Question about Sewing Machines
Jcpenney 6945 sewing machine
STITCH LENGTH DIAL STUCK
  • 323 Answers
SOURCE: reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Posted on Jun 05, 2008
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
  • 1027 Answers
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Posted on Jul 10, 2008
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
  • 55 Answers
SOURCE: bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
scott
Posted on Jul 27, 2009
How to zig zag on a janome sewing model 385.4052LX200 what numbers do I set the length dial and the stitch dial on
It really depends on what you want your stitch to look like. A longer stitch length will put more space between the stitches. Shorter stitch length will close the gap between stitches. Stitch width determines how wide the stitch will be.
Mar 11, 2018 | Janome Sewing Machines
Singer 6510 3 dial machine - no "S" on stitch length dial selector
Lower numbers moves the fabric further for each time the needle penetrates the fabric. . If you raise the number you will get more stitches per inch which means your fabric is moving more slowly. Try moving the number to different locations for examples. If you are attempting to make something so it will stretch you are probably wanting to use a zigzag stitch. A wide zigzag stitch will allow a longer stretch than a less wide zigzag stitch.
Dec 23, 2014 | Singer 6510 Sewing Machine
Singer sewing machine
From the pattern selector (the bigger dial), select the zig-zag stitch. Then, using the stitch length dial (the smaller dial), adjust the stitch length. The closer your stitch length is to "0", the more dense will your zig-zag stitch be.
Sep 04, 2014 | Singer 2250 Tradition
TRADITION 2250 SINGER SEWING MACHINE HOW TO ZIG ZAG
Stitch length dial is stuck on SS
Likely broken threads wrapped around internal components. Have it prefessoinally serviced.
Jan 09, 2014 | Brother XR-65t Mechanical Sewing Machine
Janome sewing machine dial moves
I have exactly the same problem. Did you find a solution? If so I'd be really grateful to hear it ... Thank you.
Oct 23, 2012 | Janome Sewing Machines
How to change stitch length on j c penny kenmore model 6945
Kenmore is a "Sears" brand.
Try your search on the Sears/Kenmore parts area. Or call the kenmore hotline. (usually the stitch length is marked from 0-6 or so.) Depending on the year of the machine... it could be near the reverse button.
Oct 03, 2012 | Kenmore Sewing Machines
My Kenmore sewing machine model number is 17630, & when I try to set the stitch length from a Straight Stitch setting to a Straight STRETCH Stitch setting, there isn't any difference. I have the length...
Take a look at the stitch length dial. If you turn that dial counter clockwise (to about 7 o'clock), it will set to stretch stitch. Then all of the stretch stitch features will work. When you want to go back to straight stitching, just move that dial back to what ever stitch length you wish.
Nov 26, 2010 | Kenmore Sewing Machines
Viking 2000 6430? sewing machine, only sews in reverse.
Your stitch length dial is stuck. Your machine is in need of oil. If you open the back of your machine and see the bit that moves when you turn you stitch length dial. oil that bit and warm it with your hair dryer. It should become loose. It take a bit of warming and working the oil into the machine. You have to repeat this process a few times.
I do have the service manual at sewingnz@gmail.com
Jan 25, 2010 | Husqvarna Sewing Machines
Where is ''S'' on the stitch length dial shark Europro 7133
Hi Queen,
on the stitch length dial on the top right of the machine, turn it all the way left. When you get to 0 and think it stops, keep turning, you'll get to the S.
Good luck,
Diane
Apr 01, 2009 | Euro-Pro Shark 80 - 7133
Sewing Machines Logo
74 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
