Question about U-Line Icemaker
Ice maker hanging up
I have an UIM-155 ice maker that keeps hanging up with a little piece of ice. It will work for a short time after the piece is removed.
  • 1073 Answers
SOURCE: Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Posted on Jun 24, 2008
SOURCE: how to replace the ice maker unit.
I just RR'd mine. Undo the three screws on the bottom of the metal piece that the ice maker sits on, then the two screws that are horizontle above the . Take of the back, withdraw the termocouple from the tube that goes through the foam, clip the wires (5) leaving enough of a pigtail to crimp a **** splice to the new ones. Withdraw the fill tube. Don't lose the clay that seals the holes through the insulation. Withdraw the ice maker by gently twisting and pulling straight out. Replace in reverse order. Getting the screws back in is a little tricky.
Posted on Jul 15, 2008
SOURCE: b195 ice maker not making ice
the solenoid might have packed it in
Posted on Oct 27, 2008
  • 286 Answers
SOURCE: My U-Line ice maker somehow leaks water inside the
You can have a couple of things causing this. First do you see flakes in the ice cubes? Yes replace the icemaker. No then I would remove the cover off the icemaker (pry on the corners and pull) Check to see if the motor gears is rusty. If yes then its causing the motor to run slow and overfillilg the icemaker. You can also check to make sure the fill tube is pointing downward in the water cup of the icemaker. If that looks goo then it cold be the matter of replaceing the faceplate of the icemaker. That would replace the switch, motor and gears.
Posted on Aug 16, 2009
heatman101
  • 43501 Answers
SOURCE: Ice Maker not making ice
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jun 09, 2010
Ice maker was jammed or not working so I pulled the tray out. Inside the tray was a plastic piece about 3 inches long with a piece of styrofoam on it. Inside the maker there is now a white cord han
Good Morning Friend,
I understand the ice maker was jammed on your Frigidaire refrigerator, model# FGHB2844L. I also see that when you pulled the tray out, there was a 3 inch plastic piece with a piece of styrofoam on it. Now there is a white cord hanging inside the ice maker. I suggest contacting your local authorized technician for further assistance. They will be able to determine what exactly is needed to repair your ice maker. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
My Whynter UIM-155 ice maker used to make alot of ice quickly. Now, it does not make very much ice and it takes a long time? What should I do?
look at the condenser coli to see if it is dirty if so clean it. Dirty coil will cause it longer to make ice. also make sure nothing is blocking the condenser return.
Aug 20, 2013 | Whynter UIM-155 Stainless Steel Built-In...
Ice maker jammed how do I remove it.
What I do is use a hair dryer to melt the ice. Keep at it till the ice maker goes around and resets for the next harvest. Ice cubes hang up from time to time. I wrote an article on it
Help my Frigidaire Gallery ice maker Jammed!!
Mar 30, 2011 | Refrigerators
A rubber piece fellout and there is a white wire hanging out.
This just happened to me.
The waxy piece has a clear plastic bracket, if its not connected, look around your freezer. The waxy piece fits inside the bracket, and attaches to the ice maker, just in front of the ice tray.
The white wire fits inside the waxy piece. It is the thermostat that tells the ice tray when to dump the ice.
This is impossible to feel around for, so you will need to remove at least the bottom freezer compartment as well as the ledge piece from just inside the freezer door. If you are a relatively thin/small person, you can extend the top tray fully outward, and slide underneath. Looking up at the ice maker, the plastic bracket should have a little prong. This prong will attach just behind the ice maker, with the thermostat facing the ice tray.
Mar 02, 2010 | Samsung RF265AA Bottom Freezer French Door...
Ice maker not working but water keeps leaking and freezing on the freezer door
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards
Jan 04, 2010 | GE GSS23SGSSS Stainless Steel Side by Side...
RF266ABPN French Door Firdge/freezer Ice maker sensor
I found David's solution very helpful and I'll just add to it. Take out the top freezer door-- it just slides out and up. I had a bunch of stuff on the little shelf on the actual door and I had to take some of it off first. The big bottom drawer stays on. The little foam piece was on the floor of the freezer so I picked that up and can see how the little sensor part fits into it. Next, I put a chair next to the open bottom drawer, sat on it and leaned back onto and into the big drawer. I had to torque my head to actually get right under the ice maker. I am 5'5" so I don't know the heck David did it! Anyway, there is a little "slot" next to the last ice cube mold closest to the door. This is where the foam piece goes in. The slot where this piece goes has some raised lines sticking out on each side-- I wouldn't call them brackets and the foam thing doesn't stay in well by itself. However, on the right side of the ice maker, near that last cube, is a little hook. So I slid foam piece up with the sensor tucked in, facing the ice cube mold. I wrapped the tail/wire around the bottom of the foam piece and also the hook, so that it kind of holds the foam piece up in there, kind of cradling it. That was my solution, we'll see if it works!
Sep 29, 2009 | Samsung RS2534 Side by Side Refrigerator
Wires hanging in ice maker area
Look underneath the 2nd row from left in the ice tray there should be a white plastic piece that pops in and out from the bottom of the ice tray. Pop it off. There should be a piece of styrofoam on top of the piece you removed. the white wire runs along the bottom of the ice tray there may be little plastic hooks to place wire along the way. The sensor should fit right where the white piece of plastic and styrofoam you removed goes. Just place it there and pop that piece back in. It really doesn't attach to anything just lays there.
May 26, 2009 | LG LSC26905TT Side by Side Refrigerator
KitchenAid Superba ice maker not dispensing ice
this is not a solution, but an explanation- our repair man said that there is a line (tube) containing electric wires that passes from the frig to the door at the bottom of the door, near the hinge. for what ever reason, the line has broken, thus keeping the electric from getting to the motor that dispense ice and water- solution= $700 for a new door; we'll do without
Sep 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker problem
I also have this problem.  The ice that was hanging, when looking in the freezer was the right side ice.  I just releveled the frig or increased the height of the side that was hanging causing the water to level.  It has cut down on the amount of ice or times the ice hangs.
Sep 17, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
U-Line Icemaker Logo
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
