Question about Canon imageRUNNER ADVANCE C5030
E000027 0300 Was able to reset in service mode. problem back again. Not sure where to go next.
I have recently brought my hous3 and have a Honeywell ST9400S. It says it needs a code as a service is due but this was done the week before I moved in. How do I find the code to override this.
Here's a link to the manual. You'll probably need it for future and current issues.
https://www.google.com/search?q=Honeywell+ST9400S+manual&ie=utf-8&oe=utf-8&client=firefox-b-1-ab
Resetting the Service Timer Function
If the Service Timer function is enabled you will be required to reset it after the boiler service has been carried out.
The process for resetting the Service Timer is as follows:
a. Enter Installer Modes (as described on page 3 see manual) and navigate to SET SERVICE mode. In response to the query 'SET SERVICE OK ?' press the button to enter SET SERVICE mode.
b. If you no longer require the Service Timer, disable it by setting parameter AL to 0 and confirm with the button.
c. If you still require the Service Timer, set the number of days until the next service is due using parameter d and confirm with the button.
d. Whilst in SET SERVICE mode, use the opportunity to change any other service parameters if required.
e. Exit by moving the slider to the next position and back again to RUN
My suggestion is to download the manual and print a hard copy to have when you begin the reset process.
I know i'd need it! :)
Cheers
Feb 14, 2018 | Honeywell Heating & Cooling
Tip
How to "Reset" your printer.
So your printer is stuck, it will not work, it won't print. Well try a "Reset" it may, just sort your problems out. Here is what to do. Unplug the power cable from the BACK of the printer, Next, Remove the USB cable from the Computer. Reboot the PC, when at the desktop next, Reconnect the Power, and plug in the USB cable, wait a bit, Reboot again, next time, at desktop... you should be all good. Now often the printer has "Jobs" in the "Que" these must be canceled, double clicking on the Printer Icon will bring up the printers "Que" window. Now you right click on the "Print Job" in the window,and select "Cancel" Now sometimes, you cannot do this, as it simply refuses to "go away" in this case, you MUST reconnect up the printer, to that PC, turn it ON, & then you should be able to "Cancel" that print job, often you will see many copies of things to "Print" these ALL must be "Canceled" If that doesn't work, Delete the Printer, Right Click, select "Delete". Now Reboot, and then, either, set up the printer, directly attached, or set it up as a "Networked printer". Then this will have cleared anything that was causing problem and you are back to a fresh new printer. ver faced problems with resetting your printer? Well, here we provide you invaluable tips to help you troubleshoot your HP, Dell, Lexmark, Brother or Samsung Printers in easy steps.
Resetting an HP laser printer
There is a technique known as cold resetting. It basically will set all your HP printer settings to the factory default levels. It is important to note that any settings made at the control panel of your printer are going to be reset. Hence, in case you happen to have a JetDirect card then even the IP address will be reset to the factory defaults. Make sure to remove the card before resetting your HP printer. You can try to reset NVRAM. To do this, switch off your HP printer and then hold down the ‘Go’ key for around 20 seconds while switching the printer back on again.
- HP 1200 and 1100 models resetting: To do this, simply change the data by going into the service mode. This is applicable if your HP printer has a display panel. Otherwise you need to hold down the ‘Go’ button for around 5 seconds while the printer is switched on.
- HP 2100 printer resetting: You need to press the ‘job cancel’ key after switching off the printer. Then switch the printer on and only then release the key called ‘job cancel.’ Make sure you release the button within 20 seconds of the LEDs coming on.
- HP 2200 printer resetting: Switch off your printer and then hold down the ‘Go’ key. Switch back the printer on while holding the ‘Go’ button till the light comes on. Then release the button.
- HP 6P and 5P models resetting: Switch off your printer and then press the ‘reset’ button and within 20 seconds switch on the printer back again.
Resetting a Dell printer
You can reset your Dell printer fairly easily by simply double-clicking on the ‘Reset Dell Printer’ icon. You can reach this icon by clicking on the folder ‘UAN’, then clicking on ‘System Utilities’ and you should find the icon. However, one word of caution – this method will function only if the USB cable has been directly connected from the PC to the printer. If you are using a USB Hub or some switch box then this method will not work.
Resetting a Lexmark printer
You will firstly need to switch off your printer. Then simultaneously press the RETURN and READY keys while switching the printer on. This will take you to the Diagnostics Mode. The display unit will show the message ‘Performing self test’. Choose ‘Maintenance count’. Reset the count to make it zero. Then select the RETURN key and go back Diagnostics Mode. Then you can reset the printer to go back to the normal mode.
Resetting Brother Printer
You need to keep pressing the DOWN or UP keys a couple of times till you see ‘Maintenance 99’ displayed on the display. Then hold down the ‘Set’ button to go to standby mode. Please note that if you press the exit key only after typing in a single digit then the machine goes to maintenance mode in initial stages. If you have entered an invalid code by mistake then too the machine goes to maintenance mode in initial stages.
Resetting Samsung printer
You need to press the following keys in quick succession – MENU # 1 9 3 4. Then you should see a message on your display saying ‘TECH.’ Then again select the MENU key followed by ENTER. The display will now show ‘TECH MODE.’ Then select the ‘<’ key two times. Your operator panel should show ‘NEW PRINTER CARTRIDGE’. Then select ENTER. Now the panel will show [YES]. Select ENTER key again. You can exit from this mode by pressing MENU # 1 9 3 4 again one after another.
on Feb 11, 2010 | Office Equipment & Supplies
How do I reset the Service stitch count? Just had it serviced and the repairman forgot (again). That's the only way I can seem to keep track unless something stops working!
Take it back in. This is in the Service Mode on the Machine. It's not hard, just very technical. If a wrong selection is made you can mess up other major settings on your machine. That could be more costly that the trip back to the shop. Next time, tape a post it on the machine front to the repair tech. It'll help remind her/him!
Mar 04, 2016 | Baby Lock Esante
How I can reset my color, brightness, contrast and sharpness and have they stay the way I set them. Every time I turn my tv on and off I have to go and reset the them all again cause they go back
Main system control memory IC is faulty. Replace it. Contact any service technician.
Try a reset to this TV, and check it first; before doing anything.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Nov 29, 2014 | Televison & Video
How to reset canon printer ir 2320L
I'm not faliliar with this model as I only work on American sold models but I'm sure the following may help. I'm also assuming you have an error code and turning off and then back on the power didn't help. Try resetting the error code by going into service mode: Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. You should be in service mode. If not press the reset key serveral times to make sure everything is reset and try getting into service mode again. Press the " COPIER " button on the display and the screen changes. Press the " FUNCTION " key across the top of the display and then " CLEAR " then " ERR " and finally " OK ." You have cleared the error out of the copiers memory. Turn off the copier waits a few seconds then power back on. Hopefully this gets you in the right direction.
Aug 15, 2012 | Canon imageRUNNER 5000 Copier
ERROR CODE e000001-00010
Thsi is an error code dealing with temperature of the fuser assembly. . Try resetting the error code by going into service mode: Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. You should be in service mode. If not press the reset key serveral times to make sure everything is reset and try getting into service mode again. Press the " COPIER " button on the display and the screen changes. Press the " FUNCTION " key across the top of the display and then " CLEAR " then " ERR " and finally " OK ." You have cleared the error out of the copiers memory. Turn off the copier waits a few seconds then power back on. If the error comes back then you have to have the fuser assembly either rebuilt or totally replaced. Good Luck.
Jul 31, 2012 | Canon imageRUNNER 5000 Copier
My ikon Image Runner 2200 has an error message E000003000
All E000 codes have to do with the fixing unit. It can be reset but if the code comes back it will need to be serviced. It has been known to be caused by electrical noise on the main power supply so a filter might keep it from coming back.
To reset. Press the star button followed by 2 and 8 at the same time, then the star button again. You should now be in service mode. Select COPIER and this will give you some options along the top. Select FUNCTION. In the list select CLEAR. From the next list select ERROR and press ok. Then switch off machine and back on at the power socket. If it clears then all is ok.
Be warned!! Do not try to change any settings in service mode or clear any other function!! It is very easy to mess a lot of things up while in the service mode.
Aug 05, 2010 | Canon Office Equipment & Supplies
Service error 5C00. Cancel printing and turn the printer off and then back on. If this doesn't clear the error, see the printer manual for more detail.
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in succession. Note: you are still holding the POWER button). The printer's carriage will “reset" or move momentarily.
If the above was properly performed the printer will enter the "Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp will alternate (change) color with each key press. Next press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
The problem with resetting the waste ink counter is that the waste tank could at some point over-flow. If you manage to get inside to empty the wadding and waste ink tank, make sure you wear rubber gloves as the ink will get everywhere..
And make sure you replace with some fresh wadding if you can..
Regards
Mike
May 27, 2010 | Canon BubbleJet i560 InkJet Printer
Will not power back up.
Hi
The waste ink are in the inside of your printer you need to get at it to clean out, but after this you got to reset it after you cleaned it or it will still not work, you may not have to get inside to clean it try this first to reset it.
Reset CANON PIXMA IP5000 printer To reset the counter or to find out about it’s reading you have to use the service mode.
Turn off the printer, push the resume button and keep on pushing.
Press the power button and keep on pushing. Now let go off the resume button,
but not the power button. Push the resume button twice, then let go off all buttons.
You are now in service mode.
To leave the service mode, give the power button one push.
Push the resume buttons once, after that the power button once.
The first information page appears.
Push resume twice, then power once: You get the second page.
Newer PIXMA-printers print the first page as a test for the nozzles.
The second page contains a lot of information.
Our advice: Print the second page before and after reset of the waste ink counter.
Only then can you be sure that the reset was a success.
To reset the waste ink counter right now, push resume four times and after that power once.
Important: Before starting with normal printing again, switch off the printer.
That gets you out of service mode.
Then switch on the printer again and print, as you like
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 05, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
Canon imageRUNNER ADVANCE C5030 Logo
266 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
