION GETS IN THE TUBING THAN IT CAN DO THOSE SAME PHANTOM LIKE OPERATIONS I EXPLAINED IN NUMBER 3. THE FIX WOULD BE A NEW SWITCH OR PULLING THRU NEW TUBING AND CONNECTING ETC.
Good luck. This is only the second question i have answered for folks so i dont know how the website all works but if you are able to get me the info than i can pretty much pin point it for you. Merry Christmas
Dec 23, 2010 | Jacuzzi Pool & Spa
I have the zuma whirl pool tub. the jets go on
This is an automatic feature to dry out the pipes and prevent mold. The next time you turn on the pump after leaving these tubs for a few weeks you get lots of black **** in the water and this is what this feature prevents. Sounds like the tub is working fine :)
May 23, 2010 | NRS Zuma Tub Only - R7236T - Standard
I have an old AquaWhirl tub that was out of commission for several months because of a breaker problem. I replaced the breaker but when I turn on tub I get 5 seconds of normal whirl followed by a big burst...
Due to your tub setting for a long period of time, you have a simple air lock in the jet hoses.
Find the pump - locate the jet farthest from the pump and using a funnel slowly pour water in that jet until water starts coming out of the other jets.
Turn you tub on it should work fine. If this does not solve your problem you may have to loosen the top hose at the pump and allow the air to escape while being replaced by the water you are pouring in
Mar 05, 2010 | Home
My yamaha jet-ski is in learning mode. how do i turn it off?
Its going to ask for a code!!If not lift the seat find the blue plug un hook it then hook back up it will ask for code push AAA then hold it will reset it if this is digital odomtor
May 31, 2009 | Yamaha 12V Air Pump
Some of jet points inside jacuzzi are not mixing air with water
the jet are pushed by the impeller (it's like a fan blade) run by a moter water is pushed through the plumbing and out the jet head . when you open an air valve air is mixed in .
Feb 03, 2009 | Pool & Spa
Home Logo
134 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
