Question about Kitchen Ranges
Replacing oven thermostat
Where is the oven thermostat located on the electric range?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number?
Posted on May 03, 2013
5 Suggested Answers
  • 7 Answers
SOURCE: Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Posted on Feb 09, 2008
  • 382 Answers
SOURCE: GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Posted on Dec 27, 2009
heatman101
  • 43501 Answers
SOURCE: Whirlpool self-cleaning electric range
You can find a replacement online by following this tip...
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Here is a tip about the replacement of the glass...
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
heatman101
Posted on Apr 10, 2010
ercupa190
  • 12223 Answers
SOURCE: where can I locate a thermostat for my whirlpool oven model #RS6100XVN
go to www.repairclinic.com and buy give your model, serial number, mark, and ready.
God bless you
Posted on Jul 27, 2012
Why is the thermostat temp. range reading 30 degrees lower than it should be
Thermostat controls are nothing but variable resistors. Sometimes they build corrosion in the metal tab that it is sliding on. First try rotating the knob back and forth several times full range. If it is a slider instead of a knob, move it up and down full range. (This should be done on a regular basis.) If that does not work then shut the power off to the unit and get some contact cleaner. You can buy it in any electronic store. Spray the contact cleaner into the back of the control and work the knob full range again. It should feel easier to turn after a few turns. This should do the trick. If it doesn't, you need a new thermostat.
Feb 04, 2016 | Kitchen Ranges
Maytag oven won't heat or self clean
Roger. Thank you for the correct model number ! That helped! Your model has a high limit safety thermostat located either in the back of the range or under the cooktop. The service manual does not specify where, but on previous service calls, we find them usually in the back of the range, behind the metal back panel. This has gone bad. Usually after a self clean. 71001844 THERMOSTAT, HI-LIMIT - $43 and simple to replace.
High Limit Thermostat 71001844
Apr 09, 2014 | Maytag MER5770 Electric Kitchen Range
Oven doesn't turn off, then I have to unplug it
Hello, I hope your oven is electric. Your White Kitchen Range needs a new oven thermostat which is in the knob. If you replace the thermostat switch, please unplug the White electric range. GB...stewbison
Sep 12, 2011 | Hotpoint Ovens
Our Tappan oven does not heat up. The top burners all work, but the oven and broiler units are not heating up. What should we do?
It sounds like you have a thermostat problem, or possibly a selector switch issue. If your able to trace wiring, I would trace back from the selector switch to the thermostat than to each element to located which component failed. This will help you solve the problem. If your unable too, you will need to call a service person in your area to locate and replace the failed component in your unit.
Thermostat information www.repairclinic.com/PartDetail/Oven-Thermostat/318059310/892148
Selector switch information www.repairclinic.com/PartDetail/Switch/318057910/833283
I hope this helps
Aug 14, 2011 | Tappan TEF242 Electric Kitchen Range
Wall electric oven gets hotter than the tempature reading on the control dial
If this has a manual turn oven control (not electronic) you will have to replace the oven control thermostat.
First shut the power off to the oven at the main breaker. Remove the screws holding the front control panel in place. Some of the screws are located inside the oven and some are on top of the control panel. Tilt the control panel forward to access the oven thermostat. While holding the new thermostat in your hand transfer each wire the the corresponding numbers on the new thermostat. Unclip the oven sensor from inside the oven and feed it into the control panel area.Remove the screws holding the old thermostat to the control panel and discard old thermostat.
Insert new thermostat into the control panel and screw to panel.
Reinsert the thermostat sensor into the oven cavity and fasten to clips.
Re assemble control panel.
WARNING: make sure that no wires are touching when reassembling.
When everything is back together, turn power back on and test temperature.
Dec 30, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Oven takes up to 15 minutes to light. glow plug does appear to be bright orange immediately after turning oven on. it is a propane unit.
Hi, glow plug (element) should glow red, maybe you got faulty thermocouple, located ot bottom of oven burner, unit where gas enter oven burner, they could either be gas pilot or electrical element as metering device, give a little tap, could be stuck, could also be your thermostat, check oven thermostat, many ways to check oven thermostat, give thermocouple a little tap located at beginning of oven burner, if it didn't work, call a mechnic to make futher checks. good luck.
Aug 05, 2009 | Magic Chef CGR3725 Gas Kitchen Range
My smeg oven,(bottom fan oven) keeps getting hotter and hotter till it cuts out or the fuse blows when i switch it on no matter what temp i put it on,iam assuming its the thermostat,were is it and how yo...
The thermostat is obviously not working and you will need to replace it.
The thermostat is located behind the temperature selector switch on the control panel. The oven thermostat usually has a capilliary tube attached which goes in to the oven internally and is fixed on to the oven wall you will need to disconnect this also and remove it with the thermostat. Fitting the stat is the reverse of removal.
Make sure the electrical supply to the oven is switched off before starting work Hope this will FixYa.
Please remember to rate this solution.
Dec 12, 2008 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Maytag Stainless Steel & Black Electric Oven won't heat over 140 degrees
on a 220 volts stoves when the electrissity drops to 120 volts thats what it does.so oven element wires most be check for power, if it's getting 220 replace the element.
Sep 16, 2008 | Maytag MER5755QAS CleanDesign Electric...
Bake oven element blew
Could be the oven selector switch or the thermostat that failed form thhe element shorting out. You will have to have a ohm meter to check these
Dec 15, 2007 | Jenn-Air SVE47100 Slide-In Electric...
The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
Kitchen Ranges Logo
61 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
