Benq shadow dark shadow on gl2250 benq monitor after being on few seconds
viziks
  • 220 Answers
SOURCE: flickering then off
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Samir
Posted on Sep 20, 2008
  • 16 Answers
SOURCE: monitor goes dark
If the power light turns yellow, there is no signal being received by the monitor from your computer's graphics card. The screen will shut off (go into idle mode), which is a low-power state, that saves energy. Check that the cable on the back of your computer is plugged into the right graphics card (many PCs come with more than one, these days). There may be one built into the computer's mainboard, and another one may be on a separate graphics card located somewhere else on the machine. Only one of these will work on startup. If one doesn't work, try the other.
Posted on Apr 23, 2010
budmrtn
  • 11361 Answers
SOURCE: Monitor keeps going dark for a few seconds then co...
Look for bad caps as shown in my pictures, worst case can be bad lamps assemblies, see pictures of bad lamps album.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 23, 2010
electrotech1
  • 1126 Answers
SOURCE: the monitor powers up and the ACER screen appears,
The power supply caps need replace on power supply, or replace power supply.
Posted on Oct 14, 2010
SuperTech-11
  • 1591 Answers
SOURCE: I have a problem with
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 05, 2011
Screen flickers at 1920x1080
are you using hdmi? if so it might be the cable.
Sep 02, 2013 | BenQ GL2250 21.5 WIDE LED MONITOR
I was playing Fallout 3 and after a while, my screen turned a bit darker, not really dark but as if there is a light shadow on it and after a few seconds it turned black. I tried to press twice on the...
try shining a torch/flash light on the screen
If, when the flashlight is on the monitor, the problem is fixed then you have aback light issue.
You will have to contact your manufacture or shop you bought it from
Mar 04, 2011 | ViewSonic VX1940w LCD Monitor
Where can I buy a logic PCB for FP71G Benq
Shenzhen VIIV Technology Co., Ltd is an expert at PCB,PCBA and Rigid Borad manufacturer based in shenzhen China.
MSN:viivtech@msn.cn
Yahoo: viivtechavril
SKYPE: viivtech
Mobile: 86)15989403359
Email:avril@szviivtech.com ,zhwei930@163.com
Website :www.szviivtech.com
Tel: 0086 755-29477736
Fax: 0086 755-29410695
ADD: sha
Jul 13, 2010 | BenQ FP71G 17" LCD Monitor
I have shadow to the right of my text on my newly installed BENQ G2220HD monitor. How do I fix this problem?
You need to set your PC video resolution to the native resolution of this monitor, 1920 x 1080 @60Hz for best picture.
Apr 21, 2010 | BenQ FP93GX (Silver, Black) 19 inch LCD...
My Benq screen shuts down 10 seconds after switchung on
it may be overheat or check the cables it will properly connect or not(may be loose connection or damaged).
click this link for more info
Feb 22, 2009 | BenQ FP731 17" LCD Monitor
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
Flickering then off
Samir
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Dark disp-lay
sorry mate,that is dreaded power interter board inside lcd,read about similar benq model dramas here http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
Jun 03, 2008 | BenQ T705 17" LCD Monitor
Powers up temporaly displays goes dark
Your monitor has a bad back light. Send it back to your friend
Nov 22, 2007 | BenQ T705 17" LCD Monitor
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
