Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Where does spring go? - Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
  • Official Brand Answer
  • 315 Answers
Hi. The spring will need to be repaired by one of our Authorized Service Centers.
Here's a quick link to help you find one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
Posted on May 02, 2013
Dyson DC25 -wand extension lost a spring and becomes disconnected during use. I don't know where spring should be?
The button you push to release the wand has a spring to allow it to spring back after the button has been released. If that spring is missing the wand will not stay attached.
Jan 10, 2017 | Dyson Vacuums
How is the spring attached to the valve door.
spring to valve door on what? Need more info.
Feb 27, 2015 | Vacuums
How do i install a replacement spring in a tool catch
it isn't obvious from the pics but if I had to guess u need to get both the catch and the spring (if u lost it) b/c the reason the spring came out is that the catch is already broken.
Once u get it, it simply pops into place.
look at this page - may help
http://www.vacpartswarehouse.com/Dyson-Silver-Tool-Catch-DC25-DC33-DC35-DC44-DC56-p/dy-911523-03.htm
Sep 21, 2014 | Dyson DC35 Handheld Vacuum
Switch Assembly
one spring larger goes on the red on /off small spring goes on the little white piece
Apr 05, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Stiches are loose in the bottom side of the cloth,if i change the bobbin case....will it help? I can understand that tension of thread is the problem.....but don't know what to do
the case the bobbin goes into has a little spring on its side .. the spring has one or two screws. one screw adjusts tension on the spring .. the bobbin thread goes under that spring when it is properly threaded .. if the screw is loose or missing then replace the screw or tighten it a little so that thread pulled thru the bobbin case spring has a bit of drag .. if its too loose then you can tighten the screw a bit more ... if you tighten it too much then it will pull the top thread thru to the bottom .. if your adjustment screw or spring is missing then you can replace the bobbin holder .. the new one should have the spring in place and be properly tightened .. . often the adjustment screw is just loose or the thread is not positioned correctly in the bobbin case slot. .
Jun 21, 2010 | Vacuums
Dyson DC-07 Hose Wand Spring Came Out. How to put back in?
You'll see that there is a round piece with a cross shape on the inside of the button wand release button - place the end of the spring over the cross - you'll see the same cross on the collar of the machine...it'll take some doing, but line the other end of the spring up with the cross and pop the button back into place - be sure to click it onto those two gray circular/oval shaped divets at the bottom where the release button connects to so that the button stays in place.
Jun 25, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Metal Spring in Belt area?
Yes the metal spring is used to pivot one of the rollers in that area.
You would need to take it apart one more time and check to see if any of the roller travel up or down while you press it with your fingers. look to the edge on either side for a place to attach the end of a spring. then a place on the chassis to add the other end of the spring. Then redo the belt.
May 24, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Spring on bottom wheels eureka altima
look up inside where the wheels go and you will see a open notch clip the spring in there and on the wheel assembly itself oon the inside you will see a holeclip the other end of the spring to that .your done
Apr 22, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Royal upright handle fork spring replacement
This is actually fairly normal, and there's no real easy way to get that bolt out. Your best bet is to continue turning it as if you were unscrewing it while applying pressure to the opposite end. A narrow piece of metal can help, especially if coaxed with a ballpeen hammer. If possible, you can try to apply some pressure upward on the spring to keep it from holding the bolt too tightly, but this only works about half the time.
Getting the bolt back into place is also something of a nightmare, as you have to use your thumbs to hold the new spring in place while forcing the bolt back into place. I've had indentations on my thumbs from holding that spring many times.
Good luck,
-R
Sep 22, 2008 | Royal 5300 Upright Vacuum
Replacing spring in wheel height adjustment
I just solved the problem. Go to this website: http://www.completevac.com/kirby_schemo_5.html
It will show you where the spring goes (left side inside the ratchet - when you remove the ratchet you will see that it is hollow. That's where the spring goes!) and a good picture of that assembly
Jul 30, 2008 | Kirby G6 Bagged Upright Vacuum
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
22 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
