Question about Logitech Cordless Mouse
Red lite on top keeps flashing....is this proper?
    New Friend:
That usually means the batteries are low
Posted on Aug 31, 2013
Unit has power bur will not turn on
You need to be specific to get help. Just what is happening? What is not turning on? The compressor? The fan(s).
Is thermostat properly set?
Jun 19, 2016 | Heating & Cooling
Sony kdf-37h1000. push power button and the green lite comes on steady and i can hear a fan. never gets to a picture or sound. it then sounds like it shuts power off but lite goes from flashing green to...
Hi catfishbob,
You're lamp came to its peak burning life and now its dead that's why you can't power up the unit and the led light keeps flashing. Once the lamp replace with new one your unit will back to normal again. Click this link for the replacement http://shop.ebay.com/i.html?_nkw=KDF-37H1000&_sacat=0&_odkw=sylvania+ld370sc8s&_osacat=0&_trksid=p3286.c0.m270.l1313.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 05, 2011 | Sony KDF-37H1000 37" HDTV
When switching ds lite on green light flashes then foes off andbottom screen just flashes on then foes off - top screen does nothing
make sure the top screen ribbon cable is attached to the connector properly, push the cable in as far as it will go and then try again, if that dosent work it may be a fuse on the board prob f2 if that dosent work change both it should fix the problem
Jan 14, 2010 | Nintendo DS Lite Console
DS Charging Diffuculties
( times out of 10 here its the battery if by replacing the battery it still does not charge you got a bad charging unit inside the DS and your repair bill will be under $75 bucks to replace the chargin element inside.
Like my advice please accept and rate it today. We accept all postive answer ratings , Thanks.
Oct 09, 2009 | Nintendo DS Lite Console
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Power light keeps flashing
Sound like residue from the protective tape that was on the cartridge. Take the cartridge out and clean the copper contacts with a Q-Tip dipped in alcohol. VERY lite-ly... I have seen a lite glaze from the tape stopping proper contact if the were on the store shelf very long....
Please rate this solution if it helps.... Thank You...
Oct 25, 2008 | Lexmark X1270 All-In-One InkJet Printer
No sound or pix
3 times flash of standby light shows that Lamp Cover is not mounted properly after replacement of Lamp.
Please fix lamp cover properly because cover has to press protection switch in circuit.
Sep 17, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Nintendo DS Lite won't turn on
My kids did the same thing. What I did to get it to work was to push back on the top and hold it turn it on. If it comes on then turns off after you let it go get 2 rubber bands and put the 1st. one on the top left down to the bottom right. The 2nd. one goes from the top right right to the bottom left. Then keep turning it on while moving the top to find the sweet spot.
Jun 03, 2008 | Nintendo DS Lite Console
Kenwood kac 859 amp
hi, note that if you are not using the proper gauge b+ and gnd cable with this amp then the current available at the amp wont be sufficint to keep amp on. also try using this amp while vehicle is idling. if this doesnt work then disconnect all spks from amp and check if red lite stops flashing. if it doesnt stop flashing then amp has internal fault. if lite stays on brite then proceed to check each spk load impedance, then reconnect each spk individually. the minute red lite starts flashing it will give you a clue that the channel or spk load is faulty. cheers
Jul 27, 2007 | Kenwood KAC-859 Car Audio Amplifier
Logitech Cordless Mouse Logo
90 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
