Junko@hawaiiantel.net - Computers & Internet
My auto trans makes a thud when shifting out of low gear and when shifting from park to reverse or drive. Is this a major problem or a minor one which can be fixed without taking the transmission apart?...
This problem is called slippage. It can be caused by old/burned transmission fluid or something much more serious.
If you are lucky, simply changing the fluid in your transmission will do the trick. Any autoparts store will have a kit that allows you to change your fluid through the dipstick if your transmission isn't equipped with a drain plug (many aren't).
If this doesn't work, then you will have to take your car to a transmission specialist.
I hope this helps.
Aug 02, 2009 | 1995 Buick Regal
Tip
How To Completely Remove .Net Framework
Directions:
  1. Download the .NET Framework cleanup tool
  2. Open dotnetfx_cleanup_tool.zip and run cleanup_tool.exe.
  3. Download and reinstall the version of the .NET Framework you want, .NET Framework 3.5 includes .NET Framework 2.0 service pack 1 and .NET Framework 3.0 service pack 1.
Prerequisites:
Note: If you are installing on XP 64 bit or Windows 2003 you might need to install the Windows Imaging Component. The Windows Imaging Component 32 bit can be found here. The Windows Imaging Component 64 bit can be found here.
on Feb 20, 2011 | Computers & Internet
Tip
Provider SMTP Server 12 012.net.il 191 mail.191.biz 191.it ...
12 012.net.il
191 mail.191.biz
191.it mail.191.it
Access4Less smtp.access4less.net
Active Network smtp.activenetwork.it
Actrix Networks mail.actrix.co.nz
Adelphia mail.adelphia.net
akfree smtp.akfree.it
Albacom relay.albacom.net
albacom smpt.albacom.net
Albacom smtp.albacom.net
alcotek smtp.alcotek.it
alice out.aliceposta.it
aliceposta.it mail.tin.it
alise outmail.f2s.com
AOL smtp.aol.com
Arnet smtp.arnet.com.ar
Aruba smtp.aruba.it
AT & T Wireless smtp.attwireless.net
AT & T Worldnet imailhost.worldnet.att.net
atlanet smtp.weblinea.it
atlanet smtp.atlavia.it
Auna smtp.auna.com
Bahrain Telecommunications Company batelco.com.bh
Barak I.T.C mail.barak.net.il
basilicatanet.it mail.basilicatanet.it
bella.ci bella.ci
Bellsouth mail.bellsouth.net
Bezeq International mail.bezeqint.net
Bezeqint mail.bezeqint.net
Bitstop pangasinan.com
Blu.it smtp.blu.it
Bluebottle mail.bluebottle.com
bluelight.com smtp.mybluelight.com
Bluewin mail.bluewin.ch
BlueYonder smtp.blueyonder.co.uk
bol.com.br smtp.bol.com.br
BRTURBO smtp.brturbo.com.br
BT Internet mail.btinternet.com
BT Openworld mail.btopenworld.com
BTClick smtp.btclick.com
BTTB mail.bttb.net.bd
BusinessServe smtp.businessserve.co.uk
Cable One mail.cableone.net
Cableinet smtp.blueyonder.co.uk
Caiway smtp.caiway.nl
Callsouth - Broadband smtp2.callsouth.net.nz
Callsouth - Dial up smtp.callsouth.net.nz
Cantv.net mail.cantv.net
cegetel smtp.cegetel.net
Chariot Netconnect mail.vic.chariot.net.au
charter pop.charter.net
Charter mail.charter.net
cheapnet smtp.cheapnet.it
chello.pl mail.chello.pl
ciaoweb ciaosmtp.ciaoweb.it
Cingular smtp.mymmode.com
Ciudad smtp.ciudad.com.ar
Claranet relay.clara.net
Clear Net smtp.clear.net.nz
click21 smtp.click21.com.br
Club-Internet smtp.club-internet.fr
collegeclub collegeclub.com
Colt.net (Germany) smtp.ipmail.colt.net
Columbia Power and Water mail.cpws.net
Comcast smtp.comcast.net
Cox - Central smtp.central.cox.net
Cox - East smtp.east.cox.net
Cox - West smtp.west.cox.net
Cultura smtp.cultura.com.br
CWCom smtp.ntlworld.com
See also:
Huge list of SMTP servers D-K
Huge list of SMTP servers L-S
Huge list of SMTP servers T-Z
on Mar 24, 2010 | Garden
Take apart method to replace rubber drive belt.
I had the same dillema, till I discovered a soft spot on the label. They put one last screw there. I got the housing open and discovered the belt was broken. Ordered a new belt ($12.39) through ACE Hardware repair center, now I can't get the belt on. That is why I came to this site.
The Ace guy told me he has had lot of calls for this particular belt. If you order one, I suggest you order two.
Good luck.
Apr 16, 2009 | Black & Decker 14" Grass Hog Xp...
Who repairs the sharper image ionic breeze GP
This is a repair that someone I know didafter reading a post on the net.....regarding Quadra repairs....and here is a link for repairs....its all one link....so type it into your browser or paste it.....
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=34&ProductId=591
Remove the grid assembly.
Remove the 4 screws holding the top on.
Gently remove the top as there are wires connected to it.
Once removed, find the microswitch assembly on the side. There will be 2 green wires going to this assy board (PCB).
Examine the bottom of this board. On both my units, the PCB wascorroded badly on the trace that runs from the center lead to the wireconnection. This will cause the microswitch to quit working.
What I did was soldered a wire from the center contact of themicroswitch (center piece coming through the board. There should be alarge solder pool) to the wire connection at the edge of the board.This just 'goes around' the corroded PCB trace.
Worked fantastic on both ionic breezes and took about 5 minutes for thesecond one. The first one took over 2 hours just to find the problem.
I hope this helps.....good luck...thanks for rating my effort....the Fang.
Nov 21, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Tip
Huge list of SMTP server settings from providers Worldwide A-C
Provider - SMTP server
12 012.net.il
191 mail.191.biz
191.it mail.191.it
AOL smtp.aol.com
Aruba smtp.aruba.it
Auna smtp.auna.com
bella.ci bella.ci
Blu.it smtp.blu.it
See also:
on Mar 24, 2010 | Symantec AntiSpam For SMTP 3.1
2000 vw beetle rear right turn signal light not working
yes, i also have had the same problems (with many many other problems). There is 3 recalls for exterior lighting..call the dealer and they should fix all for free!
Sep 15, 2008 | 2004 Volkswagen New Beetle Convertible
Sony FD Trinitron WEGA Won't Turn On
The key here is the count of the blinks. I'm assuming that the model number is KV-36FS120. Please post the blink count. It should be a count-pause-count...
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
