Question about Dryers
Age of TEDS740PQ dryer - Dryers
My dryer doesnt go on. The front panel still clicks and when i push start button it buzzes but doesnt go
Belt, fuse, door switch, timer switch, something caught on the drum (all sorts of things get caught back there), heat sensor (depending on the age, had one that had a heat sensor would turn the dryer off, if told the computer dryer was overheating even though had not been running), bad motor, bad motherboard for dryer (again depending on age of dryer)
Jan 06, 2015 | Dryers
I am trying to determine the age of my Kenmore gas dryer- Series 80 model 11070802990 ser MK 1715724
There is a web site, appliance411.com, which helps to identify the age of major appliances. I have gone there and looked up your dryer, it appears to have been manufactured in April of 2000.
Aug 02, 2013 | Dryers
What year was electric kenmore dryer 110. 86574110 65741 made?
The year and approximately the month Whirlpool and Whirlpool-made appliances can be determined from the serial number. The second letter in the serial number indicates the year while the first two digits of the number indicates the week the appliance was made. Locate the serial number then click on the link below for the details on how to determine the age of your Whirlpool-made Kenmore dryer.
Determining the Age of Dryers and Washing Machines Made by Whirlpool
Apr 08, 2011 | Kenmore 75944 Gas Dryer
Can you tell me tha age of a dryer if i have m and s numbers of unit if so m 110.72062102 s mr1304865 kenmore
The dryer is made by Whirlpool and its age can be determined from the serial number. The second character (R) is the year while the first 2-digit of the number (13) is the week on that year the dryer was made. The dryer was made on the 13th week of the year code R which is 2004. The dryer was made approximately on April 2004, about 7 years ago. Click on the link below for further details on how to determine the age of dryers and washers made by Whirlpool.
Feb 23, 2011 | Kenmore Dryers
10 year old Kenmore dryer Series 80 suddenly has stopped producing heat. Vent is clean. What else can I try?
On a gas model dryer those coils seem to die when heated when they have a little age on em. So if the ignitor works and the dryer does a little bit of heating then fails and it is gas then those coils are the problem. On an electric model the element will get brittle with age and die but if your dryer is suffering from air restrictions it may have had a limit trip on it.
I have a service manual and more of a Kenmore /whirlpool style dryer HERE
Jan 18, 2011 | Dryers
No heat during the dryer cycle
There are several things that can cause a gas dryer to have no heat. I can walk you through how to test the components if you have a bit of mechanical ability and an ohmmeter to test with. I will list the suspects here but to narrow it down we need to do a bit more troubleshooting.
Thermal fuse or thermal cut off - these two components can trip if too much heat builds up due to lack of air flow, usually a restricted vent.
Gas valve coils - these can fail as a result of age
Gas valve ignitor - This can fail as a result of age or vibration
Control/timer contacts - Fails due to age or heavy use
Let me know how deep you want me to go as far as troubleshooting with you on these and I would be happy to assist.
Apr 24, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I want to know the age of my dryer model #de485rw ser #7339818
I want to know my dryers age model #fer341ac0
Apr 21, 2008 | Dryers
Dryers Logo
18 people viewed this question
Top Dryers Experts
