Dell 3300 MP Projector
There is a white line on the left even after I changed he Bulb. Need help
    Problem Solver:
  • 5 Answers
Try turning the projector and a extra tip is off the lights so you see better
Posted on May 01, 2013
Marrie
  • 563 Answers
SOURCE: White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Posted on Apr 01, 2008
Sinista
  • 6 Answers
SOURCE: Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Posted on Jul 10, 2008
omg, I just figured out why OUR projector was doing this! There was an adaptor plugged into it that we use to hook it up to cable to watch games/tv shows sometimes...once I unplugged that from the projector the lines dissapeared!
Posted on Oct 02, 2008
SOURCE: White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Posted on Oct 29, 2008
  • 8 Answers
SOURCE: Vertical lines on projected image from a Dell Data Projector. White vertical lines are appearing at even spacing across the width of the image projected. At a loss to how to fix this. Any ideas as to
that is due to lcd filter units , try to align, precision work
Posted on May 25, 2009
Dell 2300 MP Verticle lines distorted image
light engine or bulb is gettingbad ok how many hours on bulb fans clean ect thx nick
Feb 11, 2008 | Dell 2300MP Multimedia Projector
Trying to synch my mac and my dell 3300 MP so i can deliver a power point.
Your Mac should do it automatically. I suspect you need to get into projectors "input" menu an assign what input it's supposed to recognize . (it'll give you multiple choices)
Mar 11, 2011 | Dell 3300MP Multimedia Projector
I think this is a lamp issue. Even though your lamp might have an advertised time of 3000 hrs from Dell, it can fail and dim a lot earlier than that. Often within 1000 hrs a projector lamp's brightness can be reduced by up to 40%. Projector lamps brightness and lamp life varies according to how you use your projector and the environment it is in. Our company sells projector lamps and has created a YouTube video to help people get the most out of their projector lamps. You can see the video below. If you decide to buy a new lamp we have the lamp you need in stock at Projector Lamp Experts.
Hope this helps..
Jul 15, 2010 | Dell 3300MP Multimedia Projector
Dell 5100mp dlp projector - white vertical lines evenly spaced
clock and phase are off. go into menu and reset the settings to factory default.
Sep 02, 2009 | Dell 2400MP DLP Projector
During Powerpoint presentations, I am unable to play embedded video clips OR straight from a DVD that is minimized on desktop without a lag...on the screen it says 'searching for signal' when I click on...
this is caused by your computer changing resolutions in order to display the video full screen. to decrease this, set your screen size as close as posible to the size of the video
Aug 14, 2009 | Dell 3300MP Multimedia Projector
Dell 3400mp Projector is flickering
Hello. Based on the video, return the projector and get a new one since it is still under warranty. The symptom has nothing to do with the lamp or connections. It appears to be an image processing problem on the main board. The blank part isn't distorted or scrambled, it's MISSING!
Feb 18, 2009 | Dell 3400MP Multimedia Projector
341 people viewed this question
jasbo
jasbo
