HOW TO GET TO BIOS SET TO FAST MODE - Computers & Internet
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 96 Answers
Sir Which motherboard or BIOS you are using. To set the BIOS fast you have to disable Power on self test (POST)
Posted on May 01, 2013
I'm trying to help a friend install
After "Fast Boot" has been enabled, you cannot access the BIOS setup during power on . The machine will bypass "Press F2 to access Setup Utiltiy and F12 for Boot Menu" prompt.
This is a bigger issue if the hard drive crashes and access to Windows is not possible OR
Fast Boot can be enabled or disabled in the BIOS setup, or in HW Setup under Windows.
If you have Fast Boot enabled and you want to get into the BIOS setup. Hold down the F2 key, then power on. That will get you into the BIOS setup Utility.
You can disable the Fast Boot Option here. You will need to disable Fast Boot if you want to use the F12 / Boot menu.
Aug 26, 2011 | Toshiba Computers & Internet
How can i access my toshiba satellite L655 bios after setting to fast boot mode.I can not find my f2 to access my bios again
Turn the computer on. If you do not see a prompt to press the F2 key, then immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear.
Jul 21, 2011 | Toshiba Satellite L655S5065BN 156 Notebook...
LAMP KEEP BLOWING OUT. TOSHIBA 65 HM167
I had this same problem with my Mitsubishi it is when you have fast on mode set it pre warms the bulb to much. I turneed it off and now the bulb has lasted much longer Setting the Power-On Mode feature You can select either Power-Saving or Fast mode. If you select Power-Saving mode and you turn off the TV, it can take several seconds for the picture to appear when you turn on the TV again. Power-Saving mode saves more power than Fast mode. See "Specifications" on page 66 for details. If you select Fast mode and the TV is turned off, the TV will stay in Standby mode for several minutes (see Note below). If the TV is turned on from Standby mode, the full picture appears immediately. To set the Power-On Mode feature: 1 Press Y and open the Setup menu. 2 Highlight Power-On Mode and press c. 3 Press b or B to select either Fast or Power-Saving and press T. Note: If Power-On Mode is set to Fast and you turn off the TV, the following will occur for a few minutes: • The screen (lamp) lights dimly; and • The fans continue to run. This is a function of the Power-On Fast Shutdown mode and is not a TV malfunction. If you do not prefer this, set the PowerOn Mode feature to Power-Saving. When the Power-On Mode feature is set to Power-Saving, if you repeatedly turn the TV on and off in a short period of time, the useful service life of the lamp may be shorter than the average useful service life (- page 63).
this is from your manual not my Mitsubishi please rate this answer if you felt it was useful.
Feb 03, 2011 | Toshiba Televison & Video
My neighbor gets a message when he boots up saying to "enter CURRENT password" It happens so fast I can't even get into the BIOS. It's on a black screen with white letters. It will only let you type in 7...
You should remove the BIOS battery inside of the machine and also remove the power and wait for a 15 min.
Then put the battery in it's place and turn your machine on.
When you remove the BIOS battery, the settings of Bios will set in Default mode so the boot password and Bios Password will be removed.
Sep 23, 2010 | Gateway Essential 400C SE PC Desktop
Can not get it installed on Note Book computer
You should go to BIOS and set "mapped as AHCI" to SATA/IDE mode". Find any information regarding AHCI, SATA/ID mode or anything like that on your BIOS. then try to install Windows XP Home Edition
Aug 24, 2010 | Microsoft Windows XP Home Edition
Several different vertical coloured lines down screen
Check in the BIOS mode..
If the lines are in BIOS mode then its a hardware issue with the display of the computer or the motherboard..
Contact HP fast if the notebook is under warranty.
Jun 19, 2010 | HP Compaq Presario M2000 Notebook
I have a Caompaq Armada 7770 DMT that is set to fast boot
om my armada m300 before the boot screen comes up i tap f10 a few times to get in service mode, it mayy not b f10 on urs though, may b f3 or similar.
Apr 11, 2009 | Compaq Armada 7770DMT Notebook
I was formatting my hp(dv2000tu)recovary partion but when i want to install xp by any cd my harddisk ware not detacted but vista is installed with out causing any problem
First is your hard disk a removable one/external hard drive?6ea4669.png if you receive this image, then it probably means you have a SATA hard drive, and your bios is set to Raid/SATA mode.
First, go to your bios settings, then change SATA mode into IDE. This should be under something like "On-Chip SATA".
Or, you can go to http://www.nliteos.com then download the program to install the needed drivers to the xp installation CD.
Hope this helps, and please rate ^_^
Feb 21, 2009 | HP 4.2 GB SCSI-2 Fast Hard Drive
Laptop boots then shuts automatically off
Try this, if you have a fast hand, the second it boots, push Ctrl+Shift+Esc and end taskeng.exe.
If you can't do it fast enough, try booting into safe mode, going to scheduled tasks, and removing any suspicious ones.
If you don't know how to boot to safe mode, push f8 until you see a screen which allows you to choose safe mode.
Dec 18, 2008 | Toshiba Satellite P105-S6177 Notebook
Computers & Internet Logo
David Payne
David Payne
