Question about Koiiler XM-8787C Car Audio Amplifier
WHEN CONNECTING MY AMP THERE IS NO POWER, AND I HAVE EVERYTHING HOOKED UP RIGHT.
THE AMP IS HOOKED UP BUT STILL NO POWER AND THE FUSES ARE BRAND NEW
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
The amp is most likely blown.
Posted on May 10, 2013
Tip
Car audio hook ups
when installing a car audio sytem it is always wise to leave the power wire the last thing you hook up.ive seen many brand new amps fry because of people hooking power up to fast,if it sparks your in trouble, amps power wires should always be connect to the amp it self before connecting to the power supply. saves on amps:] And your ground should always be less then 3 feet on an amp the shorter the better!
on Jan 02, 2010 | Car Audio & Video
The problem with my marshall ma100h amp is that out of the box brand new it stopped working within a few days. Earlier I turned on the amp power switch and let it warm up. About a minute later I kicked on...
Brand new? Take it for warranty repair IMMEDIATELY... don't mess with it !!!
The only thing for you to check is that you did not turn on "STANDBY" as this shuts down the power amp and the capacitors will bleed off and sound will fade. Try switch in both states before complaining
ONLY use the amp in STANDBY for a brief period (20 seconds) to let the tubes warm up... Leaving in STANDBY for a long period straains the input filter capacitor. If you are done with using the amp, turn it off...
Jan 14, 2011 | Marshall Amplification Marshall MA100H and...
I have everything hooked up and i keep blowing the fuses in the amp?
did you use connectors on the amp or did you just strip the wire back then screwed the wire down? is the amp brand new?
Sep 12, 2010 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
I have an Dual brand 300 watt amplifier that I just bought and I hooked everything up right (battery---power, ground----sanded metal, bypassed remote with toggle switch remote-----+terminal on switch...
Is your toggle hooked to ground? Hook your toggle switch to the battery and then the other end of that toggle the remote input on the amp.
Aug 15, 2010 | Car Audio & Video
I tried hooing up my amp and subs but i get
make sure u have
power source with inline fuse working.
a ground line getting a good ground(scratch paint off care frame screw it down).
remote line from amp connected to the remote line on the radio.
and make sure you have rca running to the sub input on your radio.
and your speakers are connected.
Mar 25, 2010 | Kenwood KDC-138 FM / AM Receiver
I installed my amplifier today and it doesn't seem to turn on. I connected the remote wire to the dark blue wire on my harness on my cd player. The power wire is running from the battery and the ground is...
Check the fuse sometimes when hooking them up youll blow a fuse.but make sure your ground is to bare metal no paint should be on it. very important.. also make sure the blue wire has current using a light tester or volt meter. if you have a long wire run it directly from battery to see if its the remote wire . sounds like a bad ground is the amp new what is the brand
Oct 03, 2009 | Car Audio & Video
Visonik 350watt Amp Doesnt Come On....
With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Oct 06, 2008 | Visonik V117SX Car Audio Amplifier
Blowing fuses
Here are some answers:
1. Make sure your amp does not have a higher amp rating then the fuse, For example, an 18 amp amplifier will blow an 15 amp fuse, so connect it to a 20 amp fuse
2. you have a connection issue, where something is shorting out
3. you are pushing the amp or car to it's limit with how loud you put it, and thus blowing it, fixed by getting a more powerful amp and a better fuse.
4. or there is something very wrong and cannot help you and you would have to bring it into a shop.
Nov 18, 2007 | Car Audio & Video
My Hifonics TX1505D
dude check your remote wire and your ground also make sure you power wire hasn't come undone anywhere i mean really look at this stuff
Nov 18, 2006 | Hifonics TX1505D Car Audio Amplifier
Koiiler XM-8787C Car Audio Amplifier Logo
66 people viewed this question
Top Koiiler Car Audio & Video Experts
xxxxxx xxx
Are you a Koiiler Car Audio and Video Expert? Answer questions, earn points and help others
