Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Briggs I have a Briggs & Stratton Riding mower. Model 287708 Type 022701. It is leaking oil from the bottom seal. How do I remove the bottom pulley from the crack shaft and how hard is to replace the gasket?"
    Sergeant:
  • 416 Answers
The pulley just bolts on
9/16 i think
may have to use pipe wrench to hold shaft of pulley
spray top of pulley with PB blaster should slide off might have to tap it some
Posted on Oct 17, 2013
  • 130 Answers
SOURCE: briggs & stratton 190707 wiring diagram
make sure your coil has not move ajust to 010. gap check magent on flywheel.see if strong.if all is ok yes coil is bad
Posted on Jul 22, 2009
rwvanlue
  • 486 Answers
SOURCE: Briggs & Stratton 6.75 lawnmower. Won't start.
1) Determined that there is spark?
2) Have you used a type of spark tester?
3) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug,
it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel
cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Nov 26, 2009
  • 7 Answers
SOURCE: New Craftsman 20hp Briggs & Stratton 42
first make sure the air intake screen on top of engine is not clogged with debris if thats not a concern you could have a faulty ignition coil etc your engine should have a two year warranty and can be serviced at no charge to you at your local briggs service dealer make sure and check your manual for the fine print though. Briggs makes a great engine and very rarely have I ever seen a problem allthough if you were to have an engine issue it will accur during the first few hours of opperation good luck
Posted on Jan 25, 2010
rycgl
  • 1545 Answers
SOURCE: What type of oil do
Only use SAE 30 if using conventional oil. Briggs is real specific about that. I highly recommend using synthetic oil in ALL lawn equipment. You can use a multi-viscosity oil like SAE 10W-30 if you use synthetic, but straight 30 weight if using conventional. The brand is up to you.
Posted on Jun 08, 2011
  • 640 Answers
SOURCE: were can I GET a maintence manuel for briggs and
You can go to the Briggs and Stratton web site and to the upper right corner of the page, enter your engine model number, 31p777, when following page comes up scroll down to match with the type number, 0296E1, then you will be able to view all supported materials, this will get you to a screen to download operator's manual and an illustrated parts list.
If you have any more trouble with this just let me know and I will get you straighten out.
If you found this post to be really helpful, please rate four thumbs up.
Posted on Jul 14, 2011
6.5 briggs and stratton leaking motor oil through the filter area
How does it run? Is it back firing through the air filter box area? And although your stating it is oil is it actually oil or gasoline that is black due to getting dirty? Don't shoot me! I'm going on what information I'm reading what you submitted. If oil is it enough to show up quickly on the dipstick/engine oil level ? Get back to us and we can go further.
Nov 23, 2013 | Briggs & Stratton 491056 492932 Briggs ...
Briggs & stratton 18hp model 422777
check around the sump breather pipe. When you replace the bottom seal it is advisable to inspect the shaft as if there is a groove there the new seal will not work as intended.
Jun 23, 2013 | Garden
Ariens 1640 Zoom Riding Mower with Briggs & Stratton engine smoking
check to see if the oil smells like gas the needle valves go bad in the carb and gas over flows into the crank case also the head gaskets go bad and **** the oil from the crank case
May 08, 2012 | Ariens Garden
I bought an Ariens, model #921031 Deluxe 24 with a Briggs & Stratton engine brand new online and haven't used it yet. It's been sitting and now I have a puddle of oil under it. The place t
Some times, the seals not sealed yet not being run. Check all your oil and gear oil levels and run it. Hope everything will be ok then.
Feb 10, 2012 | Briggs & Stratton Garden
Can you please advise which oil to put in my B & S rideon mower. Model 261777 Type 013801
Hi verndono,
Briggs and Stratton recommends to use SF or SG. SAE-30 or 10w-30 oil for temps above 40F (4C) , SAE 10W oil for temps between 40F (4C) and 0F (-18C) and SAE 5W-20 (or 10W oil diluted with 10% kerosene) for below 0F (-18C). I suggest you use 10W-30 or SAE-30 and you will be good to go. Hope this helps. Best regards. Denis.
Mar 01, 2011 | Briggs & Stratton Garden
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Can't find oil filter model
there's 2 possible models... depends on the length of the filter..
one is 2 1/4" long Model no.492932 and the 3 1/4" is no. 491056
you should be able to order online at briggsandstratton.com
May 25, 2009 | Briggs & Stratton Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
