Question about Emerson LC320EMXF 32 in. LCD TV
Emerson hdmi what wires need to be connected to it to get just the anntena channels?
    Top Expert:
  • Emerson Master
  • 74,482 Answers
Refer its instruction manual.
Posted on May 02, 2013
My mitsubishi tv has a phone jack looking plug then a anntena plug part , how do i hook up a dvd player to it
it could be an HDMI port for connecting HDMI cable. If your DVD player has HDMI output then you can connect it.
or it could be a usb port for playing videos from usb devices like pen drives and portable hard disks
i dont think tv has a phone jack
Feb 28, 2016 | Mitsubishi Televison & Video
Emerson LCD TV Model LD190EM1 Sony Blu-Ray Disc Player, Model BDP-S3100, The TV screen gives an error reading "Format not supported" when I connected it using either HDMI connection.
This HDTV is rated display signals up to and including 720P resolution according to the spec linked below. If you are outputting a 1080i or 1080P signal from your BD Player, this could be the cause for the error message. Many HDTVs will accept signals higher than they can display - and simply down-rez to the highest resolution that they can display.
Connect the BD Player to a device that can display the signal. Enter the player's setting and change the output to 720P. Shut it off / disconnect cables as needed and reconnect it to the Emerson HDTV and see if it will display properly.
If it does, you're all done! if it doesn't - there's something else going on that isn't readily apparent to me. Good luck!
Emerson LD190EM1 Specs CNET
Mar 03, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
Connect to direct tv
did you go into the source menu on the tv and go to the hdmi no.you have the hdmi wire plugged into
Feb 07, 2015 | Emerson LD195EMX - 19" LCD TV
How do I get channels on my Emerson tv with dvd? I have tried everything I could think of and I only get channel 23 and that is kinda grainy looking.
I don't understand the question. Why do you need channel settings for the DVD? Are you asking what channel to play the DVD on? It won't be a TV channel, it will be a separate video input source setting, usually found on the remote. The TV may show Video 1 or HDMI for the source in order to watch an external source like DVD.
Sep 27, 2014 | Emerson Televison & Video
I HAVE A NEW 20" eMERSON TV. I JUST BOUGHT A wii SYSSTEM AND HAVE THE 3 COLOR CODED CABLES INSERTED. tHE CABLES ARE RED WHITE AND YELLOW, THE TV ONLY HAS RED WHITE AND ORANGE! I CANNOT FIND A CHANNEL...
You should order an hdmi cable for the WII so that it will connect. Right now you have audio (red and white) and video (yellow) the new television sets dont use that anymore.
Nov 18, 2013 | Emerson EWF2004 20" TV
Need to connect a laptop to an emerson lcd color tv model #LC320EM8. Which cord to I need?
HDMI cable will work great just plug the HDMI into the laptop and into the TV then select the HDMI for the input and you should be good to go
Dec 30, 2012 | Emerson LC320EM8 32 in. LCD TV
Digital tv tuner not displaying picture
. Try putting you tv set to channel 3 or 4. Try your tv in all modes. Check the back also to see if in the right spots with the wires. Check your channel scan status, try it on anntena and try it on cable, run channel scan on both. good luck. Try vcr wires if cable wires dont work. vcr wires are yellow red and white. Try another cable cord sometimes they get old. Try looking at your remote and setting it to tv.
Sep 02, 2012 | Panasonic PT-50LCX63 50" Rear Projection...
AV NOT WORK
You need to give more info. Try putting you tv set to channel 3 or 4. Try your tv in all modes. Check the back also to see if in the right spots with the wires. Check your channel scan status, try it on anntena and try it on cable, run channel scan on both. good luck. Try vcr wires if cable wires dont work. vcr wires are yellow red and white. Try another cable cord sometimes they get old. Try looking at your remote and setting it to tv.
Sep 02, 2012 | Hitachi C21 F800S TV
My Emerson 19 inch flat screen has picture but no sound
Hello!
I need more information on how to fix this. Are you connected by a componet, composite or HDMI cable? For the componet or composite, make sure that the red and white inserts are connected to the right channels and that they are inserted all the way in. For HDMI cables, just check to see if you have a solid connection to your TV or video source.
If any of those does not fix the problem, you need a new sound cable. These are easy to find and cost relatively cheap. The most expensive would be your HDMI cable, which costs around $30 for a 3 foot cable. If that doesn't fix it, either your TV or your sound card to the video source is bad and you may need to have it repaired by a licenced repair person.
Hope that helps you. Good luck!
Jun 27, 2012 | Emerson Televison & Video
Emerson LC320EMXF 32 in. LCD TV Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
