2 speed fan switch wiring diagram
Company fan switch broken somebody disconnected some wires. trying to find wiring diagram motor has 5 wires blue,black,brown,green/yellow and red . Switch has 3 wires blue,black and red . Black box (Cap ?) 2 wires black and red ,four connectors still made,tying together,1)motor br,cap red and sw red.2) Motor G/Y & outlet grd.to box cover.3) Motor black & outlet black.4) Outlet White & black wire,(black wire disconnected).Also disconnected were black and blue from sw,black from cap.and red & blue from motor.Thanks Henry
  • Henry Madjeski May 04, 2013
    first time using Fixya, probably in wrong forum , this has nothing to do with ac. This is a fan we use in construction to move air ,its two speed I would imagine(sw broken and partially removed, has three wires ,which I expect would be off ,high,low
5 Suggested Answers
  • 587 Answers
SOURCE: I am replacing the a/c
Motor Wiring
Old Motor
Brown wire is Start
Yellow wire is run or Power
Black wire is High Speed or Common
The other two taps are speed taps, but you have a single speed application
And high speed is what you need ,that’s why there’s not any wires
on Red and Blue if high speed was to much then you would move the
Black wire to one of the other taps RED low speed or Blue Medinm speed
New Motor
White goes to the Yellow wire from the capacitor
Black goes to the Black wire you took off of high speed on old motor
Of course both Brown wires go to the capacitor and Green to ground
If a capacitor doesn’t discharge it doesn’t mean it’s bad
but the capacitors don’t last as long as they used.
Any time you put in a new motor always replace the capacitor
It will save you a lot of time and grief later on.
Posted on Apr 28, 2009
shastalaker7
  • 1515 Answers
SOURCE: I just purchased an fse1028sf
Hi, this is a different wiring diagram then what you have . The 2 brown/wht wires are for the run cap only. Black and white are t-1 and t-2. They sold you a motor that takes its own run capacitor to run it with just both brown wires. Take the diagram from the new motor back along with your original. They will give you the right run cap to go with this motor. Yes, the red wire is power to fire your existing cap and old motor. You will need another cap to run this motor. Don't put the 2 brn/white striped wires on the old cap! They have to be alone on there own run cap. Go back to the parts house and they will show you very fast the wiring diagram and give you the cap. This is a very easy fix when they give you what you need. Keep me posted and ask them to give you what you need to run the motor. A 5 uf run cap perhaps?
Keep me posted.
Shastalaker7
Posted on May 03, 2010
  • 45 Answers
SOURCE: i have a 3 speed ac motor to replace a single
Do not connect all the speed together. Do you have an RPM of the old and new motor. I think I can help you out if I had that info. Let me know.
Posted on Jun 05, 2010
Jahn27
  • 1554 Answers
SOURCE: I have a 30" drum fan that I turned over in my
You have a two-speed as indicated by the red jumper wire and brown wire left out for connection. These two wires connect to the speed switch with the red jumper to low speed and the brown wire to high speed. The black electrical cord wire connects to the L or COM terminal of the speed switch. The diagram below should give you better understanding on how the motor and the speed switch is wired.
The L/COM terminal makes contact with terminal 1 for low speed and terminal 2 for high speed. The OFF (0) is not shown.
Please accept the solution should you find it helpful and/or informative. Accepting the solution will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 16, 2011
How to check fan blower switch I need diagram of the switch
id find blower motor and hit it with a hammer if it turn on its bad also look at the wire to the resistor they melt down if its bad put new connector and resistor in iv done a few
Mar 04, 2015 | 2005 Chevrolet Silverado
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
I have a 3 speed fan with a red, blue, black an white wires, how are the supposed to be wired with power. the wires go to a little black box that appears to just be wires with no circuit board
The BOX is a GE splicer - with 6 wires - 2 grey power wires, then the red, blue, black, and white from the fan motor. I have the same problem and cannot find another GE SPLICER 3 SPEED SWITCH for the fan. All switches that I have tried have 4 connections.........so a WIRING DIAGRAM would be GREAT!
Can anyone offer any help? I have tried every electrical store in the area!
Thanks
May 29, 2011 | Patton U2-1887HO Floor / Box Fan
I was trying to install a fan control switch on my Patton floor fan and took the 3 speed switch out and disconnected the wires and cannot figure out what wires (too many colored wires) to connect to the 2...
Thr issue you are having you need to look on the motor and see if there is a diagram but you have to use the grey and white for a capacitor because i have an older fan that has no capacitor. and use the red for high
Dec 28, 2010 | Patton U2-1487 Floor / Box Fan
Wiring diagram for a 3 way ceiling pull switch.
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
May 29, 2010 | Hampton Bay 24750 Huntington III Ceiling...
5 speed fan on h&a #5 quit 1st and now all speeds have quit working. What does this sound like , switch or relay. Can I disconnect wiring at the fan motor and tell which is bad with a volt meter.
There is a voltage regulator somewhere in that circuit. it controls the speed of the motor by changing the voltage in the circuit. Trace the wire back from the motor and you will find it, it's between the switch and the motor. They sometimes get hot and stop working on certain speeds. Change it out with a new one and check the amperage on the circuit to make sure you won't cook your new one. Good luck.
Apr 18, 2010 | 2006 Chevrolet Silverado 1500 2WD
Just replaced broken pull 3-speed switch. Fan now only runs on two speeds, need wiring diagram please
I ran into this when replacing the 3 spd switch. The replacement switch has a pair of connections at each position; you would assume the two connections are electrically tied together, they are not. The switch assembly actually has two seperate 4-position rotary switches. If your "L" wire is on the 'inner' connection, then your motor speed wires will have to be as well.
Jul 27, 2009 | Hunter Dryers
Heating & Cooling Logo
389 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
