Question about Garden
Task Master 1550 has no pressure?
I have a Task Maser Pressure washer with 1550 psi. I have had it for several seasons now and just took it out of storage and hooked everything up it started to spray on and off which is typical while it works the air out but then it stopped spraying anything. So I took off the front head to see if anything was obstructing it and saw nothing. when I pull the trigger the motor turns on and water comes out the front of the trigger but it is more like a hose and not pressurized. Help if you know what might be causing the issue?
stug_57u
  • 99 Answers
SOURCE: No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
Posted on Nov 01, 2008
Monster80
  • 463 Answers
SOURCE: pressure washer has no pressure
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
Posted on Apr 05, 2009
SOURCE: Ex-Cell VR2500 Builds Pressure but Won't Spray
I have a similar problem and diagnosed it to be a problem with the gun. I spoke to a technician that services this pressure washer and he walked me through all the diagnostic steps. The pump is working because there is pressure being built up and the gun sort of works because you can get water out before the washer is started. The technician said that the mechanism inside the gun is either clogged or broken. I am going to Home Depot or Lowes to purchase a new gun and will try it tonight. Guns are only about $30-40. He said generic is fine as long as the thread matches and PSI is in range. Good luck!
Posted on Aug 14, 2009
  • 10 Answers
SOURCE: I have the Coleman powermate 2400 PSI pressure
Sounds like the valve in the handle is sticking closed. May have a broken spring, or maybe a part is stuck..
I say take it apart, and the answer will present itself.. Play with it with nozzle out too... Maybe something is stuck after storing so long and will loosen up.. Fingers crossed
Posted on Oct 26, 2009
  • 2841 Answers
SOURCE: New Troy-Bilt 3000 psi - Very Hard to Hot Start
When you run the unit and shut if off, release the pressure from the spray wand before trying to restart the engine. This built up pressure will cause it to be very hard to start as you have found out. If it does not start on the second pull release the pressure again. Another option is do do what I did on mine. I simply put a pull tie on the handle so I can pull the trigger back and use the pull tie to hold the trigger open. Make sure if you do this, that you remove the high pressure orifice from the end of the wand before attempting to start the engine. Otherwise the pressure will come on abruptly and could injure you or do property damage.
Posted on Apr 25, 2010
Can i get a manual for this not syre i have all the parts grandpa passed and trying to hook up
www.pressurewashersdirect.com/manuals/CH%20electric%20manual_2.p..
www.ppe-pressure-washer-parts.com/task-force-power-washer-parts
Jul 02, 2014 | Task Force 2000 PSI Electric Pressure...
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    What is the price and types of the pressure washers and where can i buy it?
    Hi mary
    About the price i think Mr JERRY is true
    About the types there are many types like : -
    - 2000 PSI Electric
    - Gentron 2200 PSI Gas Pressure Washer
    - Gentron 3000 PSI Gas Pressure Washer
    - Gentron 4200 PSI
    - 1600 PSI Electric Pressure Washer
    - 2000 PSI Electric Pressure Washer
    - 2200 PSI Gas Pressure Washer
    And about the place you can buy these products, you can find many depots online like : -
    http://www.generatordepot.us/pressure-washers.aspx
    Thanks
    Oct 30, 2011 | Garden
    I don't know how to mix gas and oil. Can you tell me how? Thanks
    The CM-1250-OMEH is a electric pressure washer could you check the model number
    http://www.amazon.com/CM-1250-0MEH-Mi-T-M-Master%C2%AE-Pressure-Washer/dp/B0015BCB28
    Jun 07, 2011 | Mi T M Mi-T-M CM-1250-0MEH NA Chore Master...
    Presure relief value not working when let off trigger on wand
    sounds exactly like the problem and the soluition you are looking for.
    Mar 12, 2010 | Karcher 2500 PSI Pressure Washer
    I have A 1998 FORD RANGER EXT. CAB W/ 6 CYL.- 4.0 RECENTLY LOST PEDAL ON MY CLUTCH. REPLACED MASTER CYLINDER, SLAVE CYLINDER, AND THE CLUTCH PACK, HAVE FLUID THROUGH BLEEDER VALVE ON THE SLAVE BUT CAN NOT...
    Take the top off the master cyl and slowly very slow push in on the clutch and watch for any bubbles comming up.Replace the top and pump pressure and bleed at the master direct by using the lines for bleeders.
    Aug 13, 2009 | 1998 Ford Ranger SuperCab
    Garden Logo
    114 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
